I²C doesn't behave like I want
Hello,
So I have quite a question. I am building a modular macropad with an Arduino nano ESP32. The idea is that there are different modules that can move. For the Arduino to know when which button is pressed, or which potentiometer is turned, I use different PCB's each with an ATMega328P-PU.
On the module with the Arduino is also a display, this, and the ATMega's, communicate with I²C. The problem is that they just don't want to work together. In the code is a custom library, I will add it here, but it doens't do anything major to this problem.
code for the arduino:
#include <BleCombo.h>        //library to establish BLE HID connection
#include <time.h>        //include time library
#include <WiFi.h>        //include wifi library
#include <Adafruit_GFX.h>        //library to print and draw on the OLED-display
#include <Adafruit_SSD1306.h>                                                             //library to establish connection with the OLED-display
#include <Wire.h>        //library to establish I²C connection
#include <GIP.h>
#define SCREEN_WIDTH 128        //OLED display width, in pixels
#define SCREEN_HEIGHT 32        //OLED display height, in pixels
#define OLED_RESET     -1        //variable to connect the screen with reset (needs to be -1 to share reset)
#define SCREEN_ADDRESS 0x3C                                                               //adress of the OLED-display
#define battery_port A0        //port to read the battery level
#define switch_chip 1
#define slide_chip 2
#define rotation_chip 3
#define joystick_chip 4
#define string_length 7
const char* ssid     = "Stemnet";                                                         //define the wifi adress
const char* password = "";        //define the wifi password
long timezone = 0;        //set the timezone
byte daysavetime = 1;        //set the day
struct tm tmstruct;        //make a time structure
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);                 //start communication with the OLED-display
mechanical_switch switch00(10);
mechanical_switch switch01(11);
mechanical_switch switch02(12);
mechanical_switch switch03(13);
mechanical_switch switch10(14);
mechanical_switch switch11(15);
mechanical_switch switch12(16);
mechanical_switch switch13(17);
mechanical_switch switch20(18);
mechanical_switch switch21(19);
mechanical_switch switch22(20);
mechanical_switch switch23(21);
mechanical_switch switch30(22);
mechanical_switch switch31(23);
mechanical_switch switch32(24);
mechanical_switch switch33(25);
bool wifi_connected = false;                                                              //this boolean will be set true when the arduino is connected to the wifi
char cursor_place = 0;        //variable to store the position of the OLED cursor
char battery_level = 100;        //variable to store the previous send battery level
char real_battery = 100;        //variable to check the battery level with the send level
char I2C_count = 0;        //variable that adds up with each incomming byte
char I2C_check = 0;
char I2C_chip_adress = 0;
char I2C_interface_adress = 0;
char last_read = 0;
  Keyboard.begin();        //make a Keyboard object
  Mouse.begin();        //make a Mouse object
  display.begin();
  Wire.begin();
  switch00.begin(0x80, 0x82, 0x81, 0x41);
  switch01.begin(0x80, 0x82, 0x81, 0x42);
  switch02.begin(0x80, 0x82, 0x81, 0x43);
  switch03.begin(0x80, 0x82, 0x81, 0x44);
  switch10.begin(0x80, 0x82, 0x81, 0x45);
  switch11.begin(0x80, 0x82, 0x81, 0x46);
  switch12.begin(0x80, 0x82, 0x81, 0x47);
  switch13.begin(0x80, 0x82, 0x81, 0x48);
  switch20.begin(0x80, 0x82, 0x81, 0x49);
  switch21.begin(0x80, 0x82, 0x81, 0x50);
  switch22.begin(0x80, 0x82, 0x81, 0x51);
  switch23.begin(0x80, 0x82, 0x81, 0x52);
  switch30.begin(0x80, 0x82, 0x81, 0x53);
  switch31.begin(0x80, 0x82, 0x81, 0x54);
  switch32.begin(0x80, 0x82, 0x81, 0x55);
  switch33.begin(0x80, 0x82, 0x81, 0x56);
  pinMode(battery_level, INPUT);                                                          //make the battery level port input
  pinMode(7, INPUT);
  if(!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)){                               //if the internal OLED display voltage isn't 3.3V, don't stop the loop protect the OLED display
    Serial.println("ERROR: 1D1");                                                         //print the error on the serial monitor
    for(;;);        //go in an infinite loop
  display.setTextSize(1);        //set the standard text size to 1
  display.setTextColor(WHITE);                                                            //set the standard text color to white
  display.clearDisplay();        //clear the display
  display.setTextSize(2);        //set the text size to 2
  display.setCursor(2, 2);        //set the cursor on the display to pixel 2, 2
  display.print("START-UP");                                                              //print text
  display.display();        //display text
  delay(750);        //wait 1.5 seconds
  display.setTextSize(1);        //set the text size to 1
  display.print("connect to:");                                                           //print text
  display.setCursor(2, 15);                                                               //set the cursor on the display to pixel 50, 2
  display.print(ssid);        //print the name of the wifi network
  display.display();        //display the text
  delay(500);        //delay 0.5 seconds
  WiFi.begin(ssid, password);                                                             //start to connect to the wifi network
  display.setCursor(2, 30);                                                               //set the cursor on the display to pixel 2, 10
