SPIFFS write/read problem with byte array
Here is a simple code where I write to file two bytes (233 and 78). Then I want to read them back, but instead of getting 233 and 78 I get characters 2,3,3,7,8. Of course, it's not the data at all and of course I can try to use some delimiter (",") to separate bytes from each other. But!!! I'm using SPIFFs to store a firmware.bin file that is supposed to be LARGE. This is why I'm using SPIFFS in the first place. And increasing the size of the file even more by using a delimiter is a VERY bad idea.
I googled, but I couldn't find a way to write bytes to SPIFFs.
uint16_t byte1 = 233;
  uint16_t byte2 = 78;
  Serial.println("Writing to file");
  File file = SPIFFS.open("/firmware.bin", "w");
  if (!file)
    Serial.println("Error opening file for writing");
    return;
  file.print((uint16_t)byte1);
  file.print((uint16_t)byte2);
  file.close();
  Serial.println("Written");
  Serial.println("Reading...");
  File file2 = SPIFFS.open("/firmware.bin", "r");
  if (!file2)
    Serial.println("Failed to open file for reading");
    return;
  while (file2.available())
    Serial.write(file2.read());
    Serial.write("|");
  Serial.println("Read");
  file2.close();
Writing to file
Written
Reading...
2|3|3|7|8|Read
Writing to file
Written
Reading...
233|78|Read
#include "FS.h"
#include "SPIFFS.h"
void setup(){
  SPIFFS.begin();
uint8_t byte1 = 233;
uint8_t byte2 = 78;
  if (!file)
    return;
  file.write(byte1);
  file.write(byte2);
  file.close();
  if (!file2)
    return;
    Serial.print(file2.read(),DEC);
    Serial.write('|');
  file2.close();
void loop() {}
print() converts numbers into their ascii representation so 78 turns into '7' '8'
write() does not do this conversion so numbers are written as-is.
