Hello,
I would like to create a scrolling text only in one part of the 128x64 OLED screen. Specifically the part which is yellow. You can see the attached picture.
For example, i would like to display “ThingSpeak Ok” for 5 seconds then scroll text right and display “IP address” for 5 seconds.
My issue is that when i call the function startscrollright() inside void loop() the text starts flickering without any scroll movement. I suspect that is because the void loop() function is constantly running and constantly calling the function startscrollright().
I do not want to use the delay() function because that would make the whole code and display stop.
Can you please point me in the right direction? How should i proceed?
Thank you!
