I am trying to implement a watchdog timer that reboots the Linux OS running on the Yun. I came across the watchdog and issued the following command
watchdog -t 5 -T 60 /dev/watchdog
This starts a watchdog daemon and it appears that the watchdog is automatically reset by the command. I was looking something similar to what you would do on a microcontroller. I would like to be able to reset the watchdog @ /dev/watchdog from the application I am running.
Is there a way of achieving this?
Yun OS has watchdog daemon install and enabled.
root@Arduino:~# ps |grep watchdog
1347 root 1492 S /sbin/watchdog -t 5 /dev/watchdog
2792 root 1484 S grep watchdog
watchdog --help
BusyBox v1.19.4 (2014-11-13 19:03:47 CET) multi-call binary.
Usage: watchdog [-t N[ms]] [-T N[ms]] [-F] DEV
Periodically write to watchdog device DEV
-T N Reboot after N seconds if not reset (default 60)
-t N Reset every N seconds (default 30)
-F Run in foreground
Use 500ms to specify period in milliseconds
means reset the watchdog every 30 seconds with 60 second timeout
same as
So No need to issued the that command.
To trigger watchdog:
root@Arduino:~# uptime
20:26:52 up 53 min, load average: 0.00, 0.03, 0.04
pgrep watchdog | xargs kill -SIGSTOP
20:29:22 up 1 min, load average: 0.42, 0.21, 0.08