    while(WiFi.status() != WL_CONNECTED && cursor_place < 52 ){                           //while the arduino isn't connected to the wifi network the cursor_place makes sure it doesn't take too long
      display.setCursor(cursor_place, 25);                                                //set the cursor on the display to pixel 2, 20
      display.print(".");        //print text
      cursor_place = cursor_place + 5;                                                    //change the cursor by 5 pixels
  if(cursor_place >= 52){        //if it took too long to connect to the wifi
    display_error("1W1");        //display the error message
    wifi_connected = false;                                                               //make sure that the wifi_connected variable is set false
  else{
    wifi_connected = true;        //make the variable that indicates if the arduino is connected with wifi true
  if(wifi_connected){        //if the WiFi is connected
    display.print("CONNECTED");                                                           //print text
    display.print("IP-adress:");                                                          //print text
    display.print(WiFi.localIP());                                                        //print the name of the wifi network
    delay(1500);        //delay 1.5 seconds
    display.print("CONTACT TIME SERVER");                                                 //print text
    configTime(3600*timezone,                                                             //configure the timezone
      daysavetime*3600,        //configure the daytime
      "time.nist.gov",        //configure the time
      "0.pool.ntp.org",        //configure the time
      "1.pool.ntp.org");        //configure the time
    delay(200);        //delay 200 milliseconds
    char buffer[30];        //create a string to store the date and time in
    getLocalTime(&tmstruct, 5000);                                                        //get the time
    sprintf(buffer,"%d-%02d-%02d, %02d:%02d:%02d",                                        //store the time in the variable with the right index
      (tmstruct.tm_year)+1900,                                                            //store the year
      ( tmstruct.tm_mon)+1,                                                               //store the month
      tmstruct.tm_mday,        //store the day
      tmstruct.tm_hour ,        //store the hour
      tmstruct.tm_min,        //store the minute
      tmstruct.tm_sec);        //store the second
    display.print("LOCAL TIME:");                                                         //print text
    display.print(String(buffer));                                                        //print the name of the wifi network
  display.setCursor(2, 1);        //set the cursor on the display to pixel 2, 1
  display.setCursor(2, 18);                                                               //set the cursor on the display to pixel 2, 18
  display.print("COMPLETE");                                                              //print text
  delay(1500);        //wait 1.5 seconds
  display.display();        //display the empty screen
  if(WiFi.status() == WL_CONNECTED){
    wifi_connected == true;
  else{
    wifi_connected == false;
  if(Keyboard.isConnected()) {                                                            //if the arduino is connected with BLE
    real_battery = map(analogRead(battery_port), 0, 1023, 0, 100);                        //store the battery level in percentage
    if(real_battery != battery_level){                                                    //if the last sent is not the real battery level
      Keyboard.setBatteryLevel(real_battery);                                             //set the battery level to the correct level
      battery_level = real_battery;                                                       //make the variable the right percentage
    Wire.requestFrom(1, 6);
    I2C_interface_adress = last_read * 10;
    last_read = Wire.read();
    I2C_interface_adress = I2C_interface_adress + last_read;
    if(switch00.get_adress() == I2C_interface_adress){
      switch00.pressed();
    else if(switch01.get_adress() == I2C_interface_adress){
      switch01.pressed();
    else if(switch02.get_adress() == I2C_interface_adress){
      switch02.pressed();
    else if(switch03.get_adress() == I2C_interface_adress){
      switch03.pressed();
    else if(switch10.get_adress() == I2C_interface_adress){
      switch10.pressed();
    else if(switch11.get_adress() == I2C_interface_adress){
      switch11.pressed();
    else if(switch12.get_adress() == I2C_interface_adress){
      switch12.pressed();
    else if(switch13.get_adress() == I2C_interface_adress){
      switch13.pressed();
    else if(switch20.get_adress() == I2C_interface_adress){
      switch20.pressed();
    else if(switch21.get_adress() == I2C_interface_adress){
      switch21.pressed();
    else if(switch22.get_adress() == I2C_interface_adress){
      switch22.pressed();
    else if(switch23.get_adress() == I2C_interface_adress){
      switch23.pressed();
    else if(switch30.get_adress() == I2C_interface_adress){
      switch30.pressed();
    else if(switch31.get_adress() == I2C_interface_adress){
      switch31.pressed();
    else if(switch32.get_adress() == I2C_interface_adress){
      switch32.pressed();
    else if(switch33.get_adress() == I2C_interface_adress){
      switch33.pressed();
    if(wifi_connected){        //if the arduino is connected to a wifi network
      display_time();        //go to the display_time void0x3C
  delay(10);
void display_error(String error_message){                                                 //void to display error messages
  display.setTextSize(4);        //set the text size to 2
