Hello all! I've just spent... too long coding this, and I was wondering if there was an easier way... Or if perhaps this code could be simplified...
static int countInstances(String haystack, char needle) {
int count = 0;
for(int i=0; i < haystack.length(); i++) {
if(haystack.charAt(i) == needle) count++;
return count;
static void splitString(String haystack, char needle, int count, String output[]) {
int startpos = 0;
for(int i=0; i < count; i++) {
int i2;
for(i2=startpos; i2 < haystack.length(); i2++) {
if(haystack.charAt(i2) == needle) break;
output[i] = haystack.substring(startpos, i2);
startpos = i2+1;
output[count] = haystack.substring(startpos);
String input = "This,is,a,test";
char delimeter = ',';
int count = countInstances(input, delimeter);
String TestArray[count+1]; // Add one so that the element on the end doesn't cause the world to end...!
splitString(input, delimeter, count, TestArray);
// Do something with it:
Serial.print("Length of Array: ");
Serial.println(sizeof(TestArray) / sizeof(String));
for(int i = 0; i < (sizeof(TestArray) / sizeof(String)); i++) {
Serial.print("\"");
Serial.print(TestArray[i]);
Serial.print("\" ");
// Someone set up us the bomb.
for(;;);
Thanks!
