Sscanf giving me complie issues
Hey everyone,
I'm using an Adafruit feather M0 with inbuilt rfm95 LoRa.
I'm taking data on my Tx from a BME280, converting the float values into integers and then putting those integer values into a char buffer through 'sprintf'.
on my Rx I'm receiving the values into a char buffer and then trying to convert them back into integers through 'sscanf' which will then be converted back to a float to be used.
This method worked on my old adafruit 32u4 radio but the m0 kicks out an error of:
"Compliation error: invalid conversion from 'uint8_t*' {aka 'unsigned char*'} to 'const char*' [-fpermissive]"
If the AVR boards have issues with sscanf, what is the best way to go about converting the received data into integers? I've seen 'atoi' and 'toint' but not sure if they have the capacity to do this.
Complete code:
// Libraries
#include <SPI.h>
#include <RH_RF95.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SH110X.h>
// Rx Frequency
#define RF95_FREQ 433.0
// Assign Pins
  #define RFM95_CS 8
  #define RFM95_INT 3
  #define RFM95_RST 4
unsigned const int vBattPin = A7,
                   bdLed = 13;
// Assign radio code, pins and values
RH_RF95 radio(RFM95_CS, RFM95_INT);
int16_t packetnum = 0;    // Packetnumber counter
// Assign screen values
Adafruit_SH1107 disp = Adafruit_SH1107(64, 128, &Wire);
// Battery Declarations
float vBatt = 0;
// Timer Variables
unsigned long vBattStartTim = 0,    // Voltage measurment timer
              vBattCurrTim = 0;
unsigned const int vBattDelay = 5000;
unsigned long dispStartTim = 0,   // Display Timer
              dispCurrTim = 0;
unsigned const int dispDelay = 1000;
unsigned long ackStartTim = 0,    // Acknowledgment Timer
              ackCurrTim = 0;
unsigned const int ackDelay = 3000;
// Interger/Float Conversion Variables
unsigned int valInt = 0,    // Interger to be converted
             valDec = 0;
float valFlo = 0,   // Final generated real number
      valFrac = 0;    // Decimal for float
// Rx Data Integer Variables
int vBattIntR = 0,
             vBattDecR = 0,
             //wSpeedIntR = 0,
             //wSpeedDecR = 0;
             tempIntR = 0,
             tempDecR = 0,
             humidIntR = 0,
             humidDecR = 0,
             pressIntR = 0,
             pressDecR = 0,
             altiIntR = 0,
             altiDecR = 0;
// Rx data Float Variables
float //wSpeedR = 0,
      vBattR = 0,
      tempR = 0,
      humidR = 0,
      pressR = 0,
      altiR = 0;
// Acknowledgement Variables
bool connected = false;
// Interger -> Float conversion
void genFlo()
  valFrac = valDec * 0.01;    // eg Int = 12, Dec = 75.    75 * 0.01 = 0.75
  valFlo = valInt + valFrac;  // 12 + 0.75 = 12.75
// LED reply blink
void blink(byte pin, byte delay_ms, byte loops)
  while(loops--)
    digitalWrite(pin, HIGH);
    delay(delay_ms);
    digitalWrite(pin, LOW);
    delay(delay_ms);
    // Init Serial
  delay(2000);
    // Start Timers
  vBattStartTim = millis();
  dispStartTim = millis();
  ackStartTim = millis();
    // Declare pin modes
  pinMode(RFM95_RST, OUTPUT);
    // Pull radio reset pin low
  digitalWrite(RFM95_RST, HIGH);
    // Init Display
  disp.begin(0x3C, true);
  disp.display();
  disp.clearDisplay();
  disp.display();
  disp.setRotation(1);
    // Manual reset of radio
  digitalWrite(RFM95_RST, LOW);
  delay(10);
  delay(10);
    // Update
  Serial.println("Serial init, pin init, display init, RFM reset");
    // Hold program if radio fails
  if (!radio.init())
    Serial.println("RFM95 init failed!");
    while(1);
  Serial.println("RFM95 init ok!");
    // Set Frequency
  if (!radio.setFrequency(RF95_FREQ))
    Serial.println("Frequency set failed!");
    while(1);
Serial.print("Frequency set - "); Serial.println(RF95_FREQ);
    // Set Power
  radio.setTxPower(23, false);   // Range from 14 - 20 power
    // set Encryption
  /*uint8_t key[] = { 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08,
                    0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08};
  radio.setEncryptionKey(key);*/
  Serial.println("Init complete");
    // Start Timers
  vBattCurrTim = millis();
  dispCurrTim = millis();
  ackCurrTim = millis();
    // Read and calculate Rx battery voltage every 5 second(s)
  if (vBattCurrTim - vBattStartTim >= vBattDelay)
    vBatt = analogRead(vBattPin);
    vBatt *= 2;
    vBatt *= 3.3;
    vBatt /= 1024;
    vBattStartTim = vBattCurrTim;
    Serial.print("Rx voltage: "); Serial.print(vBatt); Serial.println("v\n");
    // If disconnected for three seconds connected = false
  /*if (ackCurrTim - ackStartTim >= ackDelay)
    connected = false;
    ackStartTim = ackCurrTim;
    // listen for message, receive message.