  display.print(error_message);                                                           //print the error message
  display.display();        //display the error message
  delay(5000);        //delay 5 seconds
  display.display();        //display the clear display
void display_time(){        //void to display the time
  sprintf(buffer,"%02d:%02d:%02d",                                                        //store the time in the variable with the right index
  display.print(String(buffer));                                                          //print the time
  sprintf(buffer,"%d/%02d/%02d",                                                          //store the time in the variable with the right index
    (tmstruct.tm_mon)+1,        //store the month
    (tmstruct.tm_year)+1900);                                                             //store the year
  display.setCursor(2, 25);                                                               //set the cursor on the display to pixel 2, 20
  display.print(String(buffer));                                                          //print the date
  delay(10);        //delay 10 milliseconds
the code for the ATmega:
#include <Wire.h>
#define chip_adress 1
char interface_adress = 0;
bool pressed = false;
  Wire.begin(1);                                              // join i2c bus with address #8
  Wire.onRequest(requestEvent);                               // register event
  pinMode(0, INPUT);
  pinMode(1, INPUT);
  pinMode(2, INPUT);
  pinMode(3, INPUT);
  pinMode(4, INPUT);
  pinMode(5, INPUT);
  pinMode(6, INPUT);
  pinMode(7, INPUT);
  pinMode(8, INPUT);
  pinMode(9, INPUT);
  pinMode(10, INPUT);
  pinMode(11, INPUT);
  pinMode(12, INPUT);
  pinMode(13, INPUT);
  pinMode(A0, INPUT);
  pinMode(A1, INPUT);
  delay(1);
void requestEvent(){
    for(char i = 0; i > 13; i++){
    if(digitalRead(i) == HIGH){
      pressed = true;
      interface_adress = (10 + i);
    if(pressed == true){
      Wire.write(interface_adress);
  if(analogRead(A0) > 900){
    Wire.beginTransmission(8);
    Wire.write(9712497);
    Wire.endTransmission();
  if(analogRead(A1) > 900){
    Wire.write(9712597);
and the library:
GIP.h
 *  This library is used in an GIP, it is made for these requirements and will not be updated after completion.
#ifndef GIP_h
#define GIP_h
#include "Arduino.h"
#endif
class mechanical_switch{
    public:
        mechanical_switch(char adress);
        void begin(char character1, char character2, char character3, char character4);
        void pressed();
        char get_adress();
    private:
        char _adress;
        char _character1;
        char _character2;
        char _character3;
        char _character4;
class potentio{
    public:
        potentio(char adress);
        void begin( char character1_more,
                    char character2_more,
                    char character3_more,
                    char character4_more,
                    char character1_less,
                    char character2_less,
                    char character3_less,
                    char character4_less);
        void changed(char value);
        char get_adress();
    private:
        char _adress;
        char _character1_more;
        char _character2_more;
        char _character3_more;
        char _character4_more;
        char _character1_less;
        char _character2_less;
        char _character3_less;
        char _character4_less;
        char _value;
        char _percent;
        char _previous;
GIP.cpp:
 * it is important to add the library 'BLECombo' to the main file to ensure the working of the library.
#include "GIP.h"
mechanical_switch::mechanical_switch(char adress){
    _adress = adress;
void mechanical_switch::begin(char character1, char character2, char character3, char character4){
    _character1 = character1;
    _character2 = character2;
    _character3 = character3;
    _character4 = character4;
void mechanical_switch::pressed(){
        Keyboard.press(_character1);
        Keyboard.press(_character2);
        Keyboard.press(_character3);
        Keyboard.press(_character4);
        delay(25);
        Keyboard.releaseAll();
char mechanical_switch::get_adress(){
    return _adress;
potentio::potentio(char adress){
    _adress = adress;
void potentio::begin(char character1_more,
                     char character4_less){
    _character1_more = character1_more;
    _character2_more = character2_more;
    _character3_more = character3_more;
    _character4_more = character4_more;
    _character1_less = character1_less;
    _character2_less = character2_less;
    _character3_less = character3_less;
    _character4_less = character4_less;
void potentio::changed(char value){
    _value = value;
    _percent = map(_value, 0, 255, 0, 100);
    if(_percent < _previous){
        while(_percent != _previous){
            Keyboard.press(_character1_less);
            Keyboard.press(_character2_less);
            Keyboard.press(_character3_less);
            Keyboard.press(_character4_less);
            delay(25);
            _previous--;
    if(_percent > _previous){
            Keyboard.press(_character1_more);
            Keyboard.press(_character2_more);
            Keyboard.press(_character3_more);
            Keyboard.press(_character4_more);
            delay(25);
            _previous++;
char potentio::get_adress(){
    return _adress;
The problem is that if i press a button on the ATMega's port (to make it high), nothing happens. I have tried to visualize the I²C with an osciloscope, but that didn't work really. So I don't know if the ATMega is ever asked to send the results. The display works fine, but the ATMega doesn't. I have tried different things with various results, but this is the program where the most seems to work.
