/* oled library*/
#include<math.h>
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
/*Temperature*/
#include <OneWire.h>
#include <DallasTemperature.h>
/*ADXL345 accelerometer*/
#include <Adafruit_Sensor.h>
#include <Adafruit_ADXL345_U.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
// The pins for I2C are defined by the Wire-library.
// On an arduino UNO: A4(SDA), A5(SCL)
// On an arduino MEGA 2560: 20(SDA), 21(SCL)
// On an arduino LEONARDO: 2(SDA), 3(SCL), ...
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3C ///< See datasheet for Address; 0x3D for 128x64, 0x3C for 128x32
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define LOGO_HEIGHT 16
#define LOGO_WIDTH 16
#define ledPin_1 13 // choose the pin for the LED start led
#define ledPin_2 12 // 2nd led
#define ledPin_3 11 // 3rd led
#define switchPin_1 7 // choose the input pin (for a pushbutton) start_switch
#define switchPin_2 4 // 2nd switch
#define switchPin_3 5 // 3rd switch
#define ONE_WIRE_BUS 3
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
Adafruit_ADXL345_Unified accel = Adafruit_ADXL345_Unified();
//pulse sensor
byte a = 0;
byte lasta = 0;
byte lastb = 0;
byte LastTime = 0;
byte ThisTime;
bool BPMTiming = false;
bool BeatComplete = false;
byte BPM = 0;
#define UpperThreshold 560
#define LowerThreshold 530
//buzzer
#define buzzer 2
byte switch_status_1 = 0; // variable for reading the pin status
byte switch_status_2 = 0;
byte switch_status_3 = 0;
byte ledStatus_1 = 0; //see if led is on; high on; low off;
byte ledStatus_2 = 0;
byte ledStatus_3 = 0;
bool all_led_status = false; // true if any led is led up
double magnitudePrevious = 0;
byte footstep = 0;
void display_oled_welcome() {
// This function displays a welcome message on the OLED display.
display.clearDisplay(); // Clear the display buffer
// Set the text properties
display.setTextSize(2);
display.setTextColor(WHITE);
// Set the cursor position and print the welcome message
display.setCursor(21, 21);
display.println("Welcome");
// Display the content on the OLED display
display.display();
delay(3000); // Delay for 3 seconds to show the welcome message
display.clearDisplay(); // Clear the display buffer after displaying the message
pinMode(ledPin_1, OUTPUT); // declare LED as output
pinMode(ledPin_2, OUTPUT); // declare LED as output
pinMode(ledPin_3, OUTPUT); // declare LED as output
pinMode(switchPin_1, INPUT); // declare pushbutton as input
pinMode(switchPin_2, INPUT); // declare pushbutton as input
pinMode(switchPin_3, INPUT); // declare pushbutton as input
//oled setup
// SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS);
if (!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
Serial.println(F("SSD1306 allocation failed"));
for (;;); // Don't proceed, loop forever
// Show initial display buffer contents on the screen --
// the library initializes this with an Adafruit splash screen.
