I have a nice little Time/Temp control application running on an UNO. It was all working well using the Adafruit_PCD8544.h library with the Nokia5110, but I didn't like the look of that display. I thought I'd be able to drop in an ssd1306 using the Adafruit_SSD1306.h library instead but have run into a brick wall - whenever I try to call my functions or use variables, the display allocation fails. If I comment out all the stuff I need to make this work, the display lights up nicely with my desired appearance. This makes no sense to me as the display should be found before any of my calls.
Here is the full code with the display working but all the calls commented out. As soon as I uncomment anything (i.e. a call to controlTemp()) I get SSD1306 allocation failed
// TIME AND TEMPERATURE CONTROLLER //
#include <SPI.h>
#include <Timer.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
// Set up One-Wire Bus for DS18B20 Temperature Sensor
// https://github.com/milesburton/Arduino-Temperature-Control-Library
#include <OneWire.h>
#include <DallasTemperature.h>
//// One Wire Bus Settings - plugged into pin 8 on the Arduino UNO
const byte ONE_WIRE_BUS = 8;
const byte TEMPERATURE_PRECISION = 10;
//// setup digital oneWire sensor addresses
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
////time and temp variable declarations
#include <EEPROM.h> //using EEPROM to store run time and temp target
// declare runTime and tempTarge to be updated from EPROM//
int runTime = 30;
double tempTarget = 200;
// declare current time and temp values
double temperature = 200.0;
double runningTime=0;
// invoke timer instance
Timer timer;
//// PID stuff https://github.com/br3ttb/Arduino-PID-Library
#include <PID_v1.h>
//Define Variables we'll be connecting to
double Output;
//Specify the links and initial tuning parameters
PID myPID(&temperature, &Output, &tempTarget, 2,5,1,P_ON_M, DIRECT); // Input = temperature, Setpoint = tempTarget default constants
//PID myPID(&temperature, &Output, &tempTarget, 1.5,1,4,P_ON_M, DIRECT); // constants per coffee-pid on github
//P_ON_M specifies that Proportional on Measurement be used
//P_ON_E (Proportional on Error) is the default behavior
int WindowSize = 2000; //example is 5000
int whereInWindow;
unsigned long windowStartTime;
// Button adn I/O definitions
// reference https://www.instructables.com/Arduino-Button-Tutorial/
#define BTN_tmpDn 9 // Button
#define BTN_tmpUp 10 // Button
#define BTN_timeDn 11 // Button
#define BTN_timeUp 12 // Button
#define BTN_Start 13 // Button
#define HEAT 14 // to SSR
#define PUMP 15 // to Relay
////set up display
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
// The pins for I2C are defined by the Wire-library.
// On an arduino UNO: A4(SDA), A5(SCL)
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3C ///< See datasheet for Address; 0x3D for 128x64, 0x3C for 128x32 - tg my 128x64 was 0x3C
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
int i=0;
// Setup
// for serial monitor output
Serial.begin(31250);
Serial.println("");
Serial.println("");
Serial.println("TIME/TEMP CONTROLLER Serial Monitor Reporting Restart");
Serial.println(" **********************");
Serial.println(" ********start*********");
//Initialize Display
if(!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
Serial.println(F("SSD1306 allocation failed"));
for(;;); // Don't proceed, loop forever
} else Serial.println("found display");
// Show initial display buffer contents on the screen --
// the library initializes this with an Adafruit splash screen.
