SSD 1306 SPI OLED not working on Pro Micro
Hi. I'm trying to get a spi oled display working with the pro micro. I've checked connections multiple times, tried tweaking the code, looked up solutions everywhere but no luck. I've had this display working in the past using spi but it stopped working out of nowhere... I thought it was possibly damaged so I ordered new ones but am still having no luck with these. I try running example sketches from the SSD 1306 library which worked before. If anyone is able to help I would really appreciate it! This is the code I'm using:
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
Adafruit_SSD1306 display = Adafruit_SSD1306(128, 64, &Wire);
// OLED FeatherWing buttons map to different pins depending on board:
#if defined(ESP8266)
  #define BUTTON_A  0
  #define BUTTON_B 16
  #define BUTTON_C  2
#elif defined(ESP32)
  #define BUTTON_A 15
  #define BUTTON_B 32
  #define BUTTON_C 14
#elif defined(ARDUINO_STM32_FEATHER)
  #define BUTTON_A PA15
  #define BUTTON_B PC7
  #define BUTTON_C PC5
#elif defined(TEENSYDUINO)
  #define BUTTON_A  4
  #define BUTTON_B  3
  #define BUTTON_C  8
#elif defined(ARDUINO_FEATHER52832)
  #define BUTTON_A 31
  #define BUTTON_B 30
  #define BUTTON_C 27
#else // 32u4, M0, M4, nrf52840 and 328p
  #define BUTTON_A  9
  #define BUTTON_B  6
  #define BUTTON_C  5
#endif
  Serial.println("OLED FeatherWing test");
  // SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C); // Address 0x3C for 128x32
  Serial.println("OLED begun");
  // Show image buffer on the display hardware.
  // Since the buffer is intialized with an Adafruit splashscreen
  // internally, this will display the splashscreen.
  display.display();
  // Clear the buffer.
  display.clearDisplay();
  display.display();
  Serial.println("IO test");
  pinMode(BUTTON_A, INPUT_PULLUP);
  pinMode(BUTTON_B, INPUT_PULLUP);
  pinMode(BUTTON_C, INPUT_PULLUP);
  // text display tests
  display.setTextSize(1);
  display.setTextColor(WHITE);
  display.setCursor(0,0);
  display.print("Connecting to SSID\n'adafruit':");
  display.print("connected!");
  display.println("IP: 10.0.1.23");
  display.println("Sending val #0");
  display.display(); // actually display all of the above
  if(!digitalRead(BUTTON_A)) display.print("A");
  if(!digitalRead(BUTTON_B)) display.print("B");
  if(!digitalRead(BUTTON_C)) display.print("C");
  delay(10);
  yield();
  display.display();
![WhatsApp Image 2022-08-03 at 2.44.12 PM|375x500](upload://bGoLwKc87WE3jTpvUp3kxiCgTdL.jpeg)
What do you mean by "not working"? Entirely black or white screen, or random dots, or distorted image?
What do you mean by "not working on Pro Micro"? Does the screen work normally on an Uno or Nano?
I have moved your question to the obviously correct forum section: "Displays" instead of "Networking and Protocols".
If the example sketches are not working, then it's not a code problem. There is no point anyone looking at your code until the display works with the example sketches. Then your code should work too, if it was working before.
You said this was an SPI OLED? There are no addresses with SPI, only with I²C.
Sorry I've tried with a couple of codes and that was one of them but I can't get the 128x64 spi code from the ssd1306 examples folder to work. The screen is entirely black. i've tried with a nano, uno, and the pro micro.
This is the code:
 This is an example for our Monochrome OLEDs based on SSD1306 drivers
 Pick one up today in the adafruit shop!
 ------> http://www.adafruit.com/category/63_98
 This example is for a 128x64 pixel display using SPI to communicate
 4 or 5 pins are required to interface.
 Adafruit invests time and resources providing this open
 source code, please support Adafruit and open-source
 hardware by purchasing products from Adafruit!
