Hi all,
It's been a while since I showed my face in here with a question, up until now I've done stuff that worked the way I wanted without asking here what I need.
So, my project is a moodlight that can be controlled by an Android app using bluetooth.
Communication works, basic functions (single colors) work fine, no problem.
Now I want to have the light show some fades and I can also make that work, but only once.
I've been looking into repeating a function and I came to the conclusion I will have to enter the world of state machines.
I started reading up here on the playground and I understand the logic behind it, but have no idea how to implement it.
I did not even try to implement one because I simply cannot understand what I will have to put into my code.
The (shortened version of the) code:
/* trial code for statemachines */
#include "Tlc5940.h"
#include "SoftwareSerial.h"
//colors on the TLC pins
int red[] = {0, 3, 6, 9, 12}; //Red LED's
int blue[] = {1, 4, 7, 10, 13}; //Blue LED's
int green[] = {2, 5, 8, 11, 14}; //Green LED's
int bright = 768;
int color = 0;
SoftwareSerial BTSerial (7, 8);
BTSerial.begin(9600);
Tlc.init(); //initialize TLC chip
delay(1000); //this delay is in place so that the first part of the code is not skipped.
for (int i = 0; i <= 4; i++) {
Tlc.set(red[i], 500);
Tlc.update();
Tlc.clear();
Tlc.set(green[i], 500);
Tlc.update();
Tlc.clear();
Tlc.set(blue[i], 500);
Tlc.update();
Tlc.clear();
Tlc.update();
if (BTSerial.available() > 0) {
color = BTSerial.read();
if (color == 'Q') {
rainbowfade();
color = 0;
else if (color == 'Z') {
Tlc.clear();
Tlc.update();
color = 0;
void rainbowfade() {
Tlc.clear();
for (int i; i <= 4; i++){
for (int fade = 0; fade <= 255; fade += 5){
Tlc.set(red[i], fade);
Tlc.update();
delay(10);
Tlc.set(green[i], fade);
Tlc.update();
delay(10);
Tlc.set(blue[i], fade);
Tlc.update();
delay(10);
for (int fade = 255; fade >= 0; fade -= 5){
Tlc.update();
delay(25);
Yes, I'm using delays to simplify things for now, I am only testing it for now. The final code will use millis, which is another thing I am playing around with to get it to work as intended, for now the delays work as intended.
Now, my question:
I have a bunch of functions, that all make the TLC chip show a single color. They stay on, that's the way it is intended. Until I send a new command through the serial connection the color stays on. That is why I cut out all those functions (as you can probably guess, the functions are A through to P).
The fader, however will run once (all LED's go from off to 255 one at a time, then they all go off at once).
So, I need to implement state machines and I am guessing I have to rewrite my whole code to get this to work.
Any good pointers on where to start?
