Sparkfun Pulse Sensor showing wrong and escalating values
I am struggling to make my Sparkfun pulse sensor work properly. Right now I am even using their example code "Getting BPM to monitor". The problem is that the BPM starts off correct but suddenly starts escalating. I have connected the pulsesensor to A0, GND, and 5V straight on the Arduino Uno board. This is the code:
/*  Getting_BPM_to_Monitor prints the BPM to the Serial Monitor, using the least lines of code and PulseSensor Library.
 *  Tutorial Webpage: https://pulsesensor.com/pages/getting-advanced
--------Use This Sketch To------------------------------------------
1) Displays user's live and changing BPM, Beats Per Minute, in Arduino's native Serial Monitor.
2) Print: "♥  A HeartBeat Happened !" when a beat is detected, live.
2) Learn about using a PulseSensor Library "Object".
4) Blinks the builtin LED with user's Heartbeat.
#include <PulseSensorPlayground.h>     // Includes the PulseSensorPlayground Library.
//  Variables
const int PulseWire = 0;       // PulseSensor PURPLE WIRE connected to ANALOG PIN 0
const int LED = LED_BUILTIN;          // The on-board Arduino LED, close to PIN 13.
int Threshold = 550;           // Determine which Signal to "count as a beat" and which to ignore.
                               // Use the "Gettting Started Project" to fine-tune Threshold Value beyond default setting.
                               // Otherwise leave the default "550" value.
PulseSensorPlayground pulseSensor;  // Creates an instance of the PulseSensorPlayground object called "pulseSensor"
  Serial.begin(115200);          // For Serial Monitor
  // Configure the PulseSensor object, by assigning our variables to it.
  pulseSensor.analogInput(PulseWire);
  pulseSensor.blinkOnPulse(LED);       //auto-magically blink Arduino's LED with heartbeat.
  pulseSensor.setThreshold(Threshold);
  // Double-check the "pulseSensor" object was created and "began" seeing a signal.
   if (pulseSensor.begin()) {
    Serial.println("We created a pulseSensor Object !");  //This prints one time at Arduino power-up,  or on Arduino reset.
if (pulseSensor.sawStartOfBeat()) {            // Constantly test to see if "a beat happened".
int myBPM = pulseSensor.getBeatsPerMinute();  // Calls function on our pulseSensor object that returns BPM as an "int".
                                               // "myBPM" hold this BPM value now.
 Serial.println("♥  A HeartBeat Happened ! "); // If test is "true", print a message "a heartbeat happened".
 Serial.print("BPM: ");                        // Print phrase "BPM: "
 Serial.println(myBPM);                        // Print the value inside of myBPM.
  delay(20);                    // considered best practice in a simple sketch.
Any ideas what might be going wrong here?
Also I am a complete Arduino beginner :slight_smile:
What is escalating and what is suddenly?
Verify all your devices' grounds share a common point/connection.
How to Interface Pulse Sensor with ESP8266 using Arduino Programming:
