[SOLVED] Negative result using dtostrf()
Im having problems on why is my float result are Negative. Here is my code along with the screenshoot of the problem.
  int mA = ACS.mA_AC(); //ACS712 Current
  float Watt = (220*mA)/1000;
  char daya[6];
  dtostrf(Watt, 4, 2, daya);
  sprintf(myStr, "ACS Current(mA)= %d. Watt Usage(W)= %s", mA, daya);
  Serial.println("Sending to Antares... ");
  Serial.println(myStr);
  lora.sendUplink(myStr, strlen(myStr), mA);
Thank you in advance.
Integer arithmetic overflowing - try
are you sure your current isn't negative (swap the probes
ACS Current(mA)= 100. Watt Usage(W)= 22.00
ACS Current(mA)= -150. Watt Usage(W)= -33.00
void
pr (
    float mA )
    char myStr [80];
    char daya  [6];
    sprintf(myStr, "ACS Current(mA)= %d. Watt Usage(W)= %s", int(mA), daya);
    Serial.println (myStr);
void setup ()
    Serial.begin (9600);
    pr (100.);
    pr (-150.);
void loop ()
The values are consistent with sixteen bit signed integer arithmetic overflow.
right, thanks
It works. Thank you so much!
1. Have you realized why did you get -25.00 in post #1 and why are you getting expected result using the following floating point arithmetic of Step-2:
2.
3. If you don't want fractional part of the result, you can use the following integer arithmetic:
int mA = 180;//ACS.mA_AC(); //ACS712 Current
unsigned long Watt = (220ul * mA) / 1000ul;  //ul for unsigned long (32-bit)
Serial.println(Watt);
