I'm porting SPI to the STM32 architecture, but I"m having issues with the SPI instance of SPIClass being instantiated or declared
#include <SPI.h>
SPI.begin();
void loop() {}
Gives the error
sketch_nov16a.ino: In function 'void setup()':
sketch_nov16a.ino:7:1: error: 'SPI' was not declared in this scope
Error compiling.
Bascially what I have done is taken the AVR SPI.cpp and SPI.h and copied them to my new hardware folder
hardware\Arduino_STM32\STM32F1XX\libraries\SPI
I know that both the cpp and the .h are both getting compiled and I get this message
Using library SPI in folder: C:\Users\rclark\Documents\Arduino\hardware\Arduino_STM32\STM32F1XX\libraries\SPI (legacy)
But I don't know what this means.
If I put a delibarate error in SPI.CPP or SPI.h I get a compile error
e.g. if I put
aaa bbb;
in SPI.cpp it immediately gives a compile error e.g
C:\Users\rclark\Documents\Arduino\hardware\Arduino_STM32\STM32F1XX\libraries\SPI\SPI.cpp:15:1: error: 'aaa' does not name a type
aaa bbb;
Error compiling.
I really dont understand, why if I take out SPI.begin() it compiles my stub functions, but as soon as I put SPI.begin() into setup, it immediately falls over
I don't think its SPI.cpp or SPI.h are the issue, but here they are.
As they are just the AVR files with all the methods converted into sub functions, just to get it to compile.
ummm unless the problem is just that there is no useful code ???
* Copyright (c) 2010 by Cristian Maglie <c.maglie@bug.st>
* Copyright (c) 2014 by Paul Stoffregen <paul@pjrc.com> (Transaction API)
* SPI Master library for arduino.
* This file is free software; you can redistribute it and/or modify
* it under the terms of either the GNU General Public License version 2
* or the GNU Lesser General Public License version 2.1, both as
* published by the Free Software Foundation.
#include "SPI.h"
//#include "pins_arduino.h"
SPIClass SPI;
uint8_t SPIClass::interruptMode = 0;
uint8_t SPIClass::interruptMask = 0;
uint8_t SPIClass::interruptSave = 0;
#ifdef SPI_TRANSACTION_MISMATCH_LED
uint8_t SPIClass::inTransactionFlag = 0;
#endif
void SPIClass::begin() {
void SPIClass::end() {
void SPIClass::usingInterrupt(uint8_t interruptNumber)
* Copyright (c) 2014 by Matthijs Kooijman <matthijs@stdin.nl> (SPISettings AVR)
#ifndef _SPI_H_INCLUDED
#define _SPI_H_INCLUDED
#include <Arduino.h>
// SPI_HAS_TRANSACTION means SPI has beginTransaction(), endTransaction(),
// usingInterrupt(), and SPISetting(clock, bitOrder, dataMode)
#define SPI_HAS_TRANSACTION 1
// Uncomment this line to add detection of mismatched begin/end transactions.
// A mismatch occurs if other libraries fail to use SPI.endTransaction() for
// each SPI.beginTransaction(). Connect a LED to this pin. The LED will turn
// on if any mismatch is ever detected.
//#define SPI_TRANSACTION_MISMATCH_LED 5
#ifndef LSBFIRST
#define LSBFIRST 0
#endif
#ifndef MSBFIRST
#define MSBFIRST 1
#endif
class SPISettings {
class SPIClass {
public:
// Initialize the SPI library
static void begin();
// If SPI is to used from within an interrupt, this function registers
// that interrupt with the SPI library, so beginTransaction() can
// prevent conflicts. The input interruptNumber is the number used
// with attachInterrupt. If SPI is used from a different interrupt
// (eg, a timer), interruptNumber should be 255.
static void usingInterrupt(uint8_t interruptNumber);
// Before using SPI.transfer() or asserting chip select pins,
// this function is used to gain exclusive access to the SPI bus
// and configure the correct settings.
inline static void beginTransaction(SPISettings settings)
// Write to the SPI bus (MOSI pin) and also receive (MISO pin)
inline static uint8_t transfer(uint8_t data) {
return 0;
inline static uint16_t transfer16(uint16_t data) {
return 0;
inline static void transfer(void *buf, size_t count) {
// After performing a group of transfers and releasing the chip select
// signal, this function allows others to access the SPI bus
inline static void endTransaction(void) {
// Disable the SPI bus
static void end();
// This function is deprecated. New applications should use
// beginTransaction() to configure SPI settings.
inline static void setBitOrder(uint8_t bitOrder) {
inline static void setDataMode(uint8_t dataMode) {
inline static void setClockDivider(uint8_t clockDiv) {
// These undocumented functions should not be used. SPI.transfer()
// polls the hardware flag which is automatically cleared as the
// AVR responds to SPI's interrupt
inline static void attachInterrupt() { }
inline static void detachInterrupt() { }
private:
static uint8_t interruptMode; // 0=none, 1=mask, 2=global
static uint8_t interruptMask; // which interrupts to mask
static uint8_t interruptSave; // temp storage, to restore state
static uint8_t inTransactionFlag;
#endif
extern SPIClass SPI;
#endif
