SparkFun weather meter (wiring wind vane and anemometer)
Hi !!!
I am working on weather station project but I am having difficulties in wiring the wind vane and the anemometer to Arduino uno.
I tried to follow the datasheet instructions from sparkfun but it is not very clear to me.
Can anyone supply me with an easy to follow schematic wiring where I can visualise which wire color connects to what.
This is my code below and it outputs number (zero, zero, zero) for all the values from the sensors.
I have a deep suspicious that the failure has to do with the my wiring since I am not sure if I am doing it the right way
Thank you in advance!!!
// Set up the inputs and the interrupts
#define ANEMOMETER_PIN 3
#define ANEMOMETER_INT 1
#define VANE_PWR 4
#define VANE_PIN A0
#define RAIN_GAUGE_PIN 2
#define RAIN_GAUGE_INT 0
  pinMode(ANEMOMETER_PIN,INPUT);
  digitalWrite(ANEMOMETER_PIN,HIGH);  // Turn on the internal Pull Up Resistor
  pinMode(RAIN_GAUGE_PIN,INPUT);
  digitalWrite(RAIN_GAUGE_PIN,HIGH);  // Turn on the internal Pull Up Resistor
  pinMode(VANE_PWR,OUTPUT);
  digitalWrite(VANE_PWR,LOW);
  attachInterrupt(ANEMOMETER_INT,anemometerClick,FALLING);
  attachInterrupt(RAIN_GAUGE_INT,rainGageClick,FALLING);
  interrupts();
// Wind speed (anemometer)
#define WIND_FACTOR 2.4
#define TEST_PAUSE 60000
volatile unsigned long anem_count=0;
volatile unsigned long anem_last=0;
volatile unsigned long anem_min=0xffffffff;
double getUnitWind()
  unsigned long reading=anem_count;
  anem_count=0;
  return (WIND_FACTOR*reading)/(TEST_PAUSE/1000);
double getGust()
  unsigned long reading=anem_min;
  double time=reading/1000000.0;
  return (1/(reading/1000000.0))*WIND_FACTOR;
void anemometerClick()
  long thisTime=micros()-anem_last;
  anem_last=micros();
  if(thisTime>500)
    anem_count++;
    if(thisTime<anem_min)
      anem_min=thisTime;
// Wind direction (vane)
static const int vaneValues[] PROGMEM={66,84,92,127,184,244,287,406,461,600,631,702,786,827,889,946};
static const int vaneDirections[] PROGMEM={1125,675,900,1575,1350,2025,1800,225,450,2475,2250,3375,0,2925,3150,2700};
double getWindVane()
  analogReference(DEFAULT);
  digitalWrite(VANE_PWR,HIGH);
  delay(100);
  for(int n=0;n<10;n++)
    analogRead(VANE_PIN);
  unsigned int reading=analogRead(VANE_PIN);
  unsigned int lastDiff=2048;
  for (int n=0;n<16;n++)
    int diff=reading-pgm_read_word(&vaneValues[n]);
    diff=abs(diff);
    if(diff==0)
       return pgm_read_word(&vaneDirections[n])/10.0;
    if(diff>lastDiff)
      return pgm_read_word(&vaneDirections[n-1])/10.0;
    lastDiff=diff;
  return pgm_read_word(&vaneDirections[15])/10.0;
// Rain gauge
#define RAIN_FACTOR 0.2794
volatile unsigned long rain_count=0;
volatile unsigned long rain_last=0;
double getUnitRain()
  unsigned long reading=rain_count;
  rain_count=0;
  double unit_rain=reading*RAIN_FACTOR;
  return unit_rain;
void rainGageClick()
    long thisTime=micros()-rain_last;
    rain_last=micros();
    if(thisTime>500)
      rain_count++;
// Main loop
  Serial.println(getUnitWind());
  Serial.println(getGust());
  Serial.println(getWindVane());
  Serial.println(getUnitRain());
  Serial.println(" ");
  delay(10000);
hey, Iam designing a mini weather project using an anemometer wind vane and a rain gauge.
guys a little help with how to get started will be really appreciated.
thank you
