I now have quite a long code for my carrier OS. So that this is clearer, I would like to split it up into several parts, i.e. files. Is the? How do I do that?
I have an MKR IoT Carrier Rev2 and MKR WiFi 1010 board.
Many, many thanks in advance!
#include <WiFiNINA.h>
#include <Arduino_MKRIoTCarrier.h>
#include <WiFiUdp.h>
#include <NTPClient.h>
#include <TimeLib.h> // Include the TimeLib library
#include <FastLED.h>
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP);
MKRIoTCarrier carrier;
float temperature = 0;
float humidity = 0;
unsigned long lastTempUpdate = 0;
int currentPage = 0;
bool inSubMenu = false;
int subMenuPage = 0;
bool ledState = false;
int brightness = -10;
void printDashboard() {
timeClient.update();
if (timeClient.getSeconds() == 0) {
String formattedTime = timeClient.getFormattedTime().substring(0, 5);
setTime(timeClient.getEpochTime());
String formattedDate = String(day()) + "." + String(month()) + "." + String(year());
int16_t x1, y1, x2, y2;
uint16_t w1, h1, w2, h2;
uint16_t width = carrier.display.width();
uint16_t height = carrier.display.height();
uint8_t r, g, b;
if (hour() >= 5 && hour() < 7) {
for (int y = 0; y < height; y++) {
r = map(y, 0, height-1, 255, 255);
g = map(y, 0, height-1, 255, 128);
b = map(y, 0, height-1, 0, 0);
carrier.display.drawFastHLine(0, y, width, carrier.display.color565(r, g, b));
carrier.display.setTextColor(ST77XX_BLACK);
} else if (hour() >= 20 || hour() < 4) {
// set background color to gradient from dark blue to black
r = map(y, 0, height-1, 0, 0);
g = map(y, 0, height-1, 0, 0);
b = map(y, 0, height-1, 64, 0);
carrier.display.setTextColor(ST77XX_WHITE);
else {
r = map(y, 0, height-1, 255, 0);
g = 0;
b = map(y, 0, height-1, 0, 255);
carrier.display.setTextSize(3);
carrier.display.getTextBounds(formattedDate, 0, 0, &x1, &y1, &w1, &h1);
carrier.display.setTextSize(4);
carrier.display.getTextBounds(formattedTime, 0, 0, &x2, &y2, &w2, &h2);
x1 = (carrier.display.width() - w1) / 2;
y1 = (carrier.display.height() - h1 - h2 - h2) / 2;
x2 = (carrier.display.width() - w2) / 2;
y2 = y1 + h1 + h2;
carrier.display.setCursor(x1, y1);
carrier.display.println(formattedDate);
carrier.display.setCursor(x2, y2);
carrier.display.println(formattedTime);
void printTemperature() {
carrier.display.fillScreen(ST77XX_BLUE);
carrier.display.setTextSize(2);
int16_t x, y;
uint16_t width, height;
String tempStr = "Temp: " + String(temperature) + " C";
carrier.display.getTextBounds(tempStr, 0, 0, &x, &y, &width, &height);
carrier.display.setCursor((carrier.display.width() - width) / 2, (carrier.display.height() - height) / 2);
carrier.display.print(tempStr);
void printHumidity() {
carrier.display.fillScreen(ST77XX_GREEN);
int16_t x, y;
String humidityStr = "Humidity: " + String(humidity) + " %";
carrier.display.getTextBounds(humidityStr, 0, 0, &x, &y, &width, &height);
carrier.display.print(humidityStr);
void printWeather() {
carrier.display.fillScreen(ST77XX_YELLOW);
int16_t x, y;
carrier.display.getTextBounds("Weather", 0, 0, &x, &y, &width, &height);
carrier.display.print("Weather");
void printSettings() {
carrier.display.fillScreen(ST77XX_MAGENTA);
int16_t x, y;
carrier.display.getTextBounds("Settings", 0, 0, &x, &y, &width, &height);
carrier.display.print("Settings");
void printLight() {
carrier.display.fillScreen(ST77XX_ORANGE);
int16_t x, y;
String text = "LED: ";
// Check if button 0 is pressed
if (digitalRead(0) == HIGH) {
// Increase brightness by 10% until it reaches 100%
brightness += 10;
if (brightness > 100) {
// Reset brightness to 0%
brightness = 0;
ledState = false;
ledState = true;
ledState = false; // Turn off the LED if button 0 is not pressed
if (ledState) {
text += "ON";
text += "OFF";
carrier.display.getTextBounds(text, 0, 0, &x, &y, &width, &height);
carrier.display.print(text);
if (ledState) {
// Set the LED brightness according to the global variable
carrier.leds.fill(CRGB::White);
carrier.leds.setBrightness(brightness);
carrier.leds.show();
// Set the LED color to black
carrier.leds.fill(CRGB::Black);
// Start sound
carrier.Buzzer.sound(523);
delay(200);
carrier.Buzzer.sound(659);
delay(200);
carrier.Buzzer.sound(784);
delay(200);
carrier.Buzzer.sound(880);
delay(200);
carrier.Buzzer.sound(1047);
delay(600);
carrier.Buzzer.noSound();
CARRIER_CASE = false;
carrier.begin();
temperature = carrier.Env.readTemperature();
humidity = carrier.Env.readHumidity();
carrier.display.setRotation(0);
const char* ssid = "XXX";
const char* password = "XXX";
// Serial.begin(9600);
carrier.display.fillScreen(ST77XX_BLACK);
// Connect to Wi-Fi network with SSID and password
// Serial.print("Connecting to ");
// Serial.println(ssid);
WiFi.begin(ssid, password);
// Serial.println("Connecting to WiFi...");
timeClient.begin();
// Set time offset to your local timezone in seconds
timeClient.setTimeOffset(7200);
printDashboard();
if (carrier.Buttons.onTouchDown(TOUCH0)) {
if (inSubMenu && currentPage == 2 && subMenuPage == 0) {
ledState = !ledState;
printLight();
else if (currentPage == 2) {
inSubMenu = true;
subMenuPage = 0;
printLight();
carrier.Buttons.update();
unsigned long now = millis();
if(now - lastTempUpdate > 60000){
lastTempUpdate = now;
if (carrier.Buttons.onTouchDown(TOUCH2)) {
currentPage = 0;
inSubMenu = false;
printDashboard();
else if (carrier.Buttons.onTouchDown(TOUCH1) || carrier.Buttons.onTouchDown(TOUCH3)) {
if (!inSubMenu) {
currentPage = (currentPage + 1) % 4;
switch(currentPage) {
case 0:
printDashboard();
case 1:
printWeather();
case 2:
printSettings();
else {
subMenuPage = (subMenuPage + 1) % 2;
case 1:
switch(subMenuPage) {
case 0:
printTemperature();
case 1:
printHumidity();
case 2:
case 0:
printLight();
case 1:
printTemperature();
else if (carrier.Buttons.onTouchDown(TOUCH4)) {
if ((currentPage == 1 || currentPage ==2) && !inSubMenu) {
inSubMenu = true;
subMenuPage = (subMenuPage + 1) %2;
case 1:
case 0:
printTemperature();
case 1:
printHumidity();
case 2:
case 0:
printLight();
case 1:
printTemperature();
else if (inSubMenu) {
inSubMenu = false;
case 1:
printWeather();
case 2:
printSettings();
