Splitting incoming strings !?
Hello everyone!
I will be sending strings ( ex: "CODE;25") from VB.NET to arduino and i need to split that string in half so the arduino serial monitor will return something like this:
h1- CODE
h2- 25
I've done some research but im still a bit confused, im new to arduino and this is a little overwhelming to me, but ive managed to split defined strings/chars (ex ; char sz[] = "CODE;25", then i can use the semicolon as the delimiter and split the words, but im a bit lost on how to do that with the incoming serial strings.
Any guidance would be welcome! thanks!
You can read the string into a char array as a buffer and when you've read the whole string, use strtok to split it at the semicolon. How do you know when you've read the whole string though - does your VB code send a newline or other end of string marker?
Since you're writing the VB code (I assume), consider making your packets look like this:
<CODE;25>
Then you've got a start of packet marker and one for the end. Then you can parse the data as you receive it:
throw chars away until you see '<'
read chars into h1 array until you see ';'
read chars into h2 array until you see '>'
Don't forget to null terminate the arrays and to check that you're not overflowing h1 or h2.
The examples in serial input basics show how to receive the data and also how to parse the received data.
...R
If more than one set of codes is coming in as a single stream, wildbill's solution is a good idea with the packet markers. If only one set comes in at a time, then you can use strchr() to partition the incoming string:
  char incomingMsg[20];            // size as needed
  char codeBuff[10];
  char number[5];
  char *index;
  int charsRead;
  Serial.begin(115200);   // Make sure yours matches
  while (true) {
    if (Serial.available() > 0) {
      charsRead = Serial.readBytesUntil('\n', incomingMsg, sizeof(incomingMsg) - 1);
      incomingMsg[charsRead] = '\0';  // Make it a string
      Serial. print("  incomingMsg = ");    // Debug statement
      Serial.println(incomingMsg);
      index = strchr(incomingMsg, ';');
      *index = '\0';                             //Make a string
      strcpy(codeBuff, incomingMsg);
      strcpy(number, index + 1);
      Serial.print("Code = ");              // Debug statements
      Serial.print(codeBuff);
      Serial. print("  number = ");
      Serial.println(number);
If you type in "code;25", the codeBuff should equal code and number should equal 25
wildbill:
<CODE;25>
To answer your question, yes i send newline to know that i´ve read the entire string! and yes i'm writing my own code (vb) to control a fingerprint sensor! and thank you so much for the tip! I managed to split the string by sending it into a char array then using strktok to split at the semicolon, its doing exactly what i wanted ! :sunglasses:
I have to do this preferably without using markers as start and end of string but i won't throw this idea away.
Now all i need is to send each half CODE and 25 to the respective h1 and h2, im going to read the " Serial Input Basics" before asking any more questions, you have been a great help!
Robin2:
...R
Thank you for pointing me in that direction, im reading it at this moment :wink:
econjack:
  char codeBuff[10];
  char number[5];
  char *index;
  int charsRead;
  while (true) {
If you type in "code;25", the *codeBuff* should equal code and *number* should equal 25
Thank you! Im going to look into this ASAP! and yes, only one set of codes comes in at a time!
Thanks to everyone who replied, you guys are amazing! I achieved my goal.