 Written by Limor Fried/Ladyada for Adafruit Industries,
 with contributions from the open source community.
 BSD license, check license.txt for more information
 All text above, and the splash screen below must be
 included in any redistribution.
#include <SPI.h>
#include <Wire.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for SSD1306 display connected using software SPI (default case):
#define OLED_MOSI   9
#define OLED_CLK   10
#define OLED_DC    11
#define OLED_CS    12
#define OLED_RESET 13
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT,
  OLED_MOSI, OLED_CLK, OLED_DC, OLED_RESET, OLED_CS);
/* Comment out above, uncomment this block to use hardware SPI
#define OLED_DC     6
#define OLED_CS     7
#define OLED_RESET  8
  &SPI, OLED_DC, OLED_RESET, OLED_CS);
#define NUMFLAKES     10 // Number of snowflakes in the animation example
#define LOGO_HEIGHT   16
#define LOGO_WIDTH    16
static const unsigned char PROGMEM logo_bmp[] =
{ B00000000, B11000000,
  B00000001, B11000000,
  B00000011, B11100000,
  B11110011, B11100000,
  B11111110, B11111000,
  B01111110, B11111111,
  B00110011, B10011111,
  B00011111, B11111100,
  B00001101, B01110000,
  B00011011, B10100000,
  B00111111, B11100000,
  B00111111, B11110000,
  B01111100, B11110000,
  B01110000, B01110000,
  B00000000, B00110000 };
  if(!display.begin(SSD1306_SWITCHCAPVCC)) {
    Serial.println(F("SSD1306 allocation failed"));
    for(;;); // Don't proceed, loop forever
  // Show initial display buffer contents on the screen --
  // the library initializes this with an Adafruit splash screen.
  display.display();
  delay(2000); // Pause for 2 seconds
  // Clear the buffer
  // Draw a single pixel in white
  display.drawPixel(10, 10, WHITE);
  // Show the display buffer on the screen. You MUST call display() after
  // drawing commands to make them visible on screen!
  display.display();
  delay(2000);
  // display.display() is NOT necessary after every single drawing command,
  // unless that's what you want...rather, you can batch up a bunch of
  // drawing operations and then update the screen all at once by calling
  // display.display(). These examples demonstrate both approaches...
  testdrawline();      // Draw many lines
  testdrawrect();      // Draw rectangles (outlines)
  testfillrect();      // Draw rectangles (filled)
  testdrawcircle();    // Draw circles (outlines)
  testfillcircle();    // Draw circles (filled)
  testdrawroundrect(); // Draw rounded rectangles (outlines)
  testfillroundrect(); // Draw rounded rectangles (filled)
  testdrawtriangle();  // Draw triangles (outlines)
  testfilltriangle();  // Draw triangles (filled)
  testdrawchar();      // Draw characters of the default font
  testdrawstyles();    // Draw 'stylized' characters
  testscrolltext();    // Draw scrolling text
  testdrawbitmap();    // Draw a small bitmap image
  // Invert and restore display, pausing in-between
  display.invertDisplay(true);
  display.invertDisplay(false);
  testanimate(logo_bmp, LOGO_WIDTH, LOGO_HEIGHT); // Animate bitmaps
void testdrawline() {
  int16_t i;
  display.clearDisplay(); // Clear display buffer
  for(i=0; i<display.width(); i+=4) {
    display.drawLine(0, 0, i, display.height()-1, WHITE);
    display.display(); // Update screen with each newly-drawn line
    delay(1);
  for(i=0; i<display.height(); i+=4) {
    display.drawLine(0, 0, display.width()-1, i, WHITE);
