I have just updated the repository README with two new sections explaining how the Custom Brick works internally and why an HTTP service is used.
The goal is to make the architecture easier to understand, especially for readers who are discovering App Lab Custom Bricks for the first time.
Why does this custom Brick use a Docker service and an HTTP API?
A common question is:
Why not access /dev/spidev0.0 directly from main.py?
The answer is that Arduino App Lab applications run in a managed environment that does not necessarily have direct access to all Linux devices, system packages, or kernel interfaces.
In this proof of concept:
MCU
SPI3
/dev/spidev0.0
Docker service
HTTP API
App Lab Python code
The custom Brick creates a dedicated Linux service running inside a container.
This service:
- has access to
/dev/spidev0.0
- installs and uses
python3-spidev
- communicates directly with the SPI3 interface
- exposes a simple HTTP API
The App Lab Python code does not need to know how SPI transactions are performed. It simply calls:
spi = SPI3()
value = spi.read_float()
values = spi.read_floats()
The Brick acts as an abstraction layer between the App Lab application and the Linux SPI device.
This approach provides several advantages:
- keeps the App code simple
- isolates Linux-specific dependencies
- makes the functionality reusable across multiple projects
- follows the philosophy of App Lab Bricks as reusable building blocks
The same architecture could be used for many other Linux resources, such as:
- ALSA audio devices
- GPS receivers
- serial ports
- I2C devices
- network services
- custom hardware interfaces
The SPI3 proof of concept demonstrates one practical example of this pattern.
Why use an HTTP server?
Some readers may wonder why this project uses an HTTP server.
The answer is simple:
The HTTP server is not used to create a website.
It is only used as a communication channel between two Python programs running on the Linux MPU.
Think of it this way:
App Lab Python
| "Please give me the SPI3 values"
v
SPI3 Service
| Reads /dev/spidev0.0
v
SPI3 Hardware
The HTTP request is simply a message sent from one program to another.
For example:
spi.read_floats()
internally becomes:
GET /values
The SPI3 service receives this request, reads the SPI3 interface, and sends the result back.
The App Lab application then receives the values and continues normally.
Why use HTTP?
Because it is:
- simple
- reliable
- easy to debug
- supported by standard Python libraries
The HTTP server is only running locally inside the UNO Q Linux environment.
No Internet connection is required.
You can think of it as a "messenger" between the App Lab application and the Linux service that has access to the SPI3 device.
