Hello fellow forum members, I'm having this problem with my ssh access to arduino yun, after entering
with root and my password I'm typing some directories which I think they exist, it gives me permission
denied. I would really appreciate if you could help. Here is what they look like :
Unless I'm missing something, In line 1 on directory.jpg, ln requires 2 arguments ln -s source destination.
Make your destination directory first (mkdir), then link your source, which I think would be /mnt/sda1 to your destination directory. I think, if I'm clear on your intentions it would be ln -s /mnt/sda1 /arduino/www/test.
Assuming that the directory /arduino/www/test exists. To check: ls /arduino/www/test. If not found, create the path with mkdir.
You are typing a command:
/mnt/sda1/arduino/www/test ls
You are trying to execute the file test
that is in /mnt/sda1/arduino/www
and giving it the argument ls
. That file test
does not have execute permissions, so it cannot execute that file, therefore you are getting that message.
I'm guessing that is the name of the folder that you are trying to list, and what you really want is:
ls /mnt/sda1/arduino/www/test
That will run the ls
command, and ask it to list the contents of the directory /mnt/sda1/arduino/www/test
Ok. Yes now I got my head around the navigation. Thank you guys.
@fatihturhan,
it is apparent you don't know what you are doing. Can you explain what your are trying to do so we can help you do what you are trying to do? If you need a tutorial, we can help you find one.
Jesse
Thanks for the offer Jesse, we're actually trying to write sensor data to a database, onboard one,
and then get it displayed on a webpage. We were giving a try to one of the instructed projects and got
lost somehow, you can follow it here Yun adventures blogspot 2 - Arduino Yún - Arduino Forum
