ST7735S 1.8 inch TFT LCD 128x160 resulting in pixelated glitching after connecting every pins and writing code
I am watching this youtube video and it shows you which pins to connect and where. But then it refers me to another youtube video showing you what pins to connect to. I do exactly what it tells me to do. And now for some reason, my display is all white screen and even has pixelated glitching, Even after adding correct images with correct format and resolution.
Edit: Sometimes it turns from white screen and to also moshes of pixels with no indication of an image appearing from the SD card. And everytime I plug it on and off it still the same. It doesn't work.
Please send help!
Edit 2: Here is the other websites I tried so far as to connecting and reconnecting the pins. There might be a flaw/bug in the code I think. I dont know.
Anyways, I posted the same exact problem on Stackexchange if you wanna check it out!
https://arduino.stackexchange.com/questions/95287/st7735s-1-8-inch-tft-lcd-128x160-resulting-in-pixelated-glitching-after-connecti
Hi
Do you use a exactly the same TFT display as in the video?
Yes I am using the exact one as in the video!
I am also using a breadboard power supply to create 3.3V because I am powering it with my Arduino Nano.
Anyways. Here is more clarification on this post. Since what I posted on here is not really quite the same, so I will have to change up alot. So go this stackexchange website where I posted the same problem but changed up a bit. https://arduino.stackexchange.com/questions/95287/st7735s-1-8-inch-tft-lcd-128x160-resulting-in-pixelated-glitching-after-connecti
So here is what I will do, I will try to run the display without the SD card on my Arduino UNO and see if it works. If it doesn't work we know that it is the display fault and or the IC fault. But if the display works, then the issue is somewhere within the SD card and or the code itself.
So any help will be appreciated to accelerate the progress of resolving the troubleshooting I am going through. Thank you!