display.display();
delay(2000); // Pause for 2 seconds
// Clear the buffer
display_oled_welcome();
oled_home_display();
pinMode(buzzer, OUTPUT);
buzzer_start_tone();
sensors.begin();
if (!accel.begin())
Serial.println("No ADXL345 sensor detected.");
while (1);
serialStatusPrint();
first_Switch_led();
second_Switch_led();
third_Switch_led();
void serialStatusPrint(void) {
Serial.print("ledStatus_1 = ");
Serial.print(ledStatus_1);
Serial.print(" Switch Status_1 = ");
Serial.print(switch_status_1);
Serial.print("ledStatus_2 = ");
Serial.print(ledStatus_2);
Serial.print(" Switch Status_2 = ");
Serial.print(switch_status_2);
Serial.print("ledStatus_3 = ");
Serial.print(ledStatus_3);
Serial.print(" Switch Status_3 = ");
Serial.print(switch_status_3);
delay(250);
void first_Switch_led() {
ledStatus_1 = digitalRead(ledPin_1);
switch_status_1 = digitalRead(switchPin_1); // read input value
if (switch_status_1 == HIGH)
{ // check if the input is HIGH (button pressed)
if (ledStatus_1 == LOW) {
all_led_off(); //turn off any open led
digitalWrite(ledPin_1, HIGH); // turn LED ON
while (ledStatus_1) {
temperature_sensor();
first_Switch_led();
third_Switch_led();
} else
digitalWrite(ledPin_1, LOW); // turn led OFF
void second_Switch_led() {
ledStatus_2 = digitalRead(ledPin_2);
switch_status_2 = digitalRead(switchPin_2); // read input value
if (switch_status_2 == HIGH)
{ // check if the input is HIGH (button released)
if (ledStatus_2 == LOW) {
digitalWrite(ledPin_2, HIGH); // turn LED ON
while (ledStatus_2) {
pulse_sensor();
first_Switch_led();
third_Switch_led();
digitalWrite(ledPin_2, LOW); // turn led OFF
void third_Switch_led() {
ledStatus_3 = digitalRead(ledPin_3);
switch_status_3 = digitalRead(switchPin_3); // read input value
if (switch_status_3 == HIGH)
if (ledStatus_3 == LOW) {
digitalWrite(ledPin_3, HIGH); // turn LED ON
while (ledStatus_3) {
footstep_cal();
first_Switch_led();
third_Switch_led();
} else
digitalWrite(ledPin_3, LOW); // turn led OFF
void all_led_off() {
//delay(1000);
void oled_welcome_display() {
display.print("WELCOME");
display.display();
delay(3000);
void oled_home_display() {
display.setTextSize(0.9);
display.setCursor(0, 0);
display.print("Press the following bottons to continue..");
display.setCursor(1, 27);
display.print("1.Temperature 2.Pulse");
display.setCursor(1, 42);
display.print("3.Footstep");
display.display();
void temperature_sensor() {
// Send the command to get temperatures
sensors.requestTemperatures();
//print the temperature in Celsius
float temperature_value_celsius = sensors.getTempCByIndex(0);
Serial.print("Temperature: ");
Serial.print(temperature_value_celsius);
Serial.print((char)176);//shows degrees character
Serial.print("C | ");
//Oled display temperature Celsius
display.setTextSize(1);
display.print("Temperature: ");
display.setCursor(0, 10);
display.print(temperature_value_celsius);
display.print(" ");
display.cp437(true);
display.write(167);
display.print("C");
//print the temperature in Fahrenheit
float temperature_value_fahrenheit = (temperature_value_celsius * 9.0) / 5.0 + 32.0;
Serial.print(temperature_value_fahrenheit);
Serial.println("F");
// Oled display temperature Celsius
display.setCursor(0, 35);
display.print("Humidity: ");
display.setCursor(0, 45);
display.print(temperature_value_fahrenheit);
display.print(" ");
display.write(167);
display.print("F");
if (temperature_value_celsius < 100) {
buzzer_alart_temp(5000);
display.cp437(false);
display.display();
void pulse_sensor() {
if (a > 127)
a = 0;
lasta = a;
ThisTime = millis();
int value = analogRead(0);
Serial.println(value);
delay(100);
int b = 60 - (value / 16);
display.writeLine(lasta, lastb, a, b, WHITE);
lastb = b;
lasta = a;
if (value > UpperThreshold)
if (BeatComplete)
BPM = ThisTime - LastTime;
BPM = int(60 / (float(BPM) / 1000));
BPMTiming = false;
tone(8, 1000, 250);
if (BPMTiming == false)
LastTime = millis();
BPMTiming = true;
if ((value < LowerThreshold) & (BPMTiming))
BeatComplete = true;
display.writeFillRect(0, 50, 128, 16, BLACK);
display.setCursor(0, 50);
display.print("BPM:");
display.print(BPM);
if (BPM > 90) {
buzzer_alart_pulse(1000);
display.display();
a++;
Serial.print("Pulse : ");
Serial.print(value);
Serial.print(" BPM: ");
Serial.print(BPM);
void buzzer_start_tone() {
tone(buzzer, 500); // Send 1KHz sound signal...
delay(250); // ...for 1 sec
noTone(buzzer); // Stop sound...
