I am creating a controller for a football play clock. When the controller is first powered up, I want it to send a command, Serial.print() 5 times in succession. Most of the rest of the code is unwritten, but I am getting a puzzling error in my code so far… Here is the code…
byte ReadyForPlayTime = 25;// constant, default delay of game time
byte TimeOutTime = 40;// constant, default time out time
for (byte i; i < 5; i++) {
printPlayclockCommand("PD", ReadyForPlayTime);
void printPlayclockCommand(char command[3], byte timerTime) {
char secondsTens = (timerTime / 10) + 48;
char secondsOnes = (timerTime % 10) + 48;
char centiseconds;
if (timerTime >= 1) centiseconds = 148;
else centiseconds = 48;
Serial.print(command);
Serial.print(secondsTens);
Serial.print(secondsOnes);
Serial.print(centiseconds);
I get no output when powered up… However, if I add 2 more lines of code as follows… just to test my serial is working…
char cMD[3] = "PX";
Serial.print(cMD);
char centiseconds;
I get “PXPD25”PD25”PD25”PD25”PD25””… Exactly what I want, without the PX…
Is it a delay thing? I’ve added delay, which doesn’t fix it. Is it an if or while statement? This is on an ATmega328P, running at 16 MHz, similar enough to the UNO.
PaulS:
Which Arduino are you running this code on?
It's an Atmega328P, barebones, with a 16MHz crystal, simple Pierce oscillator to be clear, 2 18pF caps and 1 MOhm resistor... , a pull-up resistor on /reset with decoupling cap, decoupling caps on VCC, AVCC and AREF, and grounding on GND pins. Pin 3, TX is taken through a MAX3232 with proper pump caps, decoupling and grounding, all powered at 3.3 Volts DC...
PaulS:
Just out of curiosity, does adding a small delay() between begin() and the function call accomplish anything?
No. I've tried delay, referencing, dereferencing, printing "" first... I'm either going to print PC or PD, so maybe I just pass it a boolean and have it evaluate the boolean and print the appropriate string literal...
Crank you warning level up to ALL. That would point you right at the mistake:
warning: ‘i’ may be used uninitialized in this function
/Users/john/Library/Arduino15/packages/arduino/hardware/avr/1.6.21/cores/arduino/main.cpp: In function 'main':
/Users/john/Documents/Arduino/sketch_may31a/sketch_may31a.ino:6:3: warning: 'i' may be used uninitialized in this function [-Wmaybe-uninitialized]
/Users/john/Documents/Arduino/sketch_may31a/sketch_may31a.ino:6:13: note: 'i' was declared here
Sketch uses 3708 bytes (12%) of program storage space. Maximum is 28672 bytes.
Global variables use 151 bytes (5%) of dynamic memory, leaving 2409 bytes for local variables. Maximum is 2560 bytes.
cattledog:
What is the explanation for the fact that adding
char cMD[3] = "PX";
Serial.print(cMD);
somehow initialized i in the following for loop?
I can only postulate that i was assigned a place in memory with whatever value there, possibly above or equal to 5, causing the loop to never execute even once...
adding those two lines, by circumstance, caused i to be assigned to a place in memory where the value just happened to be 0...
cattledog:
char cMD[3] = "PX";
Serial.print(cMD);
No. i was always initialised but its value was not specified so was allocated a value from the memory location that the variable was located at. Adding more code changed the memory location used by i and hence its initial value.
Out of interest try
for (static byte i; i < 5; i++)
static variables are initialised to zero if not initialised to a specific value.
