Here is the font I'm using to generate code in the LED Matrix editor. I'll set up a case statement to pick out the code from text.
curious to see how you are using this ![]()
in theory you could plot the text to a virtual framebuffer as the one used in the Game of Life example and then push that buffer to the Matrix.
If you need any help let me know ![]()
Hi Sir Can you tell what does 4x6 means in "matrix.textFont(Font_4x6);"
I am using Arduino R4 Wifi & trying to program the built in led matrix provided in the arduino board
Hi @abdullah420. This line configures the program to use a set of characters that each fit within a four pixel by six pixel grid.
In case you are curious, you can see the code that defines the characters of this "font" here in the "ArduinoGraphics" library (which is a dependency of the "Arduino_LED_Matrix" library):
https://github.com/arduino-libraries/ArduinoGraphics/blob/1.1.0/src/Font_4x6.c
