UNO Q: Sharing Knowledge, Tips, and Practical Skills
1. Safe Shutdown of UNO Q Board (from within App Lab)
Procedures:
(1) Stop the application in the App Lab
(2) Bring in "shell terminal" by clicking on >_ icon of the App Lab window.
(3) Type this command: sudo shutdown -H now and press the Enter key.
(4) Enter the Linux password (characters are not seen) and press the Enter key.
After you enter the password, Linux starts the shutdown process, which includes closing any open files and saving critical data to the eMMC storage. The UNO Q starts rebooting, showing an animation on the LED matrix.
(5) While the animation is ongoing, take out the USB cable from the PC.
2. Blinking "red:user" led of "RGB LED 1" of UNO Q Board using App Lab
1. In Fig-1, it is seen that there are four RGB leds marked as QRB: 1 2 and STM: 3 4. The "red:user" led is under QRB: 1.
2. The red:user led is connected with an IO line (GPIO_41) of the QRB2210 Microprocessor of the UNO Q board. The connection diagram of the led is shown in Fig-2:
3. The red:user led becomes On when LOW is sserted on the cathode terminal of the LED. This is the reason for calling the led an "active low led".
Figure-1:
Figure-2:
4. Program to blink LED1_R
The MPU controls the LED under the guidance of a program, whose execution is managed by the resident Linux operating system of the QRB2210 MPU. We will write this program using the Python programming language and then upload it using App Lab to the eMMC storage of the UNO Q board. A program written in Python is referred to as a script.
In Linux, the red:user LED is exposed as a writable file through the sysfs interface. Writing 0 to this file turns the LED ON, while writing 1 turns it OFF, as the LED is connected as active-low device.
Script:(tested on 3/5/26)
import time
LED1_R = "/sys/class/leds/red:user/brightness"
LED1_G = "/sys/class/leds/green:user/brightness"
LED1_B = "/sys/class/leds/blue:user/brightness"
LED2_R = "/sys/class/leds/red:panic/brightness"
LED2_G = "/sys/class/leds/green:wlan/brightness"
LED2_B = "/sys/class/leds/blue:bt/brightness"
def set_led_brightness(led_file, value):
    try:
        with open(led_file, "w") as f:
            f.write(f"{value}\n")
    except Exception as e:
        print(f"Error writing to {led_file}: {e}")
def main():
  # turn off all LEDs
  set_led_brightness(LED1_R, 0)
  set_led_brightness(LED1_G, 0)
  set_led_brightness(LED1_B, 0)
  set_led_brightness(LED2_R, 0)
  set_led_brightness(LED2_G, 0)
  set_led_brightness(LED2_B, 0)
  while True: #keep executing the sub-ordinated lines repeatedly
   #blink the LED1_R (RED) segment
    set_led_brightness(LED1_R, 1) #led is Off
    time.sleep(1) #wailt for 1-sec
    set_led_brightness(LED1_R, 0) #led is On
    time.sleep(1)
if __name__ == "__main__": #Python framework to run main() only for once
    main()
5. Now, create a new App inside Arduino App Lab inder title: Blink LED1_R and then copy/paste the script of Step-4 in the python section of your application.
6. Click on the Run button of App Lab and check that LED1_R is blinking at 2-sec interval.
7. Description of the working principles of the python script of Step-4
(1) Summary:
The time module of Python package is included in the script.
File paths for the Linux files for the six led devices (red:user to blue:bt) are saved into six variables: LED1_R to LED2_B.
A function named set_led_brightness() is declared and defined for subsequent writing of LOW/HIGH into briggtness files. The function contains file openining/writing methods.
A function named main() is declared and defined to shut off all the leds. After that the red:user led is continuously blinked.
(2) Detailed Description:
(a) Mening of: LED1_R = "/sys/class/leds/red:user/brightness"
  • "/sys/class/leds/red:user/brightness": This is the file path in Linux. Linux exposes hardware components as files, known as "sysfs" entries. That means hardware devices appear as files.
  • LED1_R: It is a variable that stores the path to the above file.
  • brightness: This is the Linux file (name) into which we write 0 (LOW) to turn On the red:user led and writes 1 (HIGH) to turn Off the red:user led. The led is configured as "active-low" (Fig-2).
