The main goal of this project was to test the speech recognition performance of BitVoicer (http://www.bitsophia.com/BitVoicer.aspx). For this purpose, I designed a simple led control sketch which I integrated with BitVoicer. Of course you can do anything you want once you have received the commands from Bitvoicer, but to keep things simple, I thought a led test would do just fine.
This is the YouTube video with the result:
This is the code I created to control the leds and retrieve data from BitVoicer:
//Includes the BitVoicer library to the sketch
#include <BitVoicer.h>
//Sets up the pins and default variables
int pinR = 3;
int pinY = 5;
int pinG = 6;
int blinkDelay = 250;
int sequenceDir = 0;
int lightLevel = 0;
//Creates a new instance of the BitVoicerSerial class and
//sets up serial port to 0
BitVoicerSerial bitVoicer = BitVoicerSerial(0);
//Starts serial communication and sets up the pinModes
pinMode(pinR, OUTPUT);
pinMode(pinY, OUTPUT);
pinMode(pinG, OUTPUT);
//Retrieves data from serial buffer
bitVoicer.getData();
//Quits the loop if no string data was returned from getData
if (bitVoicer.strData == "")
return;
//Each of the next 'if' statements performs a different
//task based on the data received from BitVoicer
if (bitVoicer.strData == "wake")
digitalWrite(pinR, LOW);
digitalWrite(pinY, LOW);
digitalWrite(pinG, LOW);
digitalWrite(pinR, HIGH);
digitalWrite(pinY, HIGH);
digitalWrite(pinG, HIGH);
delay(200);
delay(200);
delay(200);
delay(200);
delay(200);
bitVoicer.strData = "";
lightLevel = 0;
else if (bitVoicer.strData == "sleep")
delay(200);
delay(200);
delay(200);
lightLevel = 0;
else if (bitVoicer.strData == "RH")
lightLevel = 255;
else if (bitVoicer.strData == "RL")
lightLevel = 0;
else if (bitVoicer.strData == "YH")
lightLevel = 255;
else if (bitVoicer.strData == "YL")
lightLevel = 0;
else if (bitVoicer.strData == "GH")
lightLevel = 255;
else if (bitVoicer.strData == "GL")
lightLevel = 0;
else if (bitVoicer.strData == "blink")
delay(blinkDelay);
delay(blinkDelay);
lightLevel = 255;
else if (bitVoicer.strData == "BF")
blinkDelay = 100;
bitVoicer.strData = "blink";
lightLevel = 255;
else if (bitVoicer.strData == "BFF")
switch (blinkDelay)
case 500:
blinkDelay = 250;
case 250:
blinkDelay = 100;
default:
lightLevel = 255;
else if (bitVoicer.strData == "BS")
blinkDelay = 500;
lightLevel = 255;
else if (bitVoicer.strData == "BSS")
switch (blinkDelay)
case 100:
blinkDelay = 250;
case 250:
blinkDelay = 500;
default:
lightLevel = 255;
else if (bitVoicer.strData == "sequence")
if (sequenceDir == 0)
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
lightLevel = 255;
else if (bitVoicer.strData == "revert")
sequenceDir = 1;
sequenceDir = 0;
bitVoicer.strData = "sequence";
lightLevel = 255;
else if (bitVoicer.strData == "ALLON")
lightLevel = 255;
else if (bitVoicer.strData == "ALLOFF")
lightLevel = 0;
else if (bitVoicer.strData == "brighter")
if (lightLevel < 255)
lightLevel += 85;
analogWrite(pinR, lightLevel);
analogWrite(pinY, lightLevel);
analogWrite(pinG, lightLevel);
else if (bitVoicer.strData == "darker")
if (lightLevel > 0)
lightLevel -= 85;
Serial.println("ERROR:" + bitVoicer.strData);
It uses the BitVoicer Arduino library that can be downloaded from BitSophia’s website (http://www.bitsophia.com).
This is the basic layout of this project. I also added a couple of pictures of the connected wires bellow the layout.
The Voice Schema used in this project can be downloaded from http://www.justbuss.xpg.com.br/BitVoicerTest.zip (you need to have BitVoicer installed in order to open it).
