sparkfun eagle tutorial how to wire barrel jack correctly
I'm following a sparkfun tutorial on how to build a pcb in eagle.
Tutorial
schematic
This is the part for the DC barrel jack.
sparkfun dc barrel jack
My question is - how can you tell from the datasheet, how to wire it correctly (as shown in the schematic)?
Seems like a stupid question, sorry.
T
The drafting is certainly a bit strange, notably how they rotate the part from the side view to create the "Top view". The important point is that pin 1, the center pin, is the pin farthest from the plug entrance hole and typically VCC. Pin 2 is GND, and pin 3 (the side pin) makes contact with pin 2 when no plug is inserted.
Thank you :slight_smile:
Note the PCB Layout part of the document shows the front of the connector outline as a dotted line, and
has pin numbers marked on the pads.
