Greetings to all friends. I am working on a project to create a speedometer test tool to be able to work on the workbench. So far I have succeeded in making a simulation for the Yamaha speedometer which can move the rpm bar and move the speed. You need to know that for the Yamaha speedometer type to be able to control the speedometer, it is all done by the ecu / ecm on the motorbike. Through a single cable for data. For now I am working on the rest is someone who can help for honda.suzuki.and.kawasaki how the ECU / ecm communicates with the speedometer.
Greetings to all friends. I am working on a project to create a speedometer test tool to be able to work on the workbench. So far I have succeeded in making a simulation for the Yamaha speedometer which can move the rpm bar and move the speed. You need to know that for the Yamaha speedometer type to be able to control the speedometer, it is all done by the ecu / ecm on the motorbike. Through a single cable for data. For now I am working on the rest. Is [there] someone who can help for honda, suzuki, and kawasaki how the ECU / ecm communicates with the speedometer.
I have deleted your other post on the same subject. It even had the same wrong use of code tags !
Crossposting is against the Arduino Forum rules. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Repeated crossposting can result in a suspension from the forum.
In the future, please only create one topic for each distinct subject matter. This is basic forum etiquette, as explained in the "How to get the best out of this forum" guide. It contains a lot of other useful information. Please read it.
help with what?
do you have some code that works? can you post it?
what is the ecu/ecm? what is the interface?
is it different for different bike manufacturers?