it is a simple circuit:
Is there anybody who knows why this doesn't work? If you have any questions, ask them please. I am doing this for a school project and I need to make some progress.
Thank you.
Siebe
So are you sure 328P is working correctly and at compatible voltage with Esp32?
At any point did you try to just make the I2C part function, that is to say just passing siml,e messages or commands or whatever, but not all boggled up with the other logic?
I would divide and conquer by writing the smallest possible demonstration sketches that show you are working the I2C stuff correctly.
Maybe even a pair of sketches you did not write or mess with that do the I2C only.
a7
  • ESP is 3V3 and Atmega is 5V
Yes the code with the display worked, my library worked and the I2C worked. But now that I am adding them together it doesn't. And it is true that the optimal voltage for an ATMega328P +5V is, but +3.3V works just fine too.
It isn't an Arduino, it is a raw ATMega328P with a crystal oscilator and some capacitors. This circuit has worked before. Every aspect worked before, but if you try to add them together it doesn't.
Sorry for forgetting to tell this.
  • Is the 328 powered by 3v3 or 5v ?
  • Show good images of the actual wiring.
I am sorry, I can't do that right now, but from the moment I can, I will. But the ATMega is powered by 3.3v.
  • Then there is no problem with different voltages.
  • Where are the I2C pull-up resistors, what values are they ?
Post all three sketches that worked. Note any differences in the schematic in effect when you had various parts working. When you post your schematic, that is.
TIA
a7
So it are 5 different PCB's each with a different design and usage, but for now I am focussing between the processor module and the 4x4 mechanical switches. This is the pcb for the processor module, this module doesn't do anything other than analyzing data and sending it through BLE HID to the computer:
and this is the 4x4 mechanical switches, the switches aren't in a matrix so they can be pushed in combination with others switches so that there are more possible outcomes:
and two times this:
this is the pcb it self:
the idea is that the pcb's can be moved but can't be rotated. This drawings are made with fusion electronics, and I will add the PDF files to give clearer images.
pcb processor.pdf (98.4 KB)
pcb mechanical keys.pdf (114.2 KB)
The pull-up resistors are 3k3, and I used the standard Arduino examples for the I²C and display tests. I also did a test with the display and the online clock together, but I didn't save the test and a just built on that to this result. But that worked too. The test were done on a breadboard with exact the same schematic, but the only thing that was unplugged were the display, and in the other test the ATMega. All the other components stayed connected.
Thank you very much for helping.
[EDIT]: In the schematic of the processor module is a whole part about a battery, I didn't use that yet. Because there is some work in progress on that part too. And it isn't really clear, but the 4 dots in the right upper corner of the processor module is the display.
  • It’s quite unlikely your 3v3 Atmega328 will run on a 16MHz crystal, intermittent at best.
  • Are there decoupling capacitors on the 328 ?
It is also not the first time this works, the datasheet says it works just fine, and yes there are 2 22pF ceramic capacitors on the crystal and one 100pF between the +3.3V and the GND.
  • A 3v3 Atmega328 should be clocked with 8MHz
  • Thats’s 100uF ?
I mean pF (pico Farad) sorry, but should that be important? If I understand it right, it isn't even necessary.
And I have seen my own drawings, the capacitors aren't on there. But they are in the real circuit.
That does not correspond with my reading of the 328P datasheet. At 3.3V, the maximum safe clock frequency is a little over 12MHz (figures 29-1 and 31-333). Could you provide references in the datasheet where you have found that 16MHz is achievable at 3.3V?
ATmega48A/PA/88A/PA/168A/PA/328/P Datasheet
References:
  • Must be uF micro farad
  • Wrong.
okay, this is a little embarrassing, I didn't see the 0.
I will try with a smaller clock
I will change it, but if I may ask, why is it important? The Arduino has internal capacitors, so why wouldn't they just add the 100µF to it if it is that important.
But is there anybody with the same problem, because all the things that are wrong in this circuit have worked. So I don't think that's the problem. I will try it, but is there in the meantime anybody else who has a solution?
Why doesn't all manufacturers use internal decoupling caps? Give it a thought or two.
It,s not 100 uF but nF.
0.1 uF = 100 nF.
