the wav files i use are always radio static this is the layout i use to play sound
i can create or add an arduino scheme sorry
microsd card reader: CS - pin 10 SCK - pin 13 MOSİ pin 11 MİSO pin 12 vcc and gnd is connected to the normal power supplies.
Speaker: Negative - GND positive - PİN 9 the audio preferences for the .wav file is
8BİT 16khz mono
What type of radio are you using?
no it makes those kind of sounds i use a speaker its supposed to play music not do static sounds
Speakers should never have DC connections! Show a block diagram of your pieces with lines showing the actual connections.
Are you trying to drive a speaker directly from the arduino pin? What kind of speaker is it? Show your wiring diagram.
Artist impression of an artist impression???
An illustration of Garbage In - Garbage Out
can you show the pin connections its hard to understand from the image
one of the speakers are not connected because i want 1 speaker to play also the code:
#include <SoftwareSerial.h>
#include <DFRobotDFPlayerMini.h>
SoftwareSerial mySerial(10, 11); // RX, TX
DFRobotDFPlayerMini myDFPlayer;
mySerial.begin(9600);
Serial.println(F("Initializing DFPlayer ..."));
if (!myDFPlayer.begin(mySerial)) {
Serial.println(F("Unable to begin:"));
while (true);
Serial.println(F("DFPlayer Mini online."));
Serial.print(F("Volume: "));
myDFPlayer.volume(25); // Set volume value (0~30).
Serial.println(25);
Serial.println(F("Playing track 1"));
myDFPlayer.play(0001); // Play the file named "0001.mp3"
if (myDFPlayer.available()) {
int message = myDFPlayer.readType();
switch (message) {
case DFPlayerPlayFinished:
Serial.println(F("Track finished playing."));
case DFPlayerError:
Serial.println(F("DFPlayer Error."));
int error = myDFPlayer.read();
printErrorDetail(error);
default:
Serial.println(F("Unknown message."));
delay(1000); // Add a small delay to avoid flooding the serial output
void printErrorDetail(uint8_t error) {
switch (error) {
case TimeOut:
Serial.println(F("Time Out!"));
case WrongStack:
Serial.println(F("Stack Wrong!"));
case DFPlayerCardInserted:
Serial.println(F("Card Inserted!"));
case DFPlayerCardRemoved:
Serial.println(F("Card Removed!"));
case DFPlayerCardOnline:
Serial.println(F("Card Online!"));
case DFPlayerError:
Serial.println(F("General Error!"));
default:
Serial.println(F("Unknown Error!"));
i updated the code still doesnt work `#include "SoftwareSerial.h"
#include "DFRobotDFPlayerMini.h"
// Use pins 2 and 3 to communicate with DFPlayer Mini
static const uint8_t PIN_MP3_TX = 2; // Connects to module's RX
static const uint8_t PIN_MP3_RX = 3; // Connects to module's TX
SoftwareSerial softwareSerial(PIN_MP3_RX, PIN_MP3_TX);
// Create the Player object
DFRobotDFPlayerMini player;
// Init USB serial port for debugging
// Init serial port for DFPlayer Mini
softwareSerial.begin(9600);
// Start communication with DFPlayer Mini
if (player.begin(softwareSerial)) {
Serial.println("OsK");
// Set volume to maximum (0 to 30).
player.volume(30);
// Play the first MP3 file on the SD card
player.play(1);
Serial.println("Connecting to DFPlayer Mini failed!");
theres a error alot mroe different than the main problem i will amke a new topic about it
