Hello everyone,
I've just got the Arduino UNO yesterday, and I had a problem with a simple program.
the program is when the push button is pressed LED1 is ON and LED2 is OFF and when released LED1 is OFF and LED2 is ON.
what happens is LED2 is always OFF :|, and LED1 is switching normally as it should.
if anyone could help, I'll appreciated.
here's the code:
int PushButton = 2;
int LED1 = 3;
int LED2 = 4;
pinMode(PushButton,INPUT);
pinMode(LED1,OUTPUT);
pinMode(LED2,OUTPUT);
if (digitalRead(PushButton)==HIGH) {
digitalWrite(LED1,HIGH);
digitalWrite(LED2,LOW);
if (digitalRead(PushButton)==LOW) {
digitalWrite(LED1,LOW);
digitalWrite(LED2,HIGH);
And about my connections, I've connected the switch with a pull down resistor 220ohm, and the two LEDs are connected to the digital pins 3 and 4 through 220ohm resistors.
I've checked for the LEDs and the wires and everything is just fine.
