I want to use an old ATmega8 as analog input converter for a raspberry pi to monitor the 5V power supply voltage.
To minimize hardware, the ATmega runs on 8MHz internal clock and is directly connected to the SDA and SCL pins on the raspberry using the latter's internal pullups.
I use the internal 1.1V reference and have a 10k - 2k2 voltage divider to the 5V.
The programs are very simple.
On the ATmega:
#include <Wire.h>
#define I2C_ADDRESS 0x10 // ATMega8 I2C address
uint16_t adc_value = 0 ; // Variables to store ADC result
{ analogReference( INTERNAL ) ;
Wire.begin( I2C_ADDRESS ) ; // Initialize I2C as slave
Wire.onRequest( sendADC ) ; // Register function to send ADC value
{ adc_value = analogRead( A0 ) ;
delay( 100 ) ; // Small delay to prevent excessive analog reads
void sendADC()
{ Wire.write( highByte( adc_value) ) ; // send ADC value over I2C
Wire.write( lowByte( adc_value) ) ;
And on the Pi:
#!/usr/bin/python
import smbus
import time
I2C_ADDR = 0x10 # Arduino address
bus = smbus.SMBus( 1 ) # Use I2C bus 1
while True:
data = bus.read_i2c_block_data( I2C_ADDR, 0, 2 ) # Read 2 bytes
adc_value = (data[0] << 8) | data[1] # Combine high and low byte
voltage = adc_value * (6.1 / 1024) # Convert ADC value to voltage
print( f"ADC Value: {adc_value}, Voltage: {voltage:.3f}V")
time.sleep( 1 )
For testing purposes, I did use the 3.3V of the Pi.
i2cdetect shows that the Pi does see the ATmega on address 10.
The problem is, that I get false readings.
The output shows: ADC Value: 235, Voltage: 1.400V
If I replace the ATmega8 with an Arduino nano and load the very same program, I do get the correct output ADC Value: 556, Voltage 3.312V
So the programs do work, but there seems to be a communication problem with the ATmega8.
I already lowered the i2c baudrate in config.txt to 10000 but nothing changed.
Any clues what I can do to solve the issue?
