Hi
I'm new at this and wanted to get startet with some lights....
So I have a Nano and a 12 bit nanopixel ring.
I can set the ring to any colors I want. Make them move around and got the basics.
But I wanted to clean up the code and there for I defined a few colors
#define PIN 6
int ArrayLength;
// Parameter 1 = number of pixels in strip
// Parameter 2 = pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(12, PIN, NEO_GRB + NEO_KHZ800);// Define colors
uint32_t black = strip.Color(0, 0, 0);
uint32_t red = strip.Color(255, 0, 0);
uint32_t green = strip.Color(0, 255, 0);
uint32_t blue = strip.Color(0, 0, 255);
uint32_t yellow = strip.Color(255, 255, 0);
uint32_t aqua = strip.Color(0, 255, 255);
uint32_t magenta = strip.Color(255, 0, 255);
uint32_t white = strip.Color(255, 255, 255);
And a Array with the colors:
//Define color array
int ColorArray[] = {black, red, green, blue, yellow, aqua, magenta, white};
And ofcause some code to use it:
strip.begin();
strip.show(); // Initialize all pixels to 'off'
}void loop() {
for (ArrayLength = 0; ArrayLength < 8; ArrayLength = ArrayLength + 1) {
NEOcounter = 11;
ColorloopCounter();
}void ColorloopCounter() {
do {
strip.setPixelColor(NEOcounter, ColorArray[ArrayLength]);
strip.show();
--NEOcounter;
while (NEOcounter >= 0);
And it works but never shows RED. Colors containing RED are showed but without the red element. And for RED that is the same as no light.
I've tried:
strip.setPixelColor(NEOcounter, ColorArray[1]);
And it dosn't work.
But
//strip.setPixelColor(NEOcounter, red);
Does work.
All colors not containing a RED element does display correctly.
What am I doing wrong.
It's as if the first value of the uint32_t red = strip.Color(255, 0, 0); declaration is set to 0.
Kind regards Jgaard
