Someone know how to fix this?
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
     System wide configuration file is "C:\Users\joshu\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
     Using Port                    : COM5
     Using Programmer              : arduino
     Overriding Baud Rate          : 115200
avrdude: ser_open(): can't open device "\.\COM5": The semaphore timeout period has expired.
avrdude done. Thank you.
Failed uploading: uploading error: exit status 1
Good idea to mention some details of what it is you want fixing in the title of your post.
You might attract the interest of someone with expertise in that particular area.
That is probably a windoz driver problem or a cable problem. Can you check the UNO and cable on another machine? If so that will narrow down the problem. Try a different cable, some are for charging only and will not work. I am assuming there is nothing currently connected to the UNO other then the USB cable.
Have you tried a later IDE version? I'm using V 1 8 5 with Win 10.