    display.display();
    delay(1);
  delay(250);
    display.drawLine(0, display.height()-1, i, 0, WHITE);
    display.display();
    delay(1);
  for(i=display.height()-1; i>=0; i-=4) {
    display.drawLine(0, display.height()-1, display.width()-1, i, WHITE);
    display.display();
    delay(1);
  delay(250);
  for(i=display.width()-1; i>=0; i-=4) {
    display.drawLine(display.width()-1, display.height()-1, i, 0, WHITE);
    display.display();
    delay(1);
    display.drawLine(display.width()-1, display.height()-1, 0, i, WHITE);
    display.display();
    delay(1);
  delay(250);
    display.drawLine(display.width()-1, 0, 0, i, WHITE);
    display.display();
    delay(1);
    display.drawLine(display.width()-1, 0, i, display.height()-1, WHITE);
    display.display();
    delay(1);
void testdrawrect(void) {
  for(int16_t i=0; i<display.height()/2; i+=2) {
    display.drawRect(i, i, display.width()-2*i, display.height()-2*i, WHITE);
    display.display(); // Update screen with each newly-drawn rectangle
    delay(1);
  delay(2000);
void testfillrect(void) {
  for(int16_t i=0; i<display.height()/2; i+=3) {
    // The INVERSE color is used so rectangles alternate white/black
    display.fillRect(i, i, display.width()-i*2, display.height()-i*2, INVERSE);
    delay(1);
  delay(2000);
void testdrawcircle(void) {
  for(int16_t i=0; i<max(display.width(),display.height())/2; i+=2) {
    display.drawCircle(display.width()/2, display.height()/2, i, WHITE);
    display.display();
    delay(1);
  delay(2000);
void testfillcircle(void) {
  for(int16_t i=max(display.width(),display.height())/2; i>0; i-=3) {
    // The INVERSE color is used so circles alternate white/black
    display.fillCircle(display.width() / 2, display.height() / 2, i, INVERSE);
    display.display(); // Update screen with each newly-drawn circle
    delay(1);
  delay(2000);
void testdrawroundrect(void) {
  for(int16_t i=0; i<display.height()/2-2; i+=2) {
    display.drawRoundRect(i, i, display.width()-2*i, display.height()-2*i,
      display.height()/4, WHITE);
    display.display();
    delay(1);
  delay(2000);
void testfillroundrect(void) {
    // The INVERSE color is used so round-rects alternate white/black
    display.fillRoundRect(i, i, display.width()-2*i, display.height()-2*i,
      display.height()/4, INVERSE);
    display.display();
    delay(1);
  delay(2000);
void testdrawtriangle(void) {
  for(int16_t i=0; i<max(display.width(),display.height())/2; i+=5) {
    display.drawTriangle(
      display.width()/2  , display.height()/2-i,
      display.width()/2-i, display.height()/2+i,
      display.width()/2+i, display.height()/2+i, WHITE);
    display.display();
    delay(1);
  delay(2000);
void testfilltriangle(void) {
  for(int16_t i=max(display.width(),display.height())/2; i>0; i-=5) {
    // The INVERSE color is used so triangles alternate white/black
    display.fillTriangle(
      display.width()/2+i, display.height()/2+i, INVERSE);
    display.display();
    delay(1);
  delay(2000);
void testdrawchar(void) {
  display.setTextSize(1);      // Normal 1:1 pixel scale
  display.setTextColor(WHITE); // Draw white text
  display.setCursor(0, 0);     // Start at top-left corner
  display.cp437(true);         // Use full 256 char 'Code Page 437' font
  // Not all the characters will fit on the display. This is normal.
  // Library will draw what it can and the rest will be clipped.
