SOLVED: ESP-8266 + Blynk: Timer problem
Ignoring 90% of my code - it works as intended...
But when I implement the Blynk timer - the code stops there. Never gets out of setup.
I also tried with the ESP Ticker - but that dies too...!
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
// #include <Ticker.h>
#define topLED	2		// GPIO2 NodeMCU LED - near antenna - input pin is used to select WiFi mode
#define botLED	16	// GPIO16 NodeMCU LED - near USB connector
// used with target_state to reflect the status back to blynk
#define GATE_CLOSED	0
#define GATE_OPEN		1
// motor step count to match open/c.osed positions
#define CLOSED_POSITION 0
#define OPEN_POSITION 1400
#define STEP_FORWARD	HIGH
#define STEP_BACKWARD	LOW
// Ticker stepTimer;
BlynkTimer timer;
unsigned char	target_state = GATE_CLOSED;	// 	assume closed to begin with at reset time
unsigned long currentPosition, targetPosition;
unsigned long prev_stepMS, step_periodMS = 50L;
// EasyDriver Pins
// ESP8266 has very few I/O pins free for user...
const int smEnable = D1; //Driver enable pin
const int smDirection = D2; //Direction pin
const int smStep = D3; //Step pin
unsigned long stepDurationMS = 50L;	// millisecs per half-step phase
int pinData;
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "token"; //MC TEST
// Your local WiFi credentials.for the ESP/Blynk server
// Set password to "" for open networks.
char ssid[] = "SSID";
char pass[] = "passphrase";
	// pinMode (topLED, OUTPUT);
	// pinMode (botLED, OUTPUT);
	pinMode(smDirection, OUTPUT);
  pinMode(smStep, OUTPUT);
  pinMode(smEnable, OUTPUT);
  digitalWrite(smEnable, HIGH);
	Serial.begin(115200);		// <<<<< ==== use this value in serial terminal etc..
	delay(100);
  Serial.println("\nStarting...\nwait for Wifi & Blynk server");
  Blynk.begin(auth, ssid, pass); // can take several seconds
	// digitalWrite(botLED, 0); // note the LED is inverted
	Serial.println(F("Connected - the Blynk server is alive!"));
	prev_stepMS = millis();
// timer.setInterval(stepDurationMS, moveStepper);
	// We don't know where the motor is parked...
	// so all movements will be relative to the initial position
	// until some sort of end stop or calibration is available,
	Blynk.run();
	// timer.run();	// moveStepper();
						// take care to accommodate reversing the
						// target motor if it is still running
						// in the opposite direction
						// We could #define the virtual pin numbers to be more readable
						// - but they still have to match the vPin assignments in the BLYNK app
BLYNK_WRITE(V0) { //momentary button Widget is writing to pin V0
  pinData = param.asInt();
	if (pinData) {	// pin has been set to '1'
		Serial.println(F("CLOSE THE GATES"));
	// target_state = GATE_CLOSED;
	targetPosition = CLOSED_POSITION;
BLYNK_WRITE(V1) { //momentary button Widget is writing to pin V1
		Serial.println(F("OPEN THE GATES"));
	// target_state = GATE_OPEN;
	targetPosition = OPEN_POSITION;
BLYNK_WRITE(V2) { // button Widget is writing to pin V2
	target_state = pinData; // !target_state;
	Serial.print(F("TOGGLE GATES TO "));
	if (target_state == GATE_OPEN) {
		Serial.println(F("OPENING STATE"));
		Serial.println(F("CLOSING STATE"));
void moveStepper() {
	static bool stepPhase = 0;	// alternates 0/1
	if (targetPosition != currentPosition) {	// we have somewhere to go...
		if (millis() - prev_stepMS > step_periodMS) {  // the time is right for a step
			// until some sort of end-stop or calibration is available,
			// the motor & position are driven until targetPosition == currentPosition
			if (targetPosition > currentPosition)	{ // choose forward por reverse
				digitalWrite(smDirection, STEP_FORWARD);
				currentPosition++;
				Serial.write('+');
					digitalWrite(smDirection, STEP_BACKWARD);
					currentPosition--;
					Serial.write('-');
			stepPhase = !stepPhase;	// the step pulse swaps every step_periodMS
			digitalWrite(smStep, stepPhase);	// toggle the step pulse
		if ((targetPosition == OPEN_POSITION) && (target_state != GATE_OPEN)) {
			Serial.println(F("|open"));
		} else if ((targetPosition == CLOSED_POSITION) && (target_state != GATE_CLOSED)) {
			Serial.println(F("|closed"));
The offending line is
If that's commented out - the code runs fine, but as soon as it's in-line - the setup dies - in that function ?
The other timer lines are commented out - because the above line defines the timer parameters.
Thanks for any thoughts
I use the ESP32. I was using ESP32servo and hardware timer 0. ESP32servo allows the ESP32 API to select a hardware timer instead of assigning a hardware timer. Your issues reads similar to the timer issue I was having. The ESP32 API was assigning hardware timer 0 to servo channel 0. I switched to using the ESP32 PWM API for servo control, that way I can directly assign a servo to a hardware timer and reserve a hardware timer for other thing do's.
SOLVED - sort of...
The Blynk Community did some digging, and noted there is a problem with the current ESP core 2.5.0
So they tested, and suggested I drop back to core 2.4.2
Problem solved. Sort of !