display.display();
delay(200); // Pause for .2 seconds
// Clear the buffer
display.clearDisplay();
//set up control pins
pinMode(BTN_tmpDn, INPUT);
pinMode(BTN_tmpUp, INPUT);
pinMode(BTN_timeDn, INPUT);
pinMode(BTN_timeUp, INPUT);
pinMode(BTN_Start, INPUT);
digitalWrite(BTN_tmpDn, HIGH); // pull-up
digitalWrite(BTN_tmpUp, HIGH); // pull-up
digitalWrite(BTN_timeDn, HIGH); // pull-up
digitalWrite(BTN_timeUp, HIGH); // pull-up
digitalWrite(BTN_Start, HIGH); // pull-up
pinMode(HEAT, OUTPUT);
pinMode(PUMP, OUTPUT);
digitalWrite(HEAT, LOW);
digitalWrite(PUMP, LOW);
//get initial values for tempTarget and runTime from eeprom values
// EEPROM address 0 is temp 1 is timer
if (EEPROM.read(0)<50 || EEPROM.read(0)>220) EEPROM.write(0, 200); else tempTarget=EEPROM.read(0);
if (EEPROM.read(1)<1 || EEPROM.read(1)>60) EEPROM.write(1, 30); else runTime=EEPROM.read(1);
Serial.print(" tempTarget:");
Serial.print(tempTarget);
Serial.print(" runTime:");
Serial.print(runTime);
//Setup PID instance
//initialize the variables we're linked to (already linked)
//Input = temperature
//Setpoint = tempTarget;
//tell the PID to range between 0 and the full window size
//myPID.SetOutputLimits(0, WindowSize);
//turn the PID on
//myPID.SetMode(AUTOMATIC);
Serial.print("PID Window: ");
Serial.print(WindowSize);
// read temperature
sensors.requestTemperatures();
temperature = sensors.getTempFByIndex(0);
Serial.print(" Temp: ");
Serial.print(temperature);
// run pid
myPID.Compute();
Serial.print(" PID Output: ");
Serial.println(Output);
// Update Display
void updateDisplay() {
// text display tests
display.clearDisplay(); // clears the screen and buffer
// Display Pump Status
if (digitalRead(PUMP)){
display.setTextSize(2);
display.drawLine(1, 0, 58, 0, WHITE);
display.setTextColor(BLACK, WHITE); // 'inverted' text
display.setCursor(0,1);
display.println(F(">BREW")); // activate icon
display.drawLine(1, 15, 58, 15, WHITE);
display.drawLine(1, 0, 1, 15, WHITE);
display.drawLine(58, 0, 58, 15, WHITE);
display.setTextColor(WHITE);
display.setTextSize(1);
display.setCursor(18,4);
display.print(F("BREW")); // label inactive icon
// Display Heater Status
if (digitalRead(HEAT)){
display.drawLine(65, 0, 122, 0, WHITE);
display.setCursor(64,1);
display.println(F(">HEAT"));
display.drawLine(65, 15, 122, 15, WHITE);
display.drawLine(65, 0, 65, 15, WHITE);
display.drawLine(122, 0, 122, 15, WHITE);
display.setCursor(82,4);
display.print(F("HEAT")); // label inactive icon
// Display tmpTarget
display.setCursor(20,19);
display.print(F("Set Temp: "));
display.println(tempTarget, 0);
// Display Temp
display.setCursor(0,31);
display.print(F("Temp:"));
display.println(temperature, 1);
// Display Time
display.setCursor(0,49);
display.print(F("Timer: "));
//display.println(runTime);
display.println(i++);
// Show your work
display.display();
delay(2000);
// Change Run Time
void changeRunTime(){
while (digitalRead(BTN_Start)) // user not done
delay(10); // debounce
if (!digitalRead(BTN_timeDn)) { // down time button pushed
runTime = --runTime; // decrement run time
delay(130); // reaction time delay
Serial.println("time Dn");}
if (!digitalRead(BTN_timeUp)) { // up time button pushed
runTime = ++runTime; // increment run time
Serial.println("time up");
// Display Run Time
display.setCursor(6,22);
display.println("Run Time:");
display.setCursor(30,36);
display.display();
Serial.println(runTime);
// Save Timer Run Time to EEPROM
if (!digitalRead(BTN_Start)) { // start button pushed?
