Unable to connect using SSL on MKR1000
I have been trying to use the SSL feature on the MKR1000 recently. I have uploaded all the relevant certificates on the board, and I attempt to connect using SSL (see code), but the connection times out and is never made. I have also had issues before where it would connect to SSL on certain servers but not others despite both servers having their certificates correctly loaded. I am using WiFi101 0.16.1 and the firmware for my board is WINC1501 Model B 19.6.1.
 #include <WiFi101.h>
WiFiSSLClient internetClient;
int beginWiFi(char* ssid, char* pass, bool retry)
    bool retry_status = true;
    int status = WL_IDLE_STATUS;
    if (WiFi.status() == WL_NO_SHIELD) {
        Serial.print("WiFi Sheild not present, exiting...");
        return -1;
    while (status != WL_CONNECTED && retry_status)
        Serial.print("Attempting to connect to network, SSID: ");
        Serial.println(ssid);
        status = WiFi.begin(ssid, pass);
        retry_status = retry; //to prevent looping!
    if (status != WL_CONNECTED) {
        Serial.println("Failed to connect to WiFi network");
        return -1;
    Serial.println("Connected to WiFi Network!");
    return 0; //OK
// inside setup
  beginWiFi(ssid, pass, true);
  int x = internetClient.connect("arduino.cc", 443); //also doesnt work when connectSSL + normal client class
  Serial.println(x); //always prints 0 (for some domains used to work, now doesn't)
try "www.arduino.cc"
Doesn't work, and it used to work just with "arduino.cc" (previously it had a problem with let's encrypt certificates, now it seems not to work with any certificate)
