SOLVED - Setpoint Issues - PID Position Control of DC Motor
Hello,
I'm currently facing an issue with trying to perform PID position control of a DC motor. The PID loop can in fact be succesfully tuned, however the setpoint of 90° that the code sees is not 90° in reality. Using debugging, the program does oscillate the motor around the setpoint, however if the shaft is manually forced in another position, it reads this new location as 90°. The encoder has been tested without PID control in a separate program, and is confirmed to be working without issues. Is there some interaction with encoders and PID control I am not aware of? I am using a DC motor with the Arduino Uno Board, code is attached below. Thank you all for any help.
#define ENCA 2 // YELLOW
#define ENCB 3 // WHITE
#define PWM 9
#define IN2 7
#define IN1 6
int pos = 0;
long prevT = 0;
float eprev = 0;
float eintegral = 0;
float degree1 = 0;
  pinMode(ENCA,INPUT);
  pinMode(ENCB,INPUT);
  attachInterrupt(digitalPinToInterrupt(ENCA),readEncoder,RISING);
  Serial.println("target pos e");
  // set target position
  int target = 90.0;
  //target = 250*sin(prevT/1e6);
  // PID constants
  float kp = 100.0;
  float kd = 1.0;
  float ki = 0.0;
  // time difference
  long currT = micros();
  float deltaT = ((float) (currT - prevT))/( 1.0e6 );
  prevT = currT;
  degree1 = (pos/1000.00)*360.0;
  // error
  float e = pos-target;
  // derivative
  float dedt = (e-eprev)/(deltaT);
  // integral
  eintegral = eintegral + e*deltaT;
  // control signal
  float u = kp*e + kd*dedt + ki*eintegral;
  // motor power
  float pwr = fabs(u);
  if( pwr > 255 ){
    pwr = 255;
  // motor direction
  int dir = 1;
  if(u<0){
    dir = -1;
  // signal the motor
  setMotor(dir,pwr,PWM,IN1,IN2);
  // store previous error
  eprev = e;
  Serial.print(target);
  Serial.print(" ");
  Serial.print(pos);
  Serial.print(" ");
  Serial.print(e);
void setMotor(int dir, int pwmVal, int pwm, int in1, int in2){
  analogWrite(pwm,pwmVal);
  if(dir == 1){
    digitalWrite(in1,HIGH);
    digitalWrite(in2,LOW);
  else if(dir == -1){
    digitalWrite(in1,LOW);
    digitalWrite(in2,HIGH);
  else{
void readEncoder(){
  int b = digitalRead(ENCB);
  if(b > 0){
    pos++;
  else{
    pos--;
Wherever the encoder is pointing when the sketch starts up is Position Zero. Your 'target' (setpoint?) is 90 steps from there. I'm guessing that there are not 360 encoder steps per revolution so I don't know what the angle is between the starting point and the 'target'.
Thanks for the response, it's already solved. It was a simple variable name issue.