delay(250);
tone(buzzer, 500);
noTone(buzzer);
void buzzer_alart_temp(int tonee) {
tone(buzzer, tonee); // Send 1KHz sound signal...
delay(250);
noTone(buzzer);
void buzzer_alart_pulse(int tonee) {
delay(250);
void footstep_cal() {
sensors_event_t event;
accel.getEvent(&event);
double x_acc = event.acceleration.x;
double y_acc = event.acceleration.y;
double z_acc = event.acceleration.z;
double magnitude = sqrt(x_acc * x_acc + y_acc * y_acc + z_acc * z_acc);
double magnitudeDelta = magnitude - magnitudePrevious;
magnitudePrevious = magnitude;
if (magnitudeDelta > 6) {
footstep++;
delay(10);
display.setTextSize(1.9);
display.setCursor(0, 26);
display.print("Footstop(s) : ");
display.print(footstep);
display.display();
Serial.print("Footstep(s) : ");
Serial.print(footstep);
//void bluetooth() {
// if (Serial.available > 0) {
// inputByte = Serial.read();
You could make better use of the F()macro for your prints
You could tell us what processor you're using, and what the memory usage stats are
its project to create a portable physiological parameter monitor based on arduino uno and Atmega328p microcontroller , after compiling the code it says
Sketch uses 25284 bytes (88%) of program storage space. Maximum is 28672 bytes.
Global variables use 957 bytes (46%) of dynamic memory, leaving 1091 bytes for local variables. Maximum is 2048 bytes.
Have you tried the example sketch for the SSD1306 from the Adafruit library ?
It looks like even using the F() macro, it's going to be tight, but if all you're putting on the screen is text, you may find a text-only library will require less memory.
how do i do that
Look for a library for your display that doesn't need a frame buffer.
(This assumes you never want to display graphics)
thank you , i will try this
Try this Text Only SSD library.
RE: "SSD1306 allocation failed" error
i am having the same issue too and i tried what you suggested and it didn't work
this is my code , can you help me
/* oled library*/
#include<math.h>
#include <SPI.h>
#include <Wire.h>
/*Temperature*/
//pulse sensor
byte a = 0;
byte lasta = 0;
byte lastb = 0;
byte LastTime = 0;
byte ThisTime;
byte BPM = 0;
//buzzer
#define buzzer 2
byte footstep = 0;
display.display();
//oled setup
display.display();
// Clear the buffer
sensors.begin();
if (!accel.begin())
while (1);
first_Switch_led();
third_Switch_led();
delay(250);
first_Switch_led();
third_Switch_led();
} else
pulse_sensor();
first_Switch_led();
third_Switch_led();
footstep_cal();
first_Switch_led();
third_Switch_led();
} else
//delay(1000);
display.display();
delay(3000);
display.display();
display.print(" ");
display.write(167);
display.print("C");
display.print(" ");
display.write(167);
display.print("F");
display.display();
if (a > 127)
a = 0;
lasta = a;
delay(100);
lastb = b;
lasta = a;
if (BeatComplete)
BPMTiming = false;
tone(8, 1000, 250);
BPMTiming = true;
display.print(BPM);
if (BPM > 90) {
display.display();
a++;
Serial.print(BPM);
delay(250);
tone(buzzer, 500);
noTone(buzzer);
delay(250);
noTone(buzzer);
delay(250);
footstep++;
delay(10);
display.display();
using a UNO and a SSD1306 if I run File>Examples>Adafruit SSD1306> SSD1306_128*32_i2c it works OK
if I load your program it displays
when linking it displays
Sketch uses 25266 bytes (78%) of program storage space. Maximum is 32256 bytes.
when the SSD1306 display.begin() is executed it allocates a buffer which I assume is running you out of dynamic memory
if you have a Mega try the program on that
okay , thx let me try it
maybe try calling display.begin once instead of twice..
and i'd keep the one in the if statement..
but yes, uno doesn't have allot of ram..
might want to try smaller screen lib, like SSD1306Ascii..
make a sketch just for testing screen..
good luck.. ~q
@sakindi, please do not hijack nor cross-post. Thread split then merged.
