I tried to modify the colorshield lib from Colorduino Library for Arduino – Lincomatic's DIY Blog to work with the Leonardo but I didn't get the part from the void TC to work. I tried some coding but I lost my Board often. I think the Timer/Counter 4 is connectet with the USB Interface sometimes the PC can't remember what it is so I have to burn the Bootloader again. There is my code.
Colorduino - Colorduino Library for Arduino
Copyright (c) 2011-2012 Sam C. Lin <lincomatic@hotmail.com>
based on C code by zzy@iteadstudio...
#ifndef _COLORDUINO_H_
#define _COLORDUINO_H_
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
#include <avr/pgmspace.h>
#include <avr/io.h>
#include <avr/interrupt.h>
#define ColorduinoBitsPerColor 8
#define ColorduinoScreenWidth 8
#define ColorduinoScreenHeight 8
define the IO
//#define RST_BIT 0x04
//#define LAT_BIT 0x02
//#define SLB_BIT 0x01
//#define SCL_BIT 0x40
//#define SDA_BIT 0x80
#define RST_BIT digitalPinToBitMask(A2)
#define LAT_BIT digitalPinToBitMask(A1)
#define SLB_BIT digitalPinToBitMask(A0)
#define SCL_BIT digitalPinToBitMask(6)
#define SDA_BIT digitalPinToBitMask(7)
//#define RST PORTC
//#define LAT PORTC
//#define SLB PORTC
//#define SCL PORTD
//#define SDA PORTD
#define RST* portOutputRegister(digitalPinToPort(A0))
#define LAT* portOutputRegister(digitalPinToPort(A1))
#define SLB* portOutputRegister(digitalPinToPort(A2))
#define SCL* portOutputRegister(digitalPinToPort(6))
#define SDA* portOutputRegister(digitalPinToPort(7))
//#define open_line0 {PORTB=0x01;}
//#define open_line1 {PORTB=0x02;}
//#define open_line2 {PORTB=0x04;}
//#define open_line3 {PORTB=0x08;}
//#define open_line4 {PORTB=0x10;}
//#define open_line5 {PORTB=0x20;}
//#define open_line6 {PORTD=0x08;}
//#define open_line7 {PORTD=0x10;}
//#define close_all_lines {PORTD=0x00;PORTB=0x00;}
#define open_line0 {*portOutputRegister(digitalPinToPort(8))=digitalPinToBitMask(8);}
#define open_line1 {*portOutputRegister(digitalPinToPort(9))=digitalPinToBitMask(9);}
#define open_line2 {*portOutputRegister(digitalPinToPort(10))=digitalPinToBitMask(10);}
#define open_line3 {*portOutputRegister(digitalPinToPort(11))=digitalPinToBitMask(11);}
#define open_line4 {*portOutputRegister(digitalPinToPort(12))=digitalPinToBitMask(12);}
#define open_line5 {*portOutputRegister(digitalPinToPort(13))=digitalPinToBitMask(13);}
#define open_line6 {*portOutputRegister(digitalPinToPort(3))=digitalPinToBitMask(3);}
#define open_line7 {*portOutputRegister(digitalPinToPort(4))=digitalPinToBitMask(4);}
#if defined (__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
#define close_all_lines {PORTB&=0b00001111;PORTG&=0b11101111;PORTE&=0b11101111;PORTH&=0b11001111;}
#elif defined(__AVR_ATmega32U4__)
#define close_all_lines {PORTB&=0b00001111;PORTC&=0b01111111;PORTD&=0b11101110;}
#else
#define close_all_lines {PORTB&=0b11000000;PORTD&=0b11000000;}
#endif
#define LED_RST_SET RST|=RST_BIT
#define LED_RST_CLR RST&=~RST_BIT
#define LED_SDA_SET SDA|=SDA_BIT
#define LED_SDA_CLR SDA&=~SDA_BIT
#define LED_SCL_SET SCL|=SCL_BIT
#define LED_SCL_CLR SCL&=~SCL_BIT
#define LED_LAT_SET LAT|=LAT_BIT
#define LED_LAT_CLR LAT&=~LAT_BIT
#define LED_SLB_SET SLB|=SLB_BIT
#define LED_SLB_CLR SLB&=~SLB_BIT
typedef struct pixelRGB {
unsigned char r;
unsigned char g;
unsigned char b;
} PixelRGB;
class ColorduinoObject {
public:
PixelRGB frameBuffer0[ColorduinoScreenWidth*ColorduinoScreenHeight];
PixelRGB frameBuffer1[ColorduinoScreenWidth*ColorduinoScreenHeight];
PixelRGB *curDrawFrame;
PixelRGB *curWriteFrame;
unsigned char line;
ColorduinoObject() {
line = 0;
curWriteFrame = frameBuffer0;
curDrawFrame = frameBuffer1;
void _IO_Init()
//DDRD = 0xff; // set all pins direction of PortD
//DDRC = 0xff; // set all pins direction of PortC
//DDRB = 0xff; // set all pins direction of PortB
//PORTD = 0x00; // set all pins output is low of PortD
//PORTC = 0x00; // set all pins output is low of PortC
//PORTB = 0x00; // set all pins output is low of PortB
uint8_t lines[] = {A0,A1,A2,3,4,6,7,8,9,10,11,12,13};
for(int i = 0; i < 13;i++){
pinMode(lines[i],OUTPUT);
digitalWrite(lines[i],LOW);
void LED_Delay(unsigned char i);
void SetWhiteBal(unsigned char wbval[3]);
void _LED_Init()
LED_RST_SET;
LED_Delay(1);
LED_RST_CLR;
LED_Delay(1);
LED_RST_SET;
LED_Delay(1);
line = 0;
void _TC2_Init()
// Arduino runs at 16 Mhz...
