I am trying to make a terminal-monitor.
Its receiving this data format (123.45,678.90)
This is the code:
// (c) Harry H.Arends
#include <Wire.h>
char inData[15]; // Allocate some space for the string
char inChar; // Where to store the character read
byte index = 0; // Index into array; where to store the character
char *AXpos;
char *EYpos;
const char *delimiter = ",";
char *posX;
char *posY;
String serialResponse = "";
LiquidCrystal_I2C lcd(0x27, 20, 4); // set the LCD address to 0x27 for a 16 chars and 2 line display
while (Serial.available() > 0) {
if (index < 14) // One less than the size of the array
inData[index] = Serial.read(); // Store it
// Serial.println(inChar);
index++; // Increment where to write next
inData[index] = '\0'; // Null terminate the string
// Serial.print(index);
// Serial.print("=");
// Serial.println(inData);
AXpos = strtok(inData, delimiter);
EYpos = strtok(NULL, delimiter);
Serial.print("AX=");
Serial.println(AXpos);
Serial.print("EY=");
Serial.println(EYpos);
The program produces AXpo but NOT EYpos.
What could be wrong??
What does the program print out, for both?
You might try this example, which should help you guess what went wrong:
// parse a C-string
char array[] = "(123.45,678.90)";
char *ptr = NULL;
Serial.println("strtok example");
ptr = strtok(array, ","); // delimiter = comma
while(ptr != NULL)
Serial.println(ptr);
ptr = strtok(NULL, ","); // delimiter = comma
Hint: try something like this for the delimiters:
ptr = strtok(array, ",()");
Topic moved !! Please do not post in "Uncategorized"; see the sticky topics in Uncategorized - Arduino Forum .
alto777
November 24, 2024, 3:46am
4
kunstmaan2024:
Print inData before these lines to see what you are feeding.
Also, are parentheses part of the format? I guessed not as you don't take in enough characters, maybe you were using them like we would normally use quotes as @jremington has
temporarily skip the reading of input and just make inData be some plausible known correct input in the same manner.
a7
alto777
November 24, 2024, 4:06am
5
char inData[] = "54.321,109.876";
char *AXpos;
char *EYpos;
Serial.print("AX=\"");
Serial.print(AXpos);
Serial.println("\" ");
Serial.print("EY=\"");
Serial.print(EYpos);
void loop() {}
output
AX="54.321"
EY="109.876"
Nothing to do with *strtok*()
a7
The program produces using serialmonutor,
input=123.45,678.90
output:
06:53:57.872 -> EY=
06:53:57.872 -> AX=123.45
06:53:57.872 -> EY=
06:53:57.906 -> AX=123.45
06:53:57.906 -> EY=
06:53:57.906 -> EY=
06:53:57.937 -> AX=123.45
06:53:57.937 -> EY=
06:53:57.937 -> EY=
as you see EY stays empty
J-M-L
November 24, 2024, 6:23am
9
kunstmaan2024:
You try to parse the string every time you get a new character. Shouldn't you wait until you've received the full payload before doing so ?
I would suggest to study Serial Input Basics to handle the data input.
So I studyed the input-basics and used a example and addapted to my needs:
#include <Wire.h>
char *AXpos;
char *EYpos;
const byte numChars = 15;
char inData[numChars]; // an array to store the received data
boolean newData = false;
recvWithEndMarker();
processNewData();
void recvWithEndMarker() {
static byte ndx = 0;
char endMarker = '\n';
char rc;
while (Serial.available() > 0 && newData == false) {
rc = Serial.read();
if (rc != endMarker) {
inData[ndx] = rc;
ndx++;
if (ndx >= numChars) {
ndx = numChars - 1;
Serial.print("Received= ");
Serial.println("Done");
inData[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
//Serial.println(ndx);
void processNewData() {
if (newData == true) {
//Serial.println();//terminate starsline
Serial.print("This just in ... ");
newData = false;
//Serial.print("*");//max.14 stars
But newData never gets true, why??
Maybe you do not send a '\n'? There are settings in the Serial Monitor that define the line ending. For the code you provided it should be set to LF (Line Feed).
So I added this:
Serial.print(ndx);
Serial.print("-");
and the output is as follows:
09:50:09.857 -> 4-Received= 123.
09:50:09.857 -> 5-Received= 123.4
09:50:09.891 -> 6-Received= 123.45
09:50:09.925 -> 7-Received= 123.45,
09:50:09.925 -> 8-Received= 123.45,6
09:50:09.957 -> 9-Received= 123.45,67
09:50:09.989 -> 10-Received= 123.45,678
09:50:09.989 -> 11-Received= 123.45,678.
09:50:10.022 -> 12-Received= 123.45,678.9
09:50:10.056 -> 13-Received= 123.45,678.90
09:50:10.088 -> 14-Received= 123.45,678.90
It does receive a CR
alto777
November 24, 2024, 3:46pm
13
What program? Please state the post # where it is hiding from me.
I see no code that actually prints the string that you are feeding to strtok .
a7
kunstmaan2024:
maybe you need a '\r' carriage return instead of '\n' newline??
good luck.. ~q
J-M-L
November 24, 2024, 5:56pm
15
How is your serial monitor set?
Thnx for all the advice so I have rewritten the code:
#include <Wire.h>
char *AXpos;
char *EYpos;
processNewData();
extractData();
char rc;
rc = Serial.read();
inData[ndx] = rc;
ndx++;
ndx = numChars - 1;
Serial.print(ndx);
Serial.print("-");
ndx = 0;
newData = true;
// newData = false;
void extractData() {
//Extract two numbers from received data
Serial.print("AX= ");
Serial.print("EY= ");
newData = false;
And it produces the correct output/result:
22:20:40.418 -> 1-Received= 1
22:20:40.418 -> 2-Received= 12
22:20:40.452 -> 3-Received= 123
22:20:40.452 -> 4-Received= 123.
22:20:40.487 -> 5-Received= 123.4
22:20:40.487 -> 6-Received= 123.45
22:20:40.521 -> 7-Received= 123.45,
22:20:40.521 -> 8-Received= 123.45,6
22:20:40.556 -> 9-Received= 123.45,67
22:20:40.589 -> 10-Received= 123.45,678
22:20:40.621 -> 11-Received= 123.45,678.
22:20:40.621 -> 12-Received= 123.45,678.9
22:20:40.656 -> 13-Received= 123.45,678.90
22:20:40.690 -> Done
22:20:40.690 -> This just in ... 123.45,678.90
22:20:40.724 -> AX= 123.45
22:20:40.762 -> EY= 678.90
So again thanks for all the input and till next time
system
Closed
May 24, 2025, 6:22am
18