3. Continuous Blinking of LED1/2_RGB and LED3/4_RGB
Working Principle: MPU blinks LED1_R/G/B, L2_R/G/B and then instructs the MCU to blink is LED3_R/G/B, LED4_R/G/B. MCU finishes blinking and then instructs MPU to blink its leds. The cycle repeats this way. The commands excage takes place via Brdge.call()/Bridge.provide() functions over the Router Bridge.
The example is given below (tested):
Sketch:
#include<Arduino_RouterBridge.h>
String startBlink(String str)
  if(str == "blinkled34")
        digitalWrite(LED3_R, LOW);   //LED On active LOW
        digitalWrite(LED3_R, HIGH);
        digitalWrite(LED3_G, LOW);
        digitalWrite(LED3_G, HIGH);
        digitalWrite(LED3_B, LOW);
        digitalWrite(LED3_B, HIGH);
        digitalWrite(LED4_R, LOW);
        digitalWrite(LED4_R, HIGH);
        digitalWrite(LED4_G, LOW);
        digitalWrite(LED4_G, HIGH);
        digitalWrite(LED4_B, LOW);
        digitalWrite(LED4_B, HIGH);
        return "blink12";
  Bridge.begin();
  delay(5000);
  pinMode(LED3_R, OUTPUT);
  pinMode(LED3_G, OUTPUT);
  pinMode(LED3_B, OUTPUT);
  pinMode(LED4_R, OUTPUT);
  pinMode(LED4_G, OUTPUT);
  pinMode(LED4_B, OUTPUT);
  digitalWrite(LED3_R, HIGH); //LED off; active LOW
  Bridge.provide("start_blink", startBlink);
Script:
import time
from arduino.app_utils import App, Leds, Bridge
def loop():
    # Turn on the LED red segment (1, 0, 0)
    Leds.set_led1_color(1,0,0)
    time.sleep(1)
    Leds.set_led1_color(0,0,0)
    time.sleep(1)
    # Turn on the green LED segment (0, 1, 0)
    Leds.set_led1_color(0,1,0)
    time.sleep(1)
    time.sleep(1)
    # Turn on the blue LED segment (0, 0, 1)
    Leds.set_led1_color(0,0,1)
    time.sleep(1)
    time.sleep(1)
    Leds.set_led2_color(1,0,0)
    time.sleep(1)
    Leds.set_led2_color(0,0,0)
    time.sleep(1)
     # Turn on the LED green segment (0, 1, 0)
    Leds.set_led2_color(0,1,0)
    time.sleep(1)
    time.sleep(1)
    Leds.set_led2_color(0,0,1)
    time.sleep(1)
    time.sleep(1)
    while Bridge.call("start_blink", "blinkled34",timeout=20) != "blink12":
        pass  # Do nothing, immediately loop back and check again
App.run(user_loop=loop)
Note:
1. Within 20 sec if "blink12" comes from MCU, the control will transfer to App.run() causing MPU to blink LED3/4_R/G/B.
2. Within 20 sec if "blink12" does not comes from MCU, the control will transfer to Operating System bypassing the App.run() framework.
3. How can the above script be modified so that control goes to App.run() even though "blink12" does not come from MCU within 20 sec?
4. Modulating LED3_RGB
  pinMode(50,OUTPUT);
  digitalWrite(50,HIGH);
  int16_t RGBled = 50;
  for (int16_t i = 0; i < 200; i++) {
    analogWrite(RGBled,i);
    delay(20);
  analogWrite(RGBled,0);
  RGBled++;
    delay(20);
  RGBled++;
    delay(20);
  RGBled++;
5. Operation of UNO Q board using WiFi Network Connection** and NOT USB Connection
The intentional design of Arduino App Lab is to give preference to the USB connection if available. So if the board is discovered via the USB data cable connection, Arduino App Lab shows that connection.
If you power the UNO Q using USB power cable (D+ and D- wires are absent) from your computer and when you open Arduino App Lab you should then see the network connection to the board is shown:
1. I have powered my UNO Q from PC using a USB-C power/charger cable (D+, D- lines are absent).
2. I have opened App Lab.
3. Yes! The network connection window has appeared.
4. I have clicked on ArduinoQ. As a result, the App Lab window has appeared.
5. I have opened my LEDR_3RBlink app and clicked on the Run button. The app is running showing a blinking led on the UNO Q board.
