Hi, here is my project :
I want to read sensor value and show the value on web browser, and then get the sensor value (with php?) and store it into mysql and then show last 20 logs of measuring into php again..
I am connecting Grove Light Sensor to XBee Carrier + Wifi Bee and using WiShield library with WiServer header. XBee Carrier reading sensor value and sending it to browser using Wifi Bee.
The code :
* A simple sketch that uses WiServer to serve a web page
#include <WiServer.h>
#include <math.h>
// Wireless configuration parameters ----------------------------------------
unsigned char local_ip[] = {192,168,234,55}; // IP address of WiShield
unsigned char gateway_ip[] = {192,168,234,1}; // router or gateway IP address
unsigned char subnet_mask[] = {255,255,255,0}; // subnet mask for the local network
char ssid[] = {"Connectify-me"}; // max 32 bytes
unsigned char security_type = 3; // 0 - open; 1 - WEP; 2 - WPA; 3 - WPA2
// WPA/WPA2 passphrase
const prog_char security_passphrase[] PROGMEM = {"0987654321"}; // max 64 characters
// WEP 128-bit keys
prog_uchar wep_keys[] PROGMEM = {
0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0a, 0x0b, 0x0c, 0x0d, // Key 0
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // Key 1
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, // Key 2
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 // Key 3
// setup the wireless mode; infrastructure - connect to AP; adhoc - connect to another WiFi device
#define WIRELESS_MODE_INFRA 1
#define WIRELESS_MODE_ADHOC 2
unsigned char wireless_mode = WIRELESS_MODE_INFRA;
unsigned char sensorValue;
unsigned char ssid_len;
unsigned char security_passphrase_len;
// End of wireless configuration parameters ----------------------------------------
int counter;
// This is our page serving function that generates web pages
boolean sendMyPage(char* URL) {
// Check if the requested URL matches "/"
if (strcmp(URL, "/") == 0) {
// Use WiServer's print and println functions to write out the page content
WiServer.print("<html>");
// Instruct the web broweser to refersh every 10 seconds
WiServer.print("<head><meta http-equiv=\"refresh\" content=\"10\"> </head>");
WiServer.println("<H1>WifiBee Connected...<H1>");
WiServer.print("<H2>Sensor Value = ");
WiServer.print(sensorValue); //pin 5 is connected to an exernal sensor. The RAW value is send to the client.
WiServer.print("</H2>");
WiServer.print("</html>");
// URL was recognized
return true;
// URL not found
return false;
// Initialize WiServer and have it use the sendMyPage function to serve pages
WiServer.init(sendMyPage);
// Enable Serial output and ask WiServer to generate log messages (optional)
Serial.begin(57600);
WiServer.enableVerboseMode(true);
void loop(){
sensorValue = analogRead(5); //pin 5 is connected to an exernal sensor via Grove interface in Grove - XBee Carrier .
Rsensor=(float)(1023-sensorValue)*10/sensorValue;
// Run WiServer
WiServer.server_task();
delay(10);
When I access the IP of Wifi Bee it worked fine, the page showed :
Sensor Value = xxx
My question is how to get the "xxx" in order to store it into mysql??
I have searched over the internet and got some idea if it is possible :
- use GET in php, the problem is how to send the value to URL?
I found this code :
void getTemp() {
Serial.println("connected, writing ...");
int temp = analogRead(5);
delay(50);
sprintf(strURL,"GET /temp.php?t=%d",temp);
client.println(strURL);
client.println();
Serial.println(strURL);
but the code is in ethernet shield tutorial and use Ethernet.h header, I wonder if it works in WiShield library/WiServer header?
use POST in php, the problem is how to send the value automatically (without submit button or something like that since I only know that sending strings is manually and then php call the strings)
assume the sensor value is a string in html, is it possible to get a certain string (the sensor value in this case) from html page/html code?
(sorry for my bad english)
