Sparkfun SAMD21 dev breakout issue
My pressure sensor signal voltage to the arduino A0 pin is 75mV, or .015 of the 0-5V it puts out. The SAMD21 is 12 bit, so 4096 steps. .015*4095 = 61.4, but the reading is 26 or so. What am I missing??
Thanks!
Bill
Here is the code and output.
Also, I am having to use the arduino MKR Zero drivers as whenever I load the Sparkfun samd21 dev breakout driver the board accepts programming, produces no error codes, but won't output any data.
Since the SAMD21 is a 3.3V ONLY processor, if a voltage > 3.3V was ever applied to the analog input, you may have damaged the ADC.
This thread shows how to get 16bit resolution using oversampling and averaging: Addressing SAM D21 ADC
More on getting the most out of the SAMD21 ADC: Reading analog values with the SAMD21's ADC - Stargirl (Thea) Flowers
Thanks. I'm such a noob. Only 75mV has ever been applied.
How do you know that?
You should NEVER connect a 5V device output to a 3.3V device input without taking precautions like using a voltage divider, a logic level shifter, etc. as the circumstances require.
Its a psia pressure sensor that has only been exposed to atmosphere. That's 75mV, period.
If you believe that, without checking for startup or shutdown transients, good luck.