6. Hardware and Software resources needed to operate/program the Arduino UNO Q Board in "PC Host Mode"
D1: Hardware Resources
1. Arduino UNO Q Board (2 GB/16 GB or 4 GB/32 GB)
Purpose:
2. USB-A to USB-C data cable
Purpose:
3. PC with Windows 10+ (for me)
Purpose:
4. Internet connectivity
Purpose:
8.
... in progress
D2: Software Resources
1. IDE 2.3.8+
Purpose:
2. Board Package aka Hardware Core aka Platform aka arduino:zephyr aka UNO Q Zephyr Core
  • It is a software package that is installed in PC hard disk and in MCU flash using BOARDS MANAGER interface of the IDE.
  • The software allows the MCU of the UNO Q board to handle I/O, sensors, and actuators instantly upon booting.
3. Libraries
When install the "Arduino_RouterBridge" library via LIBRARY MANAGER interface, Arduino IDE will open an "Install library dependencies " dialog offering to install the other libraries. This is because they are specified as dependencies via the "Arduino_RouterBridge" library's metadata. So the user only needs to be sure to Click the "INSTALL ALL " button in that dialog in order to obtain installations of those other libraries.
  • Arduino_RouterBridge.h
    Purpose:
    • Its primary purpose is to act as a Remote Procedure Call (RPC) bridge, enabling seamless data exchange between the board's two distinct processors: 64-bit QBR2210 MPU and 32-bit STM32U585 MCU.
  • Arduino_RPClite.h
  • MsgPack.h
  • DebugLog.h
  • ArxTypeTraits.h
  • ArxContainer.h
7.G Header Pins mapping
Have you tried Fig-2 of post #2. It works.
H: Internal Communication Link between MCU and MPU
Figue-1:
In Fig. 1 above, we can see four communication buses (Bus-2 does not exist). Among them, Bus-3, which is the Serial Wire Debug (SWD) bus, is dedicated to programming the MCU flash memory with code and data.
Bus-4, which appears as ttyHS1/UART2 on the MPU side and LPUART1/Serial2 on the MCU side, is dedicated to the Router Bridge for high-volume data exchange between the MPU and MCU.
This leaves Bus-5, which you can use for high-speed data exchange between the MPU and MCU. It is based on the SPI interface. To use this bus, you need to write a C++ sketch for the MCU side and a Python script for the MPU side to exchange data. You may find this thread @philippe86220 interesting.
I: Binary Breakdown of information traveling over the Router Bridge
The Complete Binary Breakdown of the arguments (tag_name, data items) of:
Bridge.call("get_data", 0x1234, 1.57, "Forum");
When serialized by MsgPack.h, the entire transmission packet expands to look like this:
  • 94 Outer Array of 4 items [type, msgid, tag, params]
    • 00 type: 0 (Request)
    • 01 msgid: 1 (The identifier)
    • A8 67 65 74 5F 64 61 74 61 TAG: String of length 8 ("get_data")
    • 93 params: Inner Array of 3 items [0x1234, 1.57, "Arduino"]
      • CD 12 34 Unsigned 16-bit Int (0x1234)
      • CA 3F C8 F5 C3 32-bit Float (1.57)
      • A5 46 6F 72 75 6D String of length 5 ("Forum"`)
8.J* Sending int float and string data items by MCU to MPU using Router Bridge
sketch:
  Bridge.begin();
  delay(5000);
  Bridge.call("get_data", 1234, 12.37, "Green");
script:
import time
from arduino.app_utils import App, Bridge
print("Hello world!")
def getData(y, z, msg):
    print(y)
    print(z)
    print(msg)
    print("----------------------")
def main():
    Bridge.provide("get_data", getData)
    while True:
       time.sleep(10)
    main()
Output:
1234
12.37
Green
1234
12.37
Green
9. Timeout if Acknowledgement does not arrive from MPU in a given time-window
Sketch:
bool status = false;
String value = "";
unsigned long prMillis = millis();
   Bridge.begin();
   Monitor.begin();
   do
      RpcCall rpc = Bridge.call("is _linux_ready");
      status = rpc.result(value);
   while((status != true) && (millis() - prMillis) < 5000);
   if(status == true)
      Monitor.print(value);//Linux is ready
      while(true) //error at Linux side
        digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN);
Script:
from arduino.app_utils import *
import time
#used only for sync purposes
def linux_started():
  return "Linux is ready"
Bridge.provide("is _linux_ready", linux_started)
def loop():
  time.sleep(1)
#include "Arduino_RouterBridge.h"
  // Initialize communication layer
  Bridge.begin();
  bool status = false;  //will turn to true when message comes from MPU
  String value = ""; //value will be loaded with message that comes from MPU
  do
      RpcCall rpc = Bridge.call("get_data", 0x1234, 1.57, "Forum");
  while((status != true) && (millis() - prMillis < 20));  //timeout: 20 ms
  Monitor.print("Elapsed time: ");  //measuring response time or timeout period
  Monitor.print(millis() - prMillis);  Monitor.println(" ms");
  if(status == false)
    Monitor.println("Communication error!");
    while(true)     //wait for ever
      Monitor.println("I'm in the error loop");
    Monitor.println(value); //shows: Communication is ok!