  if (radio.available())    // Listen
    uint8_t buf[RH_RF95_MAX_MESSAGE_LEN];   // Generate buffer for incoming data
    uint8_t len = sizeof(buf);    // Length of message
    if (radio.recv(buf, &len))    // If message received
      if (!len) return;
      buf[len] = 0;
      Serial.print("Received: ["); Serial.print(len); Serial.print("]: "); Serial.println((char*)buf);
      Serial.print("RSSI: "); Serial.println(radio.lastRssi(), DEC);
      connected = true;
      // Put data from buffer and convert from char to integers through 'sscanf'
    sscanf(buf, "%d,%d,%d,%d,%d,%d,%d,%d,%d,%d", &vBattIntR, &vBattDecR, &tempIntR, &tempDecR, &humidIntR, &humidDecR, &pressIntR, &pressDecR, &altiIntR, &altiDecR);
      // Send a reply
    uint8_t data[] = "Data Received";
    radio.send(data, sizeof(data));
    radio.waitPacketSent();
    Serial.println("Reply Sent");
    blink(bdLed, 40, 3);
    // Process recieved data every 1 second(s)
  if (dispCurrTim - dispStartTim >= dispDelay)
      // Convert Intergers to Floats
    valInt = vBattIntR; valDec = vBattDecR;   // Tx Battery Conversion
    genFlo();
    vBattR = valFlo;
    /*valInt = wSpeedIntR; valDec = wSpeedDecR;   // Windspeed Conversion
    genFlo();
    wSpeedR = valFlo;*/
    valInt = tempIntR; valDec = tempDecR;   // Temp Conversion
    genFlo();
    tempR = valFlo;
    valInt = humidIntR; valDec = humidDecR;
    genFlo();
    humidR = valFlo;
    valInt = pressIntR; valDec = pressDecR;
    genFlo();
    pressR = valFlo;
    valInt = altiIntR; valDec = altiDecR;
    genFlo();
    altiR = valFlo;
      // Print to serial
      if (connected == true)
        Serial.println("CONNECTED");
        Serial.println("DISSCONNECTED");
    Serial.print("Tx Voltage: "); Serial.print(vBattR); Serial.println("v");
    Serial.print("Temp: "); Serial.print(tempR); Serial.println("C");
    Serial.print("Humid: "); Serial.print(humidR); Serial.println("%");
    Serial.print("Press: "); Serial.print(pressR); Serial.println("HPa");
    Serial.print("Alti: "); Serial.print(altiR); Serial.println("m");
      // Print to display
    disp.clearDisplay(); disp.setTextSize(2); disp.setTextColor(SH110X_WHITE);
    disp.setCursor(0,0); disp.print(tempR); disp.print("C");
    disp.setTextSize(1); disp.setCursor(0,20);
        disp.print("CONNECTED");
        disp.print("DISSCONNECTED");
      connected = false;
    disp.setCursor(0,35); disp.print("RSSI: "); disp.print(radio.lastRssi(), DEC);
    disp.setCursor(0,50); disp.print("Rx:"); disp.print(vBatt); disp.print("v ");
    disp.print("Tx:"); disp.print(vBattR); disp.print("v");
    float rssiLvl = (((radio.lastRssi()*-1)-27)/1.49);
    int rssiLvlInt = rssiLvl;
    disp.drawRect(115, 0, 10, 64, SH110X_WHITE);
    disp.fillRect(116, rssiLvlInt, 8, 63-(rssiLvlInt), SH110X_WHITE);
    disp.display();
    dispStartTim = dispCurrTim;
Any advice would be awesome, many thanks.
Please show the code related to that message.
That is a low level warning.
If the error is coming from the line containing the sscanf call, try changing
to
char buf[RH_RF95_MAX_MESSAGE_LEN];;
Side note: if the compiler then complains about other calls involving buf not being uint8_t, you could leave it as uint8_t and cast it in the sscanf, like so
sscanf((char *)buf, "%d,%d,%d,%d,%d,%d,%d,%d,%d,%d", &vBattIntR, &vBattDecR, &tempIntR, &tempDecR, &humidIntR, &humidDecR, &pressIntR, &pressDecR, &altiIntR, &altiDecR);
This is the code that brings about the error
That did it, much appreciated. When you say cast it, it means store it as a char?
Thanks again!
This is C++, so instead of a C-style cast
(char *)buf
use the appropriate _cast
reinterpret_cast<char *>(buf)
