Greetings fellow hackers,
I have been spending the past few days attempting to construct a "BASIC pocket computer", like the one Ben Heck made in this video:
I'm making the computer out of an Arduino Uno, a 360 chatpad and an lcd display. I am currently working on editing the original TinyBasicPlus program to accommodate this hardware. I've re-flashed the chip on the 360 chatpad to output standard ascii and have written some code to get it working perfectly with the lcd, alas, when I try to implement this code into the TinyBasicPlus program, I run into problems. As in the video I have redirected the "outchar" function to the "lcdchar" and "doFrame" functions that I have written. I have also imported the LiquidCyrstal library, declared my variables and setup the serial baud rate and lcd settings.
The problem is when I upload the code and plug everything in, instead of getting "TinyBasic V.x xxxx bytes free" I get lines 0 and 2 of the lcd flickering with no text and I get no input from the chatpad.
The manufacturing number of the lcd is FDCC2004B-RNNYBW-66SE. Here is a link to the datasheet.
I've connected up the lcd like in this picture
I've connected the chatpad to 3.3v and ground and I've connected the write line to the arduino's read io
This is a link to the TinyBasicPlus github page
Here is the full TinyBasicPlus code along with my alterations and
This is just the code that I wrote to get the keyboard working with the lcd
When I use the original code and don't hook up anything to the Arduino It works fine on the serial terminal, but the funny thing is that when I use my code for TinyBasicPlus with the alterations, even when I set the code back to Serial.write(c); but leave the alterations in, I don't get anything up at all on the serial monitor.
Any input would be appreciated.
Thanks in advance,
FactualOrc
