Standard Stepper Program Working, Not the one using AccelStepper library
The following code runs fine.
It is in 1/16th for AN4988 board.
// defines pins numbers
const int stepPin = 5;
const int dirPin = 4;
hw134
      g	    dir
	    vcc	  step
	    1E	  sleep
	    1A	  reset
	    2A	  S3
	    2E	  S2
	    g	    S1
	    vmot	E
const int delayMicros = 100;
  // Sets the two pins as Outputs
  pinMode(stepPin,OUTPUT);
  pinMode(dirPin,OUTPUT);
  digitalWrite(dirPin,HIGH); // Enables the motor to move in a particular direction
  // Makes 3200 pulses for making one full cycle rotation 1/16 microstepping
  for(long int x = 0; x < 6400; x++) {
    digitalWrite(stepPin,HIGH);
    delayMicroseconds(delayMicros);
    digitalWrite(stepPin,LOW);
  delay(1); // One second delay
  digitalWrite(dirPin,LOW); //Changes the rotations direction
  // Makes 400 pulses for making two full cycle rotation
  delay(1);
However, the following code doesn't work. The stepper seems to be loaded but unable to peak the speed and doesn't move.
#include <AccelStepper.h>
AccelStepper stepper(1, 5,4);  // pin 5 = step, pin 4 = direction
  stepper.setMaxSpeed(150);
  stepper.setAcceleration(100);
  stepper.moveTo(6400);
  while (stepper.currentPosition() != 5000) // Full speed up to 300
    stepper.run();
  stepper.runToNewPosition(0); // Cause an overshoot then back to 0
What could be the reason?
"Doesn't work" contains no information.
Hi..
I mean to say that if the hardware confuration remains same and I see the steeper running fine using normal code.
When I say the library based code doesn't work, I mean to say that my motor doesn't rotate. What could be going wrong?
Is the code that I tested with Accelstepper library is wrong?
What am I missing?
I believe the pin configuration is correct.
