To give some sort of context, I am essentially looking to store large(ish) numbers on an RFID tag (Mifare classic 1kb) and understand I need to split the numbers I have, into bytes so they can then be written to the RFID tag. Equally, I will want to read this number from the RFID tag and therefore I need to rebuild the number I had split (I am aware that the Mifare cards store their bytes as Hex).
To achieve this I have been scouring the forums and other parts of the internet to get the answer, however after thinking I'd cracked it, I've come up short.
I have, what I believe is a 32 bit number as a 'long' data type, with a maximum number of 2,147,483,647 (I'm only interested in it being in the positive).
I split this into 4 separate bytes, by using Bit shift/wise operators. I print these to see the values in Binary.
I then try to 'rebuild' the original number by using bitwise 'OR' operators.
Below is a short bit of code that I have been using to try and test the splitting and rebuilding of numbers:
long num = 2147483643;
Serial.println(num, DEC);
Serial.println(num, BIN);
byte b1 = (num >> 24);
byte b2 = (num >> 16);
byte b3 = (num >> 8);
byte b4 = (num);
Serial.println(b1,BIN);
Serial.println(b2,BIN);
Serial.println(b3,BIN);
Serial.println(b4,BIN);
Serial.println("rebuilding below");
//Start rebuilding number from bytes above
long numRebuild = (b1<<24)|(b2<<16)|(b3<<8)|b4;
Serial.println(numRebuild, DEC);
Serial.println(numRebuild, BIN);
//Using unsigned long gives double the original 'num'
unsigned long numRebuild2 = (b1<<24)|(b2<<16)|(b3<<8)|b4;
Serial.println(numRebuild2, DEC);
Serial.println(numRebuild2, BIN);
Here are the results I get (to make it easier to read I have added result Lines):
Line 1 - 22:45:16.504 -> 2147483643
Line 2 - 22:45:16.504 -> 1111111111111111111111111111011
Line 3 - 22:45:16.571 -> 1111111
Line 4 - 22:45:16.571 -> 11111111
Line 5 - 22:45:16.571 -> 11111111
Line 6 - 22:45:16.571 -> 11111011
Line 7 - 22:45:16.606 -> rebuilding below
Line 8 - 22:45:16.606 -> -5
Line 9 - 22:45:16.606 -> 11111111111111111111111111111011
Line 10 - 22:45:16.641 -> 4294967291
Line 11 - 22:45:16.676 -> 11111111111111111111111111111011
The results aren't as expected. When rebuilding the new Long numRebuild
I get a -5, which I'm not understanding, and equally, for numRebuild2
, I am getting the over the maximum available number of an 'Unsigned Long' datatype: it is the maximum available (to my understanding) + 1!
Now, I can see that the Binary values on numRebuild
and numRebuild2
match each other, but both of these have an extra bit (32bits instead of 31) from the original long of num
I believe this is helping identify whether it's positive or negative, however I have tried to account for this by shifting the first byte, as well as trying to force a '0' at the very beginning, to no such luck.
Is anyone able to shed any light on why I am getting these numbers as I don't quite fully understand, as well as a potential fix, or a hint at what other terms I should perhaps be searching for?
Thanks in advance, and apologies for the wordy post!