// Timer Settings, for the Timer Control Register etc. , thank you internets. ATmega168 !
// Timer2 (8bit) Settings:
// prescaler (frequency divider) values: CS22 CS21 CS20
// 0 0 0 stopped
// 0 0 1 /1
// 0 1 0 /8
// 0 1 1 /32
// 1 0 0 /64
// 1 0 1 /128
// 1 1 0 /256
// 1 1 1 /1024
// TCNT2 increments every = 16MHz / prescaler
TCCR2B = 0x00; // Disable timer while configuring
TCCR2A = 0x00; // Use normal mode
TIMSK2 = 0x01; // Timer2 overflow interrupt enable
TCNT2 = 0xff; // Reset timer to count of 255
TCCR2B = 0x05; // Prescaler = 128
// set prescaler to 128 -> TCNT2 freq = 125KHz
TCCR4B |= (1<<CS43);
TCCR4B &= ~((1<<CS42)|(1<<CS41)|(1<<CS40));
// TCCR4C &= ~(1<<PWM4D);
// TCCR4D &= ~((1<<WGM41)|(1<<WGM40)); // Use normal mode
TCCR4A &= ~((1<<COM4A1)|(1<<COM4A0)); // Use normal mode
// ASSR |= (1<<AS2); // Use internal clock - external clock not used in Arduino
// TIMSK4 |= (1<<TOIE4); //Timer4D Overflow Interrupt Enable
TIFR4 |= (1<<TOV4);
TCNT4 = 0xff;
#else
TCCR2B |= ((1<<CS22)|(1<<CS20));
TCCR2B &= ~((1<<CS21));
TCCR2A &= ~((1<<WGM21) | (1<<WGM20)); // Use normal mode
TIMSK2 |= ((1<<TOIE2) | (0<<OCIE2B)); //Timer2 Overflow Interrupt Enable
TCNT2 = 0xff;
#endif
sei();
void open_line(unsigned char x)
switch (x)
case 0 :open_line0;
case 1 :open_line1;
case 2 :open_line2;
case 3 :open_line3;
case 4 :open_line4;
case 5 :open_line5;
case 6 :open_line6;
case 7 :open_line7;
default: close_all_lines;
void Init() {
_IO_Init(); //Init IO
_LED_Init(); //Init LED Hardware
_TC2_Init(); //Init Timer/Count2
void FlipPage() {
cli();
// swap frame buffers
PixelRGB *tmp = curDrawFrame;
curDrawFrame = curWriteFrame;
curWriteFrame = tmp;
sei();
// get a pixel for writing in the offscreen framebuffer
PixelRGB *GetPixel(unsigned char x,unsigned char y) {
return curWriteFrame + (y * ColorduinoScreenWidth) + x;
// get a pixel from the active framebuffer
PixelRGB *GetDrawPixel(unsigned char x,unsigned char y) {
return curDrawFrame + (y * ColorduinoScreenWidth) + x;
// set a pixel in the offscreen frame buffer
void SetPixel(unsigned char x, unsigned char y, unsigned char r, unsigned char g, unsigned char b)
PixelRGB *p = GetPixel(x,y);
p->r = r;
p->g = g;
p->b = b;
void run();
extern ColorduinoObject Colorduino;
#endif // _COLORDUINO_H_
Inserting the Arduino Mega parts vom Akto.
Did someone know how to use Timer/Counter4 right?
The Code below show some of my tests with several registers around the PLL and the possible frequences I get.
pinMode(6,OUTPUT);
analogWrite(6,127);
TCCR4E = 0x0;
TCCR4D = 0x0;
TCCR4B = 0b000001;
// PLLFRQ = 0b00000100; //62kHz
// PLLFRQ = 0b00100100; //125kHz
// PLLFRQ = 0b01101010; //250kHz
PLLFRQ = 0b01011010; //375kHz
void loop() {}
BTW. I make no changes on the ISR(TIMER2_OVF_vect)
