Sr04m-2 ultrasonic sensor showing incorrect values
Recently I ordered two sr04m-2 ultrasonic sensors. The problem is that they are showing incorrect values. Both of them are showing 200-250 cm(or 0) no matter how close I put them to wall, hand or whatever. I wired rx to trigger pin and tx to echo pin(also tried vice versa). 5V and GND to respective pins on the arduino board. I tried using NewPing library and code from internet without this library. Also tried to connect to different digital pins and set different baud rates. Red light on the sensor is flashing and I hear click sounds.
What can be the problem? Maybe they just don't work?
Thank you in advance.
Image:
Code with NewPing library:
#include <NewPing.h>
#define TRIGGER_PIN  7
#define ECHO_PIN     8
#define MAX_DISTANCE 400
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
  delay(50);
  Serial.print("Ping: ");
  Serial.print(sonar.ping_cm());
  Serial.println("cm");
Serial monitor:
Ping: 240cm
Ping: 227cm
Ping: 245cm
Ping: 239cm
Ping: 241cm
Ping: 240cm
Ping: 218cm
Ping: 217cm
Ping: 226cm
Ping: 223cm
Ping: 239cm
Ping: 240cm
Ping: 238cm
Ping: 239cm
Ping: 239cm
Ping: 239cm
Ping: 237cm
Ping: 237cm
Ping: 238cm
Ping: 238cm
Ping: 237cm
Ping: 239cm
Ping: 238cm
Ping: 238cm
Ping: 239cm
Ping: 237cm
Ping: 238cm
Ping: 238cm
Ping: 237cm
Ping: 238cm
Ping: 239cm
Ping: 237cm
Ping: 219cm
Ping: 235cm
Ping: 228cm
Ping: 231cm
Ping: 239cm
Ping: 224cm
Ping: 233cm
Ping: 238cm
Ping: 228cm
Ping: 224cm
Ping: 222cm
Ping: 223cm
You could post a few images of the project. You could post a schemo. You could let us know which MCU you are using.
You could come to understand why a mix of floats and ints not properly cast could give wonky results. Like what is .034 cast as an int?
You could add some serial prints for troubleshooting and remove them later.
added to the post one image(new users can't add more) and information that I get from serial monitor. If problem is in data types why first code example is not working? I hope that gives you some information. Thank you.
Have you considered how the device is wired up may be an issue?
For instance, the green wire for 5V on the module goes to pin 7 on the UNO. Perhaps finding a connect guide for your ultrasonic sensor might be in order?
Will be trying to figure out what is the problem, anyway thanks for your time.
Is there a resistor in location R19 on your board? That will switch the board to Serial (9600 baud, 3-byte messages every 120 milliseconds) ot Low Power Serial (9600 baud, send 0x01 to receive 3-byte distance).
Hello, I added image of another side of the sensor. I have read documentation from https://www.katranji.com/tocimages/files/406377-274587.pdf https://www.jahankitshop.com/getattach.aspx?id=4635&Type=Product
And both documents say that it can work in same mode as HC-SR04 sensor.
Yes, it can. If it is configured to. Neither of those documents matches your board. I suspect the "SWIM"(?) pin on your model does something. I think you need to find a document specific to your board.
I had asked the seller for documentation, and he replied that he can`t find it :laughing:
At least you got "nice" results - I get alternating nonsense and zeros
Ping: 238cm
Ping: 0cm
Ping: 239cm
Ping: 0cm
Ping: 238cm
Worked with pullup and pulldown on the trigger (recommended elsewhere) - that did not work either. Anybody have any ideas?
Same issue, with same hardware (with sensor from AMZ) : did anyone got an idea ?
(no resistor on R19. schema is working well with a non waterproof SR04)
Thx
I don't have Arduino but I just tested this sensor with another platform (Sonoff Basic + Tasmota sensors v11.1.0).
I used a slightly modified version of an Arduino sketch that can be found in this Youtube video (in Portuguese) and had good results.
https://www.youtube.com/watch?v=0lwtZZW2xXM
Maybe you could try this sketch, although it doesn't make use of the NewPing library.
Original Tasmota code uses NewPing library too but I didn't get good results...
Just some more information.
The 2.5m long cable is not well insulated. If I leave it on top of my computer keyboard the measurements go crazy.
I feed the sensor with 3.3V, which generates good measurements between 25cm and 250cm, which is enough for my use case.
@hofnarr @amanzimdwini and arsenic : take a look at the end of this page:
https://www.davidpilling.com/wiki/index.php/JSN
It talks about the position of the transformer core (transformer is the top left component in the second image of this topic).
Why don't you try changing the core position a little bit?
