Some question about memory on the Linino side
In my Python scripts (that are periodically triggered by the Arduino side) I use and run code as-like the following:
import os
os.system curl www.website.com --output /tmp/script_file.txt
with open('/tmp/script_file.txt') as file1:
    content = ... # load content
file2 = open('/tmp/another_script_file.txt', 'w')
My questions are:
1) Can the above code make the Linino side to reach "out of memory" / "stackoverflow" errors so that it starts to behave unespectly or even to block "a là Arduino way"?
2) Is it advisable to store the cURL response (see the '--output' option in the above code) to files in the 'tmp' directory on the Linino side?
3) What should I look for in order to avoid issues?
4) What else do you advice relating memory concerns on the Linino side?
5) What tools should I use to monitor the memory usage on the Linino side?
speaking: 1) Can the above code make the Linino side to reach "out of memory" / "stackoverflow" errors so that it starts to behave unespectly or even to block "a là Arduino way"?
I can't say for sure, but probably the answer is "sure you can use up all the ram". If you do the result will probably be a "Out of memory" kernel panic.
It is as good a place as any. Definitely better than flash. /tmp is in ram. A sd card or thumb drive that you don't mind burning all the write cycles on may be another good place especially if you have a LOT of info to store and don't write it often.
Use as little as possible, there is only 64M. Flush unused information often. Have your scripts that store a lot of information check to see how much they are using/is available
Linino is a version of Openwrt, Openwrt is a version of linux. The normal tools for linux are (usually) available.
root@Arduino:~# free
             total         used         free       shared      buffers
Mem:         61132        27968        33164            0         3844
-/+ buffers:              24124        37008
Swap:            0            0            0
root@Arduino:~# cat /proc/meminfo
MemTotal:          61132 kB
MemFree:           33164 kB
Buffers:            3844 kB
Cached:             9832 kB
SwapCached:            0 kB
Active:             7828 kB
Inactive:           8252 kB
Active(anon):       2452 kB
Inactive(anon):       72 kB
Active(file):       5376 kB
Inactive(file):     8180 kB
Unevictable:           0 kB
Mlocked:               0 kB
SwapTotal:             0 kB
SwapFree:              0 kB
Dirty:                 0 kB
Writeback:             0 kB
AnonPages:          2420 kB
Mapped:             2528 kB
Shmem:               120 kB
Slab:               5348 kB
SReclaimable:       1320 kB
SUnreclaim:         4028 kB
KernelStack:         376 kB
PageTables:          380 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:       30564 kB
Committed_AS:       7332 kB
VmallocTotal:    1048372 kB
VmallocUsed:        2404 kB
VmallocChunk:    1038528 kB