10. Serial Communication Ports of STM32U585 MCU
(1) USART1 : Serial1 on DPin-0, 1 = RX/TX
(2) USART2
(3) USART3
(4) UART4
(5) UART5
(6) LPUART1 : Serial2 on Router Brigde
(7) LPUART2
M: Delaying MCU until MPU/Linux is
String value = "";
   Bridge.begin();
   Monitor.begin();
   do
   if(status == true)
11. Here is an example of a four thread sketch which blinks four onboard LEDs at different rates under App Lab
The App
Sketch:
#include <Arduino.h>
#include <zephyr/kernel.h>
#include <Arduino_RouterBridge.h>
#define STACK_SIZE 1024
#define LED_PRIO3r 5
#define LED_PRIO4r 5
#define LED_PRIO4g 5
#define LED_PRIO4b 5
static struct k_thread led3r_thread;
static struct k_thread led4r_thread;
static struct k_thread led4g_thread;
static struct k_thread led4b_thread;
K_THREAD_STACK_DEFINE(led3r_stack, STACK_SIZE);
K_THREAD_STACK_DEFINE(led4r_stack, STACK_SIZE);
K_THREAD_STACK_DEFINE(led4g_stack, STACK_SIZE);
K_THREAD_STACK_DEFINE(led4b_stack, STACK_SIZE);
void led3r_task(void *, void *, void *) {
  while (1) {
    k_msleep(500);
    k_msleep(500);
void led4r_task(void *, void *, void *) {
  while (1) {
    digitalWrite(LED4_R, !digitalRead(LED4_R));
    k_sleep(K_SECONDS(1));
void led4g_task(void *, void *, void *) {
  while (1) {
    digitalWrite(LED4_G, !digitalRead(LED4_G));
    k_sleep(K_SECONDS(2));
void led4b_task(void *, void *, void *) {
  while (1) {
    digitalWrite(LED4_B, !digitalRead(LED4_B));
    k_sleep(K_SECONDS(3));
  Bridge.begin();
  Monitor.begin();
  delay(5000);
  k_thread_create(&led3r_thread,
                  led3r_stack,
                  STACK_SIZE,
                  led3r_task,
                  NULL, NULL, NULL,
                  LED_PRIO3r,
                  0,
                  K_NO_WAIT);
  k_thread_create(&led4r_thread,
                  led4r_stack,
                  STACK_SIZE,
                  led4r_task,
                  NULL, NULL, NULL,
                  LED_PRIO4r,
                  0,
                  K_NO_WAIT);
  k_thread_create(&led4g_thread,
                  led4g_stack,
                  STACK_SIZE,
                  led4g_task,
                  NULL, NULL, NULL,
                  LED_PRIO4g,
                  0,
                  K_NO_WAIT);
  k_thread_create(&led4b_thread,
                  led4b_stack,
                  STACK_SIZE,
                  led4b_task,
                  NULL, NULL, NULL,
                  LED_PRIO4b,
                  0,
                  K_NO_WAIT);
  Bridge.call("get_data", 1234, 12.37, "Green");  //tag, 3 datae items
  delay(1000);   //repeating intervals
  //k_sleep(K_FOREVER);
Script:
import time
    print(y)
    print(z)
    print(msg)
def main():
    while True:
       time.sleep(10)
    main()
Output on Python Console:
1234
12.37
Green
1234
12.37
Green
1234
12.37
Green
1234
12.37
Green
##12. Docker Container's Private Mini Filesystem**
Comments are welcome regarding the conceptual accuracy of the following explanation, rather than strict technical definitions. Feel free to elaborate on any points if helpful. This is an expanded summary based on the insights shared by @ptillisch in post #14 of this thread.
