Solved . thanks to dmjlambert. Analog inputs are not correct on Mega ADK
Have tried two boards wit same results.
I was starting another project with a Mega ADK, Should be the same as a Mega 2560.
On the A0 - A11 using 5 VDC from the card, with a dupont male to male jumper wire I find that the inpits are not where I expect them to be. Pins that read will read 5, 3.3 or 0 VDC when applied.
What is going on here??
Where Where
Attached Read
Physical Software
A0 - A0
A1 - A11
A2 - A2
A3 - no show
A4 - A6
A5 - A7
A6 - no show
A7 - A9
A8 - no show
A9 - A3
A10 - A4
A11 - A5
//#include <SoftwareSerial.h>
// software serial #2: TX = digital pin 8, RX = digital pin 9
//SoftwareSerial portOne(14, 15); // 14 = TX 15 = RX
//SoftwareSerial portTwo(16, 17); // 16 = TX 17 = EX
int channelpin [] = {A0, A1, A2, A3, A4, A5, A6, A7, A8, A9, A10, A11};
int LowCal [11];
int HighCal [11];
int AnalogRead [11];
  for (int i = 0; i < 12; i++)
    delay(20);
    pinMode(channelpin[i], INPUT);
    AnalogRead[i] = analogRead[i] (channelpin[i]);
  analogReference(DEFAULT);
  { pinMode(channelpin[i], INPUT);
    Serial.print(i);
    Serial.print(" ");
    Serial.print(AnalogRead[i]);
    delay(20);
    Serial.print(" ");
  Serial.println(" ");
  delay (500);
  // Select Analog Channels for Settings
  // Do Low Cal
  // Do High Call
  // Set Minimum reading
  // Set Maximum reading
  // Set Averaging
  // Set Rounding
  // Set Name of Channel
  // Set Local Display
  //Select Com port settings
  // Select Com port 1-4
  // UP Link or Down Link
  // Set Baudrate
  // Set bits
  // Set set stop bit
  // Set set pairity
  // Select Data Send
  // Set acquition speed
     what is this?
I was expecting something like
analogRead(channelpin[i]);
I'm not even sure why
analogRead[i] (something);
compiles.
The code doesn't compile.
Pete
This one line does not compile
But if I omit that top line, the rest does compile. I don't really know why it compiles. It is interesting...
Forgot last end of a remark. Should not have been included.
analogRead (channelpin*);*
* what is this?*
Good catch.
an AnalogRead looked too much like analogRead so I changed AnalogRead to ChannelRead and all Works!! great to have another set of eyes when you have been up too long.
This was my first attempt at using arrays since I wrote a database app in school about 18 years ago.
I should have posted it in the next group. I can't see how it compiled and worked at all since you pointed out my mistakes.
  • Star Gazer Data Systems Inc.      08/20/2015              *
  • www.stargazerdatasystems.com                              *                                                            *
  • Written by Mark W.                                        *
  • Data Logger for the Arduino Due Processor 12 bit Analog    *
  • Version 1.01                                              *
    *  14 = TX 15 = RX portOne                                  *
    *  16 = TX 17 = RX portTwo                                  *
    *  Testing on a Mega ADK                                    *
int LowCal [11];
int HighCal [12];
int ChannelRead [11];
    delay(20);
    ChannelRead[i] = analogRead (channelpin[i]);
    Serial.print(i);
    Serial.print(" ");
    Serial.print(ChannelRead[i]);
    delay(20);
    Serial.print(" ");
  delay (500);
  // Do Low Cal
  // Do High Call
  // Set Averaging
  // Set Rounding
  // Set Baud-rate
  // Set bits
  // Set set stop bit
  // Set set parity
  // Select Data Send
  // Set acquisition speed
_
```*_
Thank you so very much dmjlambert.
