prog345
December 16, 2020, 7:15am
#1
I am using SSD 1306 led Display in my project . I have drawn a rectangle and inside the rectangle a text is written in it .
If I press the reset button in my project i need only the text to be scrolled and the rectangle should disappear .
At present in my code both the rectangle and the text gets scrolled when i press the button .
Kindly help.
Please find my code and other attachments in the attachment section
OLED_BITMAP.ino (3.31 KB)
OLED text scroll.txt (3.28 KB)
prog345
December 16, 2020, 7:21am
#2
Code for the above question is as follows:
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <avr/pgmspace.h>
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define LEFT_BUTTON 13
#define RIGHT_BUTTON 12
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
int lbutton;
int rbutton;
pinMode(LEFT_BUTTON,INPUT);
pinMode(RIGHT_BUTTON,INPUT);
if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
Serial.println(F(“SSD1306 allocation failed”));
for(;;);
delay(2000); // Pause for 2 seconds
// Clear the buffer.
display.clearDisplay();
display.drawRect(0, 0, 125, 20, WHITE);
display.display();
display.setTextSize(1);
display.setTextWrap(false);
display.setTextColor(WHITE);
display.setCursor(0, 10);
display.println(“SSD1306 OLED DISPLAY TESTING”);
display.display();
lbutton = digitalRead(13);
rbutton = digitalRead(12);
if ((lbutton ==0)&&(rbutton ==1))
// display.clearDisplay();
display.stopscroll();
display.startscrollleft(0x00, 0x0F);
delay(4000);
else if ((lbutton ==1)&&(rbutton ==0))
display.startscrollright(0x00, 0x0F);
delay(4000);
jimLee
December 16, 2020, 7:33am
#3
Lets pretend you formatted it and put it in code tags…
#include <Wire.h>
int lbutton;
int rbutton;
pinMode(LEFT_BUTTON, INPUT);
pinMode(RIGHT_BUTTON, INPUT);
if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
Serial.println(F("SSD1306 allocation failed"));
for (;;);
display.display();
display.println("SSD1306 OLED DISPLAY TESTING");
display.display();
if ((lbutton == 0) && (rbutton == 1)) {
delay(4000);
else if ((lbutton == 1) && (rbutton == 0)) {
delay(4000);
But it seems that it still won’t compile.
forum_post:13:64: error: no matching function for call to 'Adafruit_SSD1306::Adafruit_SSD1306(int, int, TwoWire*, int)'
-jim lee