  for(int16_t i=0; i<256; i++) {
    if(i == '\n') display.write(' ');
    else          display.write(i);
  display.display();
  delay(2000);
void testdrawstyles(void) {
  display.setCursor(0,0);             // Start at top-left corner
  display.println(F("Hello, world!"));
  display.setTextColor(BLACK, WHITE); // Draw 'inverse' text
  display.println(3.141592);
  display.setTextSize(2);             // Draw 2X-scale text
  display.print(F("0x")); display.println(0xDEADBEEF, HEX);
  display.display();
  delay(2000);
void testscrolltext(void) {
  display.setCursor(10, 0);
  display.println(F("scroll"));
  display.display();      // Show initial text
  delay(100);
  // Scroll in various directions, pausing in-between:
  display.startscrollright(0x00, 0x0F);
  delay(2000);
  display.stopscroll();
  display.startscrollleft(0x00, 0x0F);
  delay(2000);
  display.startscrolldiagright(0x00, 0x07);
  delay(2000);
  display.startscrolldiagleft(0x00, 0x07);
  delay(2000);
void testdrawbitmap(void) {
  display.drawBitmap(
    (display.width()  - LOGO_WIDTH ) / 2,
    (display.height() - LOGO_HEIGHT) / 2,
    logo_bmp, LOGO_WIDTH, LOGO_HEIGHT, 1);
  display.display();
#define XPOS   0 // Indexes into the 'icons' array in function below
#define YPOS   1
#define DELTAY 2
void testanimate(const uint8_t *bitmap, uint8_t w, uint8_t h) {
  int8_t f, icons[NUMFLAKES][3];
  // Initialize 'snowflake' positions
  for(f=0; f< NUMFLAKES; f++) {
    icons[f][XPOS]   = random(1 - LOGO_WIDTH, display.width());
    icons[f][YPOS]   = -LOGO_HEIGHT;
    icons[f][DELTAY] = random(1, 6);
    Serial.print(F("x: "));
    Serial.print(icons[f][XPOS], DEC);
    Serial.print(F(" y: "));
    Serial.print(icons[f][YPOS], DEC);
    Serial.print(F(" dy: "));
    Serial.println(icons[f][DELTAY], DEC);
  for(;;) { // Loop forever...
    display.clearDisplay(); // Clear the display buffer
    // Draw each snowflake:
      display.drawBitmap(icons[f][XPOS], icons[f][YPOS], bitmap, w, h, WHITE);
    display.display(); // Show the display buffer on the screen
    delay(200);        // Pause for 1/10 second
    // Then update coordinates of each flake...
      icons[f][YPOS] += icons[f][DELTAY];
      // If snowflake is off the bottom of the screen...
      if (icons[f][YPOS] >= display.height()) {
        // Reinitialize to a random position, just off the top
Please post a hand drawn diagram showing how you wired the display, with clearly labeled pin numbers and designations on both the Arduino and the display. The photo is not very helpful.
SPI wiring will not work with the example I2C display code.
Here is the wiring and some code I used with SPI OLED and Pro Micro. Sorry that the wiring may not be very clear, ask if you cannot figure it out
This is what I had:
Arduino Pro Micro OLED Display
Vcc Vcc
GND GND
D15 SCL
D16 SDA
D4 DC
D2 RES
I'm trying to build an Arduboy
Thanks for sharing. I tried to upload and followed your wiring. The error I get is:
avrdude: butterfly_recv(): programmer is not responding
I have the right board and port selected...
That's an upload error, not related to the code I shared. Can you upload the blink example sketch to the Pro Mini?
Which doesn't seem to agree with the latest code you posted.
Make up your mind: are you using an SPI or I2C connection?
spi. What do you mean it doesn’t agree? Are you saying that because of how the pins are defined?
What do you think the code uses: hardware or software SPI?
I’m not really too familiar with the differences. I’ll try hardware spi once I get back home.
I’m using a pro micro not pro mini. Could that be why?
On the Pro Micro and the Pro Mini, the library SPI.h uses the hardware SPI.
Check the pinout diagrams and make sure to connect MOSI, MISO, SCK and CS correctly.
If the display is 3.3V only, you MUST use a 5V to 3.3V bidirectional level converter on the I/O lines.
Ok thank you for that insight. The display should work with 5V per the specification
So I just got back home and my computer was off. I turned it on and your code showed up on the screen. I took it out and put it back in and the screen was black again. Super weird behavior... Is it possible this is a faulty Arduino? I've never seen anything like this before.
Now when I plug it in im getting white dots on the screen. Do you know what this could be?
