[SOLVED] Servo logic not working
Hi! So for some reason, my "Claw" servo is not working as intended. I have already tested the servo and it works, it just trips up over the logic. Just some background, the Arduino is supposed to take a code and deconstruct the string in order to control a motor/servo. For example, ""; "<" and ">" signify the start and end of the message. The "B" tells the program which motor/servo to control, and the "200" signifies the speed/mapping of the servo/motor. The reason this is necessary is that I have a Processing code running in the background taking inputs from my controller and sending mapping data over the Serial port. The "Claw" servo seems to work at the beginning where I map it so that it does not stall at the close, but completely stops working after that. Does anyone have any idea why that might be? Any help would be appreciated.
Main Code:
#include <Wire.h>
#include <Servo.h>
#include <Adafruit_MotorShield.h>
//set up motorhsield
Adafruit_MotorShield AFMS = Adafruit_MotorShield(0x60);
//assign motors
Adafruit_DCMotor *RailMotor = AFMS.getMotor(1);
Adafruit_DCMotor *Swivel = AFMS.getMotor(2);
Adafruit_DCMotor *Screw = AFMS.getMotor(3);
//call the servo library
Servo DrillArm, ClawArm, Claw, Elbow;
const byte number_of_chars = 32;
char receivedChars[number_of_chars];
boolean new_data = false;
  // create with the default frequency 1.6KHz
  AFMS.begin();
  // Attach a servo to pin #10 and pin #9
  DrillArm.attach(11);
  ClawArm.attach(10);
  Claw.attach(9);
  Elbow.attach(12);
  Claw.write(map(75, 0, 180, 0, 180));//prevent servo from stalling
  receivePacket();
  if (new_data == true) {
    parseData();
    executeParsedData();
    new_data = false;
    Serial.println(receivedChars);
    char buf[4] = {receivedChars[1], receivedChars[2], receivedChars[3], receivedChars[4]};
    int mapp = atoi(buf);
    Serial.println(mapp);
    if (receivedChars[0] == 'A'){ //claw arm control
      ClawArm.write(map(mapp, 0, 180, 0, 180));
    else if(receivedChars[0] == 'B'){ //elbow control
      Elbow.write(map(mapp, 0, 180, 0, 180));
    else if(receivedChars[0] == 'C'){ //claw open or close
      Claw.write(map(mapp, 0, 180, 0, 180));
    else if(receivedChars[0] == 'D'){ //drill arm control
      DrillArm.write(map(mapp, 0, 180, 0, 180));
    else if(receivedChars[0] == 'E'){ //rail control
      if (mapp > 20){
        RailMotor->setSpeed(mapp);
        RailMotor->run(FORWARD);
      else if (mapp < -20){
        RailMotor->setSpeed(abs(mapp));
        RailMotor->run(BACKWARD);
      else {
        RailMotor->run(RELEASE);
    else if(receivedChars[0] == 'F'){ //swivel control
      if (mapp > 15){
        Swivel->setSpeed(mapp);
        Swivel->run(FORWARD);
      else if (mapp < -15){
        Swivel->setSpeed(abs(mapp));
        Swivel->run(BACKWARD);
      else {
        Swivel->run(RELEASE);
    else if(receivedChars[0] == 'G'){ //screw control
      if (mapp > 15){
        Screw->setSpeed(mapp);
        Screw->run(FORWARD);
        Screw->setSpeed(abs(mapp));
        Screw->run(BACKWARD);
      else {
        Screw->run(RELEASE);
2nd Tab:
#include <SoftwareSerial.h>
#include <Wire.h>
//SoftwareSerial mySerial(11, 12); // RX, TX
int red_led = 3;
int green_led = 6;
int blue_led = 5;
int int_1 = 0;
int int_2 = 0;
int int_3 = 0;
void receivePacket() {
  static boolean receiving = false;
  static byte index = 0;
  char start_mark = '<';
  char end_mark = '>';
  char rc;
  while (Serial.available() > 0 && new_data == false) {
    rc = Serial.read();
    if (receiving == true) {
      if (rc != end_mark) {
        receivedChars[index] = rc;
        index++;
        if (index >= number_of_chars) {
          index = number_of_chars-1;
        receivedChars[index] = '\0';
        receiving = false;
        index = 0;
        new_data = true;
    } else if (rc == start_mark) {
      receiving = true;
void parseData() {
  char * split;
  split = strtok(receivedChars, ",");
  int_1 = atoi(split);
  split = strtok(NULL, ",");
  int_2 = atoi(split);
  int_3 = atoi(split);
void executeParsedData() {
  if (int_3 == 0) {
    analogWrite(red_led, 0);
    analogWrite(green_led, 0);
    analogWrite(blue_led, 0);
  } else if (int_3 == 1) {
    analogWrite(red_led, 255);
    analogWrite(green_led, 255);
    analogWrite(blue_led, 255);
  } else if (int_3 == 2) {
    if (int_2 == 0) analogWrite(red_led, int_1);
    if (int_2 == 1) analogWrite(green_led, int_1);
    if (int_2 == 2) analogWrite(blue_led, int_1);
You reset the position of the Claw servo to the same place each time through loop() so no wonder it never moves far under your control
From the map reference:
`y = map(x, 1, 50, 50, 1);
Syntax
map(value, fromLow, fromHigh, toLow, toHigh)
Parameters
value: the number to map.
fromLow: the lower bound of the value’s current range.
fromHigh: the upper bound of the value’s current range.
toLow: the lower bound of the value’s target range.
toHigh: the upper bound of the value’s target range.`
The first argument is the destination variable. Is 75 a variable name?
What sense does it make to map 0 - 180 to 0 - 180
I mainly have it there because the example Arduino Code for the Motor Shield included code like this. If that's the case, I can just remove it.