if (!digitalRead(BTN_Start)) // button still pushed
EEPROM.write(1, runTime); // save new run time to eeprom 1 is timer
delay(200); // wait for release of start button
// Change tempTarget
void changeTempTarget(){
if (!digitalRead(BTN_tmpDn)) { // down time button pushed
tempTarget = --tempTarget; // decrement run time
Serial.println("temp Dn");}
if (!digitalRead(BTN_tmpUp)) { // up time button pushed
tempTarget = ++tempTarget; // increment run time
Serial.println("temp up");
// Display Run Time
display.println("Set Temp:");
display.println(tempTarget);
display.display();
Serial.println(tempTarget);
// Save Temp Target to EEPROM
EEPROM.write(0, tempTarget); // save new run time to eeprom eprom values 0 is temp
// Control Temperature
void controlTemp(){
// read temperature
// basic 1 degree control
if (temperature < (tempTarget-1)){
digitalWrite(HEAT, HIGH);
// Serial.println("Heat On");
if (temperature > (tempTarget)){
// Serial.println("Heat Off");
// PID control
// update temp and setpoint
//Input = temperature;
// call pid and update output
myPID.Compute();
Serial.print("<temp tempTarget>");
Serial.print(" output>");
Serial.print(Output);
whereInWindow = millis()-windowStartTime;
// turn the output pin on/off based on pid output
if (millis() - windowStartTime > WindowSize)
{ //time to shift the Relay Window
windowStartTime += WindowSize;
// example: if (Output < millis() - windowStartTime) digitalWrite(HEAT, HIGH); else digitalWrite(HEAT, LOW);
if (Output < whereInWindow) digitalWrite(HEAT, LOW); else digitalWrite(HEAT, HIGH);
Serial.print(" whereinwindow>");
Serial.print(whereInWindow);
Serial.print(" millis>");
Serial.print(millis());
Serial.print(" heater>");
Serial.println(digitalRead(HEAT));
// Run Timer
void runTimer() {
if (timer.state() != RUNNING){ // if we are stopped
if (!digitalRead(BTN_Start)){ // start the timer
timer.start();
Serial.print("time started: ");
Serial.println(timer.read());
delay (100); // time to get finger off button
} else { // we are running
if (!digitalRead(BTN_Start)){ // stop the timer
timer.stop();
runningTime = 0;
digitalWrite(PUMP, LOW); //turn off pump
Serial.println("timer stopped");
return;
if (timer.read() >= runTime*1000){ //end reached
Serial.println("end of time");
timer.stop();
runningTime=0; //reset timer
} else { //else not done
runningTime = timer.read(); //update time
runningTime = runningTime/1000; //scale ms to seconds
digitalWrite(PUMP, HIGH); //turn on pump
Serial.print("time elapsed: ");
Serial.println(runningTime);
delay (50); // slow it down a bit during prototyping
// Main Loop
//int i=0;
if (timer.state() == RUNNING) // if we are running
runTimer();
if (timer.state() != RUNNING) // if we are stopped
if (!digitalRead(BTN_Start)){ // start or stop the timer?
delay (10); // debounce
runTimer();
if (((WindowSize/4) % i) == 0) // call pid 4 times per window
i = 0;
controlTemp();
} else ++i;
//controlTemp();
updateDisplay();
delay(2000);
bool val;
val = digitalRead(HEAT);
if (val== HIGH) {
Serial.print ("heater : ");
Serial.println(val);
// report button status
Serial.print(digitalRead(BTN_timeUp));
Serial.print(" ");
Serial.print(digitalRead(BTN_timeDn));
Serial.print(" ");
Serial.print(digitalRead(BTN_tmpUp));
Serial.print(" ");
Serial.print(digitalRead(BTN_tmpDn));
Serial.print(" ");
Serial.println(digitalRead(BTN_Start));
//// adjusting target values
if (!digitalRead(BTN_timeDn) || !digitalRead(BTN_timeUp)){
Serial.println("runTime up or down");
// up or down time button pushed
changeRunTime();
if (!digitalRead(BTN_tmpDn) || !digitalRead(BTN_tmpUp)){
Serial.println("tempTarget up or down");
// up or down temp button pushed
changeTempTarget();
