I´m struggeling with a "simple" problem for hours now.
I have an incoming const char * (message.data), f.e. F9BF69, or 020581, whatever. Want to translate it to an decimal red green and blue value in the end. Problem seems to be the missing 0x, so I am not able to just cast it to an int.
Idea was now to create single chars for 0, x and two chars of my 6er const *, some examples.:
None of this worked. I am getting strange numbers when casting to String (maybe ASCII ?), and have not found a way to get my hex out of there. Also played with strdup and then atoi or strtoi, or first cast to String - no solution.
int asciiHexToInt(char c) {
int x = 0;
if (c >= "0" && c <= "9") x += c - "0";
else if (c >= "A" && c <= "F") x += c - "A";
return x;
The only problem here is if 0x or 0X is sent, it will be evaluated as an INT but it should return 0 for each character, so it ultimately should work on the entire string...
int x = 0;
return x;
Perfect point to start from, thank you very much
Much better then first put chars together.
As it is RGB, i had to always put two of em together, if someone else has a similar problem (this is only for 3x2 hex values ):
for (byte aP = 0; aP < 6;)
byte x = 0;
for (byte r = 0; r < 2; ++r)
byte mult = 0;
switch (message.data[aP]) {
case 'A':
mult = 10;
case 'B':
mult = 11;
case 'C':
mult = 12;
case 'D':
mult = 13;
case 'E':
mult = 14;
case 'F':
mult = 15;
default:
mult = message.data[aP] - '0';
if (r == 0) x = mult * 16;
else x += mult;
++aP;
switch (aP)
case 2:
redNext = x;
case 4:
greenNext = x;
case 6:
blueNext = x;