  1. My app/project named adcWrite, created using App Lab, is automatically saved in the following directory on the eMMC of the host Linux OS: /home/arduino/ArduinoApps/adcWrite/
  2. In my app, the Python script periodically writes data to a file named adc.txt using the absolute path inside the container: FILE_PATH = "/home/arduino/adc.txt"
  3. The /home/arduino/ directory referenced in Step 2 is a pre-configured directory that belongs to the container's private mini filesystem (writable layer) residing on the eMMC. It is completely isolated from the host Linux OS's /home/arduino directory, even though both have used the same directory name. The identical naming convention is not a coincidence but a design convenience, as is known from AI.
  4. While the app is running, adc.txt is not visible when exploring the host's /home/arduino/ directory via a host shell terminal. The Files Panel of App Lab also does not display adc.txt.
  5. The container’s private /home/arduino/ directory serves as temporary storage. The adc.txt is permanently lost whenever the container is removed, rebuilt, or re-deployed.
  6. If I use FILE_PATH = "/app/adc.txt" in place of FILE_PATH = "/home/arduino/adc.txt" in the Python script, then writing to /app/adc.txt indeed places the data directly into /home/arduino/ArduinoApps/adcWrite/adc.txt on the host eMMC. Data is not written into /app/adc.txt; instead, /app/adc.txt works as a pointer to the project folder on the host eMMC.
  7. /app/ is a pre-configured directory inside the container's Private Mini Filesystem linked to the host project folder (/home/arduino/ArduinoApps/adcWrite/). Writing to /app/adc.txt bypasses the container's private layer and writes directly to physical host eMMC storage. Consequently, if the container is removed, rebuilt, or deleted, adc.txt remains safely intact on the host OS eMMC.
... in progress
Tip: You can see additional options and short usage help of any Linux command if you enter man followed by command name.
To see info about shutdown try man shutdown
What is the purpose of this if whatever you do, the terminal will logout automatically?
Is there not a "shutdown -now" option?
To observe the automatic logout, I have to wait for about a minute, after which the board immediately reboots. Therefore, after issuing the shutdown command, I wait for 15–20 seconds, then issue the logout command, and finally unplug the USB cable when the Windows prompt appears.
AI says not issue logout command but wait for about 20-30 sec after shutdown command and then unplug the USB cable. What is @b707 opinion and accordingly I will revise my post #1?
Please see the first part of my answer - there is an option to do shutdown immediately rather than wait or issue additional commands.
-now is not recognized.
Please read the manual, the correct syntax is shutdown -H now
Please, tell me what to do --?
1. I STOP app.
2. I click on >_ button
3. I type what --
you have said to enter man followed by command -- which I have not understood.
Nope.
I don't interfere with your actions before the shutdown command, I only comment on the last command from the Linux point of view
Try the #7
Sorry it's been a while since I used any *nix, the memory is failing. As well as heavy use of man, I love apropos since I often only know the ballpark but not the row and seat. I hope that command is still there. @GolamMostafa
My main home desktop OS is a Linux
In all *nix systems I have ever used there is a command called man which is short for manual. It is the help system. On my M5 MacBookPro I went into terminal which is BSD Unix and did a man man, help on help, here is the output.
I have take this command: sudo shutdown -H from this thread post #6:
Did you read the manual?
The sudo shutdown -H now do the same as yours sudo shutdown -H, the only difference that the parameter now instruct the command to start immediately.
To to start immediately what -- (the) sudo shutdown -H command? If now is not appended, how long waiting there will be?
Please note that I had been concerned about the proper shutdown procedure following the premature failure of my first UNO Q board. I believe that the failure may have occurred because I did not follow the correct shutdown procedures.
I have seen that sudo shutdown -H command works, and I am happy. By the by, what is the full name for sudo and what does it do?
yes
default timeout is 1 minute
All this is in the command description; in Linux, it is a good habit to use the man command instead of asking.
do you not to know how to use the Googe???
Someone has said in some other thread that Google is wrong. So, it is reliable to hear from an experienced a person.
This is exacltly what I counted (~ 60 sec) for the automatic logout to happen after iussing the shutdown command.
Superuser do
I remember it as, source user do once..
it's runs the command as the root user (highest privileges)..
~q
sudo can be deciphered as "do it as su" - that is, execute the command as the superuser. The details see in the manual.
PS I see @qubits-us already answered this
