I am using Automation Direct's P1AM Arduino PLC to try and send commands to a TCP/IP stepper motor driver. Using Wireshark I was able to see the data that needed to be in the packet to control the motor.
I wrote the following program to try and send this same packet to the stepper driver but from the Arduino instead of my computer:
#include <SPI.h>
#include <Ethernet.h>
String Control, Command;
byte mac[] = { //Mac address on side of P1AM Eth module
0x60, 0x52, 0xD0, 0x07, 0x41, 0x95
IPAddress ip(192, 168, 1, 2);//IP Address of the P1AM-ETH module.
IPAddress stepperDriver(192, 168, 1, 1); //IP Address for stepper motor driver
EthernetClient client;
char Null = 0; //Ascii value of null character
char Bell = 7; //Ascii value of bell character
char Ret = 13; //Ascii value of carriage return
char Lf = 10; //Ascii value of line feed
Control = String("FL10000"); //step motor 10000 steps
Command = String(Null + Bell + Control + Ret + Lf); //append header and footer to command string
Ethernet.begin(mac, ip);
delay(2000); //sanity delay
Serial.println("Connecting...");
if (client.connect(stepperDriver, 49153)) { //Connect to device
Serial.println("Connected");
Serial.println("Connection Failed");
delay(3000);
client.print(Command); //send packet
Serial.print(Command); //print packet in serial monitor
Running this and using Wireshark again gives me this:
However if I change the line:
To:
Command = String(Bell + Control + Ret + Lf);
I get closer to my expected result but still do not have the null character at the start:
#include <SPI.h>
byte command[] = {0x00, 0x07, 0x46, 0x4c, 0x31, 0x30, 0x30, 0x30, 0x30, 0x0d, 0x0a};
delay(3000);
client.write(command, sizeof(command));
Thank you all very much for the help, I ended up solving the issue by using memcpy and .c_str() to copy the contents of the header, command, and footer into a byte array and sending that to the server using the client.write function rather than client.print.
For those interested here is my code:
#include <SPI.h>
byte mac[] = { 0x60, 0x52, 0xD0, 0x07, 0x41, 0x95 };
int port = 49153;
int time = 5000;
byte header[2] = {0x00, 0x07};
byte footer[2] = {0x0d, 0x0a};
String Control = "FL10000";
if (client.connect(stepperDriver, port)) { //Connect to device
if(client.connected()){
int commandSize = sizeof(header) + sizeof(footer) + Control.length();
byte Command[commandSize];
memcpy(Command, header, sizeof(header));
memcpy(Command + sizeof(header), Control.c_str(), Control.length());
memcpy(Command + sizeof(header) + Control.length(), footer, sizeof(footer));
client.write(Command, commandSize); //send command
else{
Serial.println("Connection lost, attempting to reconnect.");
client.connect(stepperDriver, port); //attempt to reconnect
delay(time);
