Serial.write null character
Is there a way to write the null character to a serial stream. I tried both print and write with char or unsigned char but none of the combinations actually writes the null character. In fact if I do
case GETMODEBYTE:
Serial.print('s');
Serial.print('t');
Serial.print('m');
Serial.write(0x00);
Serial.write(0x01);
Serial.write(0x02);
The output on the other end of the serial connection would be:
0x73 0x74 0x6d 0x01 0x02
Difficult to tell from that statement which end is at fault.
I don't see any problem with a "Serial.write (0);"
I can see no special handling of 0 in the serial write code (as you would expect), so it has be the receiving end. Can you post that code?
Rob
Hmmm, I've looked at it with my scope and I guess the 0 is being sent, however it isn't received by windows. Strange...
ow yeah, that is with following code:
	Serial.write('a');
	Serial.write(0x00);
	Serial.write('a');
Well who know what's happening in Windows? That's why I like embedded work :slight_smile:
Does that terminal program have a binary or HEX mode or something, it looks to be in ASCII mode and in that case you won't see any control characters.
Rob
The program is a serial monitor, it spies on an already open serial port. The port is opened by the arduino serial monitor. The before last column displays the hex values :slight_smile:
Anyway, normally I send the data with a bluegiga chip to my android phone, so my hope is that java(android) will be able to interpret the null character correctly, otherwise I'll have to adjust my protocol :slight_smile:
