So, i implemented the method Grumpy_Mike suggested and i got a little bit of a problem. When i press a certain key ("41" which is "(char) 0" in the keys[][] declaration) and hold it i get the RELEASE state (noteOn) message a few more times as i press other keys, then it settles down and doesn't appear again.
In the old code, the one with the "switch" statement it didn't do that. There's something off and i don't know what. I increased the debounce time but nothing changed.
//old
#include <Keypad.h>
bool debug = true;
const byte ROWS = 4; //four rows
const byte COLS = 8; //three columns
char keys[ROWS][COLS] = {
{'1','2','3','4','5','6','7','8'},
{'q','w','e','r','t','y','u','i'},
{'a','s','d','f','g','h','j','k'},
{'z','x','c','v','b','n','m',','}
byte rowPins[ROWS] = {10, 11, 12, 13}; //connect to the row pinouts of the kpd
byte colPins[COLS] = {2, 3, 4, 5, 6, 7, 8, 9}; //connect to the column pinouts of the kpd
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
unsigned long loopCount;
unsigned long startTime;
String msg;
byte cmd, note = 55, velocity = 100;
byte shift = 41;
Serial.begin(38400);
//kpd.setDebounceTime(300);
// Fills kpd.key[ ] array with up-to 10 active keys.
// Returns true if there are ANY active keys.
if (kpd.getKeys())
for (int i=0; i<LIST_MAX; i++) // Scan the whole key list.
if ( kpd.key[i].stateChanged ) // Only find keys that have changed state.
if (kpd.key[i].kstate == PRESSED) cmd = 144;
else if (kpd.key[i].kstate == RELEASED) cmd = 128;
switch ( kpd.key[i].kchar ){
case '1': note = 0 + shift; break; //not used
case '2': note = 0 + shift; break; //not used
case '3': note = 0 + shift; break; //not used
case '4': note = 0 + shift; break; //not used
case '5': note = 0 + shift; break; //not used
case '6': note = 0 + shift; break; //not used
case '7': note = 0 + shift; break; //not used
case '8': note = 24 + shift; break;
case 'q': note = 16 + shift; break;
case 'w': note = 17 + shift; break;
case 'e': note = 18 + shift; break;
case 'r': note = 19 + shift; break;
case 't': note = 20 + shift; break;
case 'y': note = 21 + shift; break;
case 'u': note = 22 + shift; break;
case 'i': note = 23 + shift; break; //ok
case 'a': note = 8 + shift; break;
case 's': note = 9 + shift; break;
case 'd': note = 10 + shift; break;
case 'f': note = 11 + shift; break;
case 'g': note = 12 + shift; break;
case 'h': note = 13 + shift; break;
case 'j': note = 14 + shift; break;
case 'k': note = 15 + shift; break; //ok
case 'z': note = 0 + shift; break;
case 'x': note = 1 + shift; break;
case 'c': note = 2 + shift; break;
case 'v': note = 3 + shift; break;
case 'b': note = 4 + shift; break;
case 'n': note = 5 + shift; break;
case 'm': note = 6 + shift; break;
case ',': note = 7 + shift; //ok
if ( kpd.key[i].kstate == PRESSED || kpd.key[i].kstate == RELEASED ){ // avoids HOLD and IDLE state wich produces additional message. TREBUIE SA INCLUDA "SWITCH" PENTRU A ECONOMISI RESURSE
if (debug) {
Serial.print(cmd);
Serial.print("__");
Serial.println(note);
else {
Serial.write(cmd);
Serial.write(note);
Serial.write(velocity);
} // End loop
//new
#include <Keypad.h>
bool debug = true;
{(char)66,(char)66,(char)66,(char)66,(char)66,(char)66,(char)66,(char)24},
{(char)16,(char)17,(char)18,(char)19,(char)20,(char)21,(char)22,(char)23},
{(char) 8,(char) 9,(char)10,(char)11,(char)12,(char)13,(char)14,(char)15},
{(char) 0,(char) 1,(char) 2,(char) 3,(char) 4,(char) 5,(char) 6,(char) 7}
byte shift = 41;
kpd.setDebounceTime(30);
if (kpd.getKeys())
if ( kpd.key[i].stateChanged ) { // Only find keys that have changed state.
note = shift + (byte) kpd.key[i].kchar;
if (debug) {
Serial.print(cmd);
Serial.print("__");
else {
Serial.write(cmd);
Serial.write(note);
} // End loop
