sslClient.connect(host, 443) is failing to IFFTT from MKR1000
sslClient.connect(host, 443) is failing to connect to IFFTT from MKR1000
Post your code to get help.
#include <Servo.h>
#include <WiFi101.h>
#include <WiFiClient.h>
#include <WiFiServer.h>
#include <WiFiSSLClient.h>
#include <WiFiUdp.h>
//Your Wifi router setup at home
char ssid[] = "MY2.4G"; //your network SSID (aka WiFi name)
char pass[] = "XXXXXX"; //your network password
int status = WL_IDLE_STATUS;
WiFiServer server(80);
//To send SMS using the s IFTTT
const char* host = "maker.ifttt.com";
WiFiSSLClient sslClient;
delay(10000); //delay to show the console display
int r= Connect_to_Wifi(); // Connect to wifi for sendign text message
sendtextMessage();
int Connect_to_Wifi()
if (WiFi.status() == WL_NO_SHIELD) {
// In case of connection issues wait
delay(3000);
return 1;
// attempt to connect to Wifi network
while ( status != WL_CONNECTED) {
Serial.println("Connecting to Wifi");
status = WiFi.begin(ssid, pass);
if(status != WL_CONNECTED){
// wait 10 seconds for connection:
Serial.println("Connected to Wifi");
server.begin();
printWifiStatus();
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
//signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
// print where to go in a browser:
Serial.print("Your IP address to use in the browser: ");
Serial.println(ip);
//call to IFTTT recipe to send an email or sms to your mobile
void ifttt_Send_SMS() {
String Medicine_not_pickedup = "Y";
String data = "{"value1":"" + Medicine_not_pickedup + ""}";
int i = sslClient.connect(host, 443);
Serial.println("SSL connect return code");
Serial.println(i);
if (sslClient.connect(host, 443)) { //443 or 80
//change this to your Maker setting from settings’s Applets - IFTTT
//sslClient.println("POST /trigger/moition_detected/with/key/XXXXXXXXXXXXXXXX HTTP/1.1");
sslClient.println("POST /trigger/{MedicineNotPicked}/with/key/eMqTXXXXXXXXXdrg4lYIIV6M HTTP/1.1");
sslClient.println("Host: maker.ifttt.com");
sslClient.println("Content-Type: application/json");
sslClient.print("Content-Length: ");
sslClient.println(data.length());
sslClient.println();
sslClient.print(data);
sslClient.stop();
Serial.println("IFTTT request Sucessful");
else {
Serial.println("IFTTT request failed");
I get the value 0 in the statement
sslClient.connect(host,443);
I am able to execute the POST on the webbrowser and get my SMS. So the setup with IFTTT is workign fine
